Question about Frigidaire Refrigerators
R5303b fridge runs all the time and ices up
Was defrosted a week ago, now ice is collecting on back wall
  • 1073 Answers
SOURCE: Maytag side by side refridgerator
the drain tube is clogged or maybe frozen, remove the restriction and you will have no more problem
Posted on Apr 10, 2008
  • 531 Answers
SOURCE: WHIRLPOOL TOP FREEZER ET1WTKXKQ01. NOT COLD ENOUGH & KEEPS RUNNIN
remove the back wall leave the unit to run half hour open and see if coil have frost all the way from the top of the coil to the bottom if the coil is full you have adefrost problem could be your timer defrost thermostart or heater
Posted on Mar 31, 2009
  • 111 Answers
SOURCE: /gss22wgpjbb Ge side by side fridge Keeps freezing
automatic defrost its not coming on check the heather or hi limit
Posted on Jun 17, 2009
mgprice
  • 744 Answers
SOURCE: fridge/freezer cooling inefficiently
Either the repair guy did not wire up the heater correctly or he replaced the wrong part, if the heater was good it was likley to be the defrost thermostat...I would call the repair guy back to check.
Posted on Jun 23, 2009
blueextc3221
  • 15935 Answers
SOURCE: GE TFX20SA back wall of freezer freezing (snow
CLICK HERE for an expanded view of your freezer section.
Can you see the evaporator fan moving when it is plugged in?
Otherwise your defrost timer has failed.
#257 in THIS diagram
CLICK HERE to see the part.
CLICK HERE for testimonials about installing the defrost timer yourself.
Thanks for using FixYa - a VERY HELPFUL rating is appreciated for answering your FREE question.
Posted on Jul 13, 2009
Drain clogged on MCBR415S
Unless that fridge has an automatic defrosting cycle, NO water should be collecting at the drain area under normal circumstances. The only time that drain is needed is during defrosting (manual or auto).
Does the unit ever turn the cool cycle off or is the fridge always running (does the fridge ever stop humming)? If the fridge is always running, ice will build up in the fridge and it is either because the thermostat is broken or the door is not sealing properly allowing the cold air to escape. This can be due to something inside the fridge is preventing the door from closing properly, the door itself being not properly aligned with the fridge compartment, a broken door seal or a bend door or a bend fridge frame.
Ice can build up fast when a fridge is installed in an area with high humidity (like in Florida) and the door is opened frequently (like every 5 minutes to get a beer out, like during a house party).
If the fridge door seems to seal properly and the fridge seems to keep things cool, it might be enough to defrost the fridge to get it back in proper operating condition.
When loading the fridge, allow enough space between items, to permit the air to circulate.
Good luck :)
Jan 06, 2014 | Magic Chef Refrigerators
Fridge warm, freezer has frost on back panel & is defrosting, fans work, just changed defrost thermostat, no air is moving from freezer side to fridge side, drain pan under fridge is dry
this fan needs to run when the compressor runs,check fan blade for being jammed by ice if you have this much ice on back wall as ice will stall motor,if no fan there will be no cool air to refrige compartment also the defrost drain tray will fill with water then freeze over which in turn floods the freezer floor and refrige compartments cause it cannot drain to the pan in the bottom
May 11, 2012 | Kenmore Side by Side Refrigerator
The "de" is flashing on my display. I know it
Try the reset procedure:--- Turn the fridge freezer off by the wall socket for 10 minutes. Then reconnect the power again and see.If that is not helping then ,DE is most likely indicating a defrost problem.. open the freezer and take a look at the back of the freezer wall - is there a bunch of frost on that back wall? If the ice is collected there then unplug the unit for 24 hours to manually defrost it or take a hair dryer and defrost all collected ice to defrost the ice quickly.There also could be a temperature problem due to a defrost failure, easy to check the freezer temperature to confirm.---------------- Thank you.
Jan 25, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Tempreture on fridge too high ice build up in fridge mahes noise like a tractor
Your automatic defrost cycle may not be working. Feel the walls inside and if they are hard solid you have ice build up and the fan is hitting the walls or ice making the noise. Unplug your fridge for 2 days and let the ice in the walls melt. Put towels on floor to catch water. Plug it back in and it should run fine for a couple of weeks until the ice builds up again. You have a bad timer and it isn't letting the defrost cycle come on. Defrost cycle are heating elements that melt the ice build up and runs about 10 mins once a day or so. This will give you time to check if an afforable repair can be done or a replacement fridge.
Jul 11, 2010 | Samsung Refrigerators
Refrigerator not cold, freezer barely cold and has ice on back wall
You have a defrost problem if the ice is on the back lower wall of the freezer section.... This is where the evaporator is located just under a fan.(aluminum coils looks like a radiator) There are three parts to the automatic defrost system- the heating element(found at the bottom of the evaporator) a bi-metal thermostat(found at the top of the evaporator) and a defrost control board(usually in the top of the refrigerator section,but this varies)
If you take off the back freezer panel and melt the ice build- up with a hair dryer or letting it open overnight, without poking any holes in evaporator and losing freon(out a fridge) your fridge will run fine for about 3 weeks. This is humidity from air collecting, automatic defrost system usually works about every 8 hours when working normally. Your sealed system and compressor are fine, you have a defrost problem. Good luck.
Mar 14, 2010 | Maytag MZD2766GES Side by Side...
Fridge freezer side by side running constantly but not cooling.
Make it a habit to defrost it every week. You see, when ice forms around the evaporator tubes (which runs around the walls of fridge and freezer), heat exchange reduces (that means heat is no longer absorbed from the things inside the refrigerator) and cooling stops. See whether freezer walls or fridge walls are damaged. Do not use knives or any other sharp tools to remove ice. Do not forcefully remove items that are difficult to take out from the freezer. Defrost and remove them.
Aug 12, 2009 | Freezers
The entire backwall of the unit is solid ice. 2
OK first defrost the refrigerator. Unplug and remove the back panel covering the evaporator and lets look at the defrost element and defrost thermostat. If they are OK we may need to have a look at mother board mounted on back of fridg. Let me know when you are ready, Sea Breeze
Apr 22, 2009 | GE Profile PDS22SCRL Stainless Steel...
Mar 31, 2009 | Whirlpool ET1WTKX Top Freezer Refrigerator
Frost built up all down the back wall of freezer and temp is down
I just had the same problem a few weeks ago...it was the defrost motor in the freezer...here is a quick fix..until you can get it fixed...turn it off...get it defrosted...all ice gone...and the defroster will work again...if you have one of those steam cleaners..that will defrost it fast!!!
Mar 30, 2009 | Refrigerators
Refrigerators Logo
48 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
