Question about Fellowes DS-1200Cs 12-Sheet Cross-Cut Shredder
Fellowes DS-1200 shredder troubleshoot - Fellowes DS-1200Cs 12-Sheet Cross-Cut Shredder
fellowesrep
  • 102 Answers
SOURCE: Fellowes Shredder keeps running
You should be able to flip up the cd cover and visibly see the sensors in the center of the paper entry(look like little LED lightbulbs) Clean with a Q-tip dipped in rubbing alchohol. This should solve your problem. If it doesn't you probally have a burned out sensor. call 1-800-945-4545 to check with customer service.
Posted on Feb 22, 2008
fellowesrep
  • 102 Answers
SOURCE: Fellowes 220c-2 repair manual
call Fellowes Customer Service 1-800-945-4545
FixinFax
  • 3085 Answers
SOURCE: how to oil a fellowes os 8cs shredder
Oil straight down into the feed slot. 3-in-1 oil or Marvel Oil are OK to use.
Posted on Jan 05, 2010
SOURCE: Need large nylon gear for fellowes shredder od1500c
Call 1-800-955-0959 they will need serial # of it....hope this will help
Posted on Apr 30, 2010
SOURCE: I have a new Fellowes
I am sure you've figured it by now ...
In any case it is weird isn't it? The manual is inside the bin!
There is a slot on one side of the bin, in addition to the carry-slot at the top. This slot is supposed to have a transparent "window", but being black on the inside and the unit is also black, it doesn't appear to be transparent. In any case, hold the slot that is on the side and pull outward - the bin will come away. It is quite stiff, and only via an accidental **** was I able to discover how to open the bin, and found the manual inside.
Posted on Jun 21, 2011
Before I recycle the metal from my DS-1 Fellowes shredder (small driven gear stripped) does anyone need any other parts? Two larger gears are good. Norm
I'm desperately looking for the small nylon gear (see attached photo) of the DS-1.
As I live in Brussels, Belgium I'm also curious to know where you have found the gear outside US and at which price.
Thanks,
Dirk.
before-recycle-metal-from-ds-1-fellowes#solution-section-ew2ec1vog3kw5zx5dcajxfma-4-3.jpg
Jan 27, 2015 | Fellowes Office Equipment & Supplies
Source for gear for fellowes 301101 DS-1 paper shredder
Replacement Parts - Paper Shredders Can I get my Fellowes paper shredder repaired or purchase parts for it?
The majority of Fellowes personal shredders (small shredders that can fit under a desk) are repairable and will have parts available. If you would like to check your model shredder to determine if parts are available, please click the "Ask a Question" tab above, and advise the model of shredder, the shredder's serial number and a description of the part needed. The serial number will be located on the bottom side of the shredder head below the bar code.
*** Please note: If your shredder is still within the warranty period, we ask that you do not open your shredder until speaking with a Fellowes Representative, as opening the unit may void your warranty.***
Fellowes office/commercial shredders (large shredders that cannot fit under a desk) are repairable and parts will most likely be available. Please do not try to repair the shredder yourself or you will void your warranty. Models included in the office shredder line are 125i Series, 225i series, 325i series, 380 series, 420 Series, and 480 series.
If you would prefer to have a local servicing dealer provide repair service to your office shredder, and would like to find a dealer in your area, please see the below link to search for a dealer by zip code.
http://www.fellowes.com/Fellowes/site/support/support_authorizeddealers.aspx
To order replacement parts, or if your model shredder is not listed, please click the "Ask a Question" tab above to ask us about your shredder. *** Please be sure to include your serial number from your shredder for the fastest service ***
Our office hours are 7:00 AM to 7:00 PM, Monday through Friday Central Standard time.
Jan 22, 2015 | Fellowes Office Equipment & Supplies
Yellow light comes on
Look at the manual in the link below. If you do not find the answer, call Fellowes.
Fellowes Shredder Manuals
Sep 18, 2014 | Fellowes FEL-3011001 DS-1 Light-Duty...
Why do my fellow ds-3 shredder not turn on?
http://assets.fellowes.com/manuals/DS-3%20Manual_1L_2010.pdf
Check and make sure the receptacle where it is plugged in has current. Unplug the cable and then plug it back in. You have an Over-ride switch on your unit, try it. If it still does not work you will have a power supply problem.
Aug 18, 2014 | Fellowes 3231001 8-Sheet Ds-3 Deskside...
I have DS 1 shredder which is jammed - how do I get top off and get to the blades ?
Theres a Youtube video that shows how to dismahntle and reassemble a Fellowes DS-1 shredder. Try
www.youtube.com/watch?v=n8XopaaGgQM
Apr 30, 2014 | Office Equipment & Supplies
The teeth are not turning it is just making a noise :(
Check the breaker,
Otherwise it may be a faulty unit. Contact Manufacturer for more details.
Oct 14, 2013 | Fellowes DS-1 Shredder
Gear for a DS 1 Fellowes shredder
heres a site that has alot of gears
http://wheelermachines.com/fellowes_parts.htm
also http://www.compax.com/shredders/parts.html
you may have to call or email them , as all parts are not always listed on the website
Oct 16, 2008 | Fellowes P400C-2 Shredder
Fellowes DS-1200Cs 12-Sheet Cross-Cut Shredder Logo
74 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
