Question about Boating
Instruction Manual for stratos boats
Manual for a 1989 stratos boat
  • 2712 Answers
SOURCE: Why are Aluminum Fishing Boats the Best Fishing Boats?
A timber boat is high maintenance. Trust me, I've had quite a few. You're always sanding timber, varnishing timber, repairing timber and lots more. Now if you're happy to be doing that then that's great, but recognize that's the price you pay for a great looking timber fishing boat. And a timber boat is often heavy, and will not last well, particularly if you aren't as diligent with your maintenance as you could be. And they puncture easily when you hit something, as I did last week. But if you're not an enthusiast for working on boats then timber isn't your best choice. What you want in a fishing boat is this. It needs to be tough. It needs to be low maintenance. It needs to be puncture resistant. It needs to last forever without spending hours working on it. It needs to be easily repairable. And it needs to be cost effective. For me the best choice fishing boat is an aluminum fishing boat. Aluminum has properties which make it the perfect material for building fishing boats. It is very light and strong for it's weight, and can be easily welded, so is ideal for both building and repairing. It is extremely long lasting, and is very resistant to puncture. Now of course that doesn't mean it can't be damaged, as it can. But you need to hit it pretty hard to do some serious damage. And if you did that to a timber or fiberglass boat it will be very seriously damaged. And an aluminum boat may just dent, rather than fracture, so you can head right back home with nothing more to show than a dent, instead of possibly be the subject of a rescue from a sinking boat. And it lasts forever if treated right. If you get a great aluminum fishing boat and treat it well you may well find yourself leaving it to your kids. Because aluminum boats are light for their strength they often need a smaller engine, and the engine is probably the highest cost item. A smaller engine costs less, and uses less fuel. And with a smaller engine they are also lighter and easier to handle. And they require little maintenance. Make sure you hose your boat down after a day out, especially in saltwater, and if you drop a lead sinker make sure you pick it up, as it's not great to leave any other metal in contact with aluminum, otherwise you don't need to do too much maintenance at all. More fishing time. And because aluminum boats last so well they also retain their resale value well. I bought a used aluminum fishing boat 2 years ago and it is currently worth a little more than I paid for it. So there's plenty of good reasons to buy an aluminum fishing boat. Unfortunately they aren't cheap if you want to buy a new boat, but for the same reasons I've mentioned above, it's way better to buy a used aluminum boat, as a used boat is usually much cheaper than a new one, and retains it value well. I would never buy a new aluminum boat. So grab yourself a great used aluminum fishing boat and get fishing this summer, it's the best way to get on the water.
Posted on Dec 01, 2008
captainjeffq
  • 52 Answers
SOURCE: need Wiring Schematic/Diagram for 89 Astro GT16 boat
In all honesty, its probably impossible to get the original wiring diagram. Also, I would be willing to bet that there has been alot of re-wiring and changes made to the wiring and electrical system of the boat. If you describe exactly what your trying to do, install fix or re-wire I may be able to better assist
Posted on Apr 14, 2009
  • 86 Answers
SOURCE: I need year of starcraft boat
If you find the hull identification number which is always stamped on the right side of the transom then the last two numbers indicate a year. Ex. BUJ5C45208 Would be a 2008.
Posted on Aug 09, 2009
  • 53 Answers
SOURCE: Yamaha 115hp 2 stroke Outboard Boat Motor. Went
is it carbureted or fuel injected? are your warning horns working? if it iscarbureted then a few easy test can be done to find out. if its fuel injected then its a little harder but not impossible.(1) check compression. without the year model I'm giving you a average numbers. all cylinders need to be over 100 lbs and equal each other within 5 lbs.(2) check spark. use a spark gap tester all cylinders should jump a half inch gap. if you have good compression and good spark fuel is the problem nine times out of ten. clean fuel lines replace primer bulb and replace all fuel filters. Yamaha has a gravity filter under the engine coul. take it to the lake if no improvement. clean carbs. same test to be and fuel system service used of fuel injected engines. if no improvement in engine preformance then you will have to take it to a dealer to test with computer.
Posted on Nov 01, 2009
fishdoctorfi
  • 178 Answers
SOURCE: have everstart 24dc-6 boat battery is it 6 or 12 volt
Sounds like the Batteries we used in golf carts......Deep cycle and shoe is right 6 volt.
Posted on Jan 01, 2010
Does a 1990 stratos 18 ft bass boat have wood in the transom and stringers
Yes it would have wood covered with fiberglass and Resin.
Apr 25, 2017 | Boating
1997 Nitro bass boat 640 LX. Where can I get an owner's manual?
Boat Manuals Now Available Free From Vessel Vanguard ...
www.passagemaker.com/.../boat-manuals-now-available-free-from-vesse...
Nov 14, 2013 - Boat owners are often frustrated by the diffi. ... I need complete operating manual for 2001 Nitro 175 Sport Fish ski boat. Peter Swanson April 6, .... I am looking for a Manuel for my Italian made 1997 AquaViva Frontier 6 meter cruiser. Thank you,. Jeff ... Have purchased 1989 Pro Craft Stalker 180 Bass Boat.
Aug 26, 2015 | Nitro Boating
Can you find an owners manual for a 2005 stratos 289 pro xl?
Isn't this a boat? Why are you posting here?
Jul 31, 2015 | Cars & Trucks
How do you remove Johnson controls from 1997 stratos 295 pro elite
the control box is bolted to the side of boat and there are nuts on the back side of it . the rest just unplugs
Mar 23, 2015 | Boating
Where is the kill switch on 1997 stratos bass boat ?
usually on the shift throttle control.
Aug 26, 2014 | Boating
Bnz4m146J495
1995 Stratos
Jul 16, 2014 | Boating
Stratos bass boat
Is your speedometer working? If not, the pick up tube may have come off and is dripping water in through that.
May 02, 2014 | Boating
Stratos bass boat wont start when key is turned
Check Battery, Battery switch, kill switch, check all wiring connections for loose connection. Check starter and selenoid.
Sep 04, 2013 | Boating
Boating Logo
184 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
