Question about Sewing Machines
Bernina 830 I've had this machine since the early 80's and have hardly used it as it has never worked properly. my latest issue is that the zigzag selector will not turn back to straight stitch. A Bernina 830 sewing machine was given to me and had not been used in quite some time. I threaded it and started it up to see if it still worked and everything was running smoothly, then it suddenly stopped, but the light still worked. Manually moving the needle also still worked smoothly. It suddenly began to work then stopped again. I'm going to clean it and oil it, but I was wondering if there may be a more serious problem? Thanks for your help.
  • 202 Answers
Pop the top open. (push up on each end with thumbs). With the top off and you watch the mechanism as you move the stitch selector up and down you will notice this moves between a forked shaped part on the right side in back that is supposed to click in place back and forth. Its very common for this to be gummed
up. Oil it and keep moving it back and forth and oil it again. It will
start clicking in and you will be in business.
Posted on Jan 03, 2009
After many hours of sewing on denim, the zigzag stopped working on Bernina Record 830
Have you been regularly cleaning and oiling your Bernina? Unless a gear is cracked or something else as serious, it could very well be that the machine has seized due to lack of appropriate lubrication.
Wheel on right side that controls the needle up and down is very tight...
Jun 23, 2017 | Bernina Sewing Machines
The zigzag on my Bernina record 830 bought in the '80s does not work properly. What can I do to get it to stitch wider than 1/8?
Your machine is seizing due to lack of regular oiling.
Here is a diagram of the oil ports for your 830 Record:
Following is the process I used to "save" a few older Berninas:
Apr 29, 2017 | Bernina Sewing Machines
The button hole knob on my Bernina 830 is very hard to turn. Is there anything I can do to fix this myself?
Do not force the dials, or they could break. I have resurrected some older Berninas whose knobs were totally frozen. The dials usually get stiff when the oil is drying out. Be sure you are cleaning and oiling your Bernina 830 on a regular basis. Use only NEW good quality oil (not 3-in-1, WD-40, or cooking oil). Only one or two drops in each spot per your manual. To help loosen things, direct hot air from a handheld hairdryer into the interior of the machine (direct it toward the buttonhole mechanism). See if that helps loosen things. You should perform regular maintenance on your machine every 40 hours of use or every six months if not in use.
If the dial is still sticky, slowly rotate the dial and study how the mechanics work in the machine and apply a drop or two of oil to the places where metal rubs against metal.
Hope this helps.
Carol--glad you were able to get it operating again. Using +40 yr old oil is probably not the best choice. If the oil is dark yellow or brown, you should discard it as it will eventually become gunky too. You can pick up a fresh bottle from a Bernina dealer--be sure to tell them that you have an oldie (but goodie) Bernina 830 Record to get the correct oil. You can get the dispenser with the long spout to get into hard-to-reach spots. There are other oils you can use (can't remember the specs right now), so unless you want to do some research, Bernina oil will do just fine. (You can join the Yahoo Group for BerninaThirtySomethings where there is a ton of suggestions on oiling, operating, maintaining, and using your wonderful 30-Something vintage machine. There is also a long conversation about types of oil to use.)
If it seems your machine is kind of sticky (difficult to turn the handwheel, or the motor seems to strain to get things moving, etc.), then a good suggestion is to put a drop of oil on every moving metal-to-metal joint. (Slowly rotate the handwheel, the dials, and levers and watch where things move.) Do NOT oil the two plastic gears or the metal cams!!! And, use only 1-2 drops of oil. Be sure to get the 4 or 5 oil holes on the needle take-up mechanism (they look like rotating knuckles) and adding a drop where the needle bar rubs would help. Look for a couple of other oil holes just to the right of the cams that help keep the stitch selector operating, and don't skip the oil hole on the right near the handwheel. Be sure to get the oil holes in the bobbin area (there's usually one on the far back behind the bobbin mechanism next to the case that is difficult to see, and also one on the far right that helps the feed dogs. Once you've hit all the moving joints, you can hand rotate the handwheel to get things distributed. Then try sewing slowly. You should notice your machine runs much quieter and smoother now. Such a happy sound!!!
Once things are moving well, you probably won't need to oil the individual moving joints again unless you notice things are getting a bit sticky again. Too much oil is not a good thing too, so don't over-oil!!!
Cleaning the bobbin area and putting a drop of oil in each oil hole and the hook race is probably sufficient to keep your machine regularly maintained. (The manual does not show all the oil holes, so you might have to look for them. Once you are able to recognize them, they are relatively easy to locate --be sure to rotate the handwheel as some oil holes are not always visible.) Some machines have a red dot to help you locate the oil holes, but sometimes not all of them are marked. (The picture below will help you locate the oiling spots.)
Be sure to run your sewing machine on some scrap fabric after oiling to make sure you don't stain your nice project!
Enjoy your lovely machine! Treat her well (oiling and cleaning), and she will treat you well for many years!f8ddf002-f79d-4ad0-a6d1-deee606a0728.jpg
May 05, 2015 | Bernina Sewing Machines
I Have a bernina 830 and the foot doesn't come down or up how do I get it working again?
Have you followed the maintence standards (oil schedule). If not
that may be the issue. A wild guess (at least this was the issue
recently with wife's older White machine. The foot lever was catching on the thread cutter device. Otherwise, perhaps a screw has come loose somewhere in the lever and or foot. Good luck. Double check your manual troubleshooter section.
Feb 26, 2015 | Bernina Sewing Machines
My Bernina 830 sewing machine will not do a zigzag stich
We are assuming that the zigzag width dial is at the widest position but the needle will not move laterally for zigzag... The following logic should be applied for Bernina machines 530, 730, 830, 930 machines with a guided motion zigzag cam.
1. The switching pawl (lever on the top cover that switches from zigzag to cam patterns) may be engaged in the cam or automatic pattern side. Check that first.
For zigzag application, the lever must be engaged in the zigzag side (lever pulled back toward the operator). The stitch width dial is then used to provide your choice of width.
2. It is common, due to oil varnishes, that the switching pawl that is actuated by this lever is stuck between the zigzag and the automatic position, thus preventing the transmission of power to either the zigzag cam or the automatic pattern cams and to the needle.
The best way to detect this is to remove the top cover. You can then switch the lever back and forth to observe if the switching pawl engages firmly into either of the receiving forks. If the switching pawl is sticking, a few drops of certain solvents are applied by a technician on the switching pawl support. The switch lever can be rapidly switched back and forth until you see the switching pawl engage into the receiving forks and you hear a crisp clicking during each engagement. This repair can be permanent or it may create only a temporary fix due to the amount of oil varnishes on the parts.
If the machine is heavily varnished, it suggested that the parts be disassembled and cleaned for flawless performance. If the machine had been sprayed with WD-40, petroleum based solvents like mineral spirits will not break down these varnishes.
A caution regarding solvents...DO NOT USE (WD-40) as your solvent. WD-40 is a marvelous product for its intended application as a water displacement device. It is not to be used for lubricating a sewing machine. Note: "Bernina Technical Information bulletin #1" issued in 1982, forbade the use of such spray lubricants and solvents. SewTechnical Home
Sep 28, 2014 | Bernina Sewing Machines
Supply of new stitch cog for Bernina 830 Record
I don't know what a stitch cog is by your definition but I suspect that you may be referring to the cam stack worm gear, part # 310 007 03. These gears are available, however those produced and sold as after market parts online have ranged from bad to very bad. I would suggest that you find an OEM part (not a reproduction) that are still available from time to time on EBAY etc.
Changing the gear is not as straight forward as it may look. The proper replacement requires: 1. removal of the cam stack without damaging the machine parts, 2. removal and installation of the new gear with the correct alignment of the individual cams, 3. installation of the cam stack and pattern indicator without axial play, 4. correct parabola timing of the main-shaft worm wheel and cam stack gear, 5. synchronization of the zigzag and automatic cam parabolas, 6. pattern indicator timing, 7. checking and adjusting the automatic needle position. SewTechnical Home
Jun 14, 2014 | Bernina Sewing Machines
Bernina 830, worked fine until today... think it
there is a board inside the foot pedal that goes out sometimes you can check this by flipping the foot pedal upside down and at the top right there is a small hole where you can adjust the speed with a flat head screwdriver but be gentle it breaks easy, if its out you can take it to a bernina dealer and they might have a reapired one or they can send yours off for repair since that part is repair only
Jun 26, 2009 | Sewing Machines
How do i use the zigzag stitch on my bernina 830
Hi, open the top cover and if you watch what goes on inside from the top when you move the top change lever you will see part of it goes through a fork or U-shape part. This part is probably stuck and needs some oil. After oiling and working it back and forth a bunch eventually it will start snapping into the notches its supposed to. I beleive then you will have your zigzag back.
Either that or you have the stitch width set on zero.
Feb 01, 2009 | Bernina Artista 180
Bernina 830
The 830 is a fantastic machine. It is completely mechanical internally for the stitch selections. A good cleaning and oiling should get you back on track.
Although it has not been used much, some of the original oil or grease can become sticky or pasty in time especially if it has not been used that much. Again a good cleaning and oiling should solve your problem.
Good luck, bushvideo
Sep 05, 2008 | Bernina Artista 180
Sewing Machines Logo
188 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
