I Have a toshiba A200-AH6 PSAE6080c satellite laptop for about 16 months now a week ago my laptop just shut down all of a sudden without any warning.I thought it might be the battery because when i put the laptop back on it shut down before it could successfully boot up into windows it was on AC power when this happens but when i took the battery out and tried it it works great.it only shuts down when the battery is on, i tried a friend of mines battery of the same model and the same thing happened.I think that the charging circuit is damaged but i do not know how to repait it can u help?
    Sergeant:
  • 183 Answers
Please, visit following websites for complete instructions with picture previews.
http://www.laptoprepair101.com/laptop/2006/01/28/toshiba-satellite-m35x-a75-power-jack-problem/
http://www.hardwareanalysis.com/content/topic/48464/
Effort rating all answers.
Posted on Jan 03, 2009
Toshiba Satellite A200-106 shuts down all over a sadden without warning
Try cleaning it, it could be running hot and shutting down.
Jul 26, 2011 | Toshiba Computers & Internet
My Toshiba laptop suddenly shuts down by itself without any warning. Sometimes it works fine for hours, sometimes it shuts down in 10-15 minutes.And from yestarday it is shetting down after 30seconds after...
  1. The keyboard and the bottom of your laptop are very hot when the laptop is working.
  2. The CPU fans are working all the time at maximum rotation speed and operate much louder than before.
  3. The laptop suddenly shuts down by itself without warning. When it just started, the laptop was shutting down after 1-2 hours and how it shuts down after 5-10 minutes of operation.
  4. The laptop works fine when it runs idle, but shuts down as soon as you start using any memory demanding applications (DVD player, image editing software, video editing software, etc.).
Solution:
If the CPU heatsink is not clogged with dust and lint completely, you can use canned air and just blow it inside the laptop through the openings on the bottom and on the sides. It's nice as a precaution measure, but it might not work if your laptop already has a problem and the heatsink is completely clogged.
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes you have to open the laptop case all the way down.
  2. Carefully disconnect the fan cables on the system board and remove the fan. If the fan makes unusual sound when it spins (grinding sound), I would recommend to replace the fan.
  3. Clean the fan and the heatsink with compressed air.
  4. I would also recommend removing old thermal grease from the CPU and applying new grease for better heat conductivity.
I decided to use a shop vac to suck the dust out and it worked. I tested it by letting the machine run all night and it worked. It's been a couple of weeks now and I'm glad I did it. I was ready to take the machine apart, now I'm glad I didn't. I'd suggest you use a heavy duty shop vac to clean out the fan and heat sinks first.I agree. Try to fix the problem without taking the laptop apart first but I would recommend using a powerful air compressor instead of a vacuum cleaner.
If your laptop is still under warranty, you can take it to any Toshiba Authorize Service Provider and fix the problem at no charge to you.
Toshiba Satellite A15 Clogged Heatsink
Toshiba Satellite A35 Clogged Heatsink
Toshiba Satellite P15 Clogged Heatsink.
Aug 25, 2017 | Toshiba Satellite A205-S5855 Notebook
Shut down problem
the fan/heatsink asembly is most likely clogged .. causing the thermal controller to kick in a thermal overheating warning and shutting down the laptop
Jun 13, 2010 | Toshiba Satellite A100-S8111TD Notebook
As soon as the toshiba a200 boots up there is a loud static noise in the speakers.It does not stop making the noise. The problem started 2 months ago when adding an audio file into powerpoint
you should check the configuration of the microphone and see if the volume is very high which leads to feedback with the speakers and produces the squeak
May 24, 2010 | Toshiba Satellite A200-0ET00X Notebook
How do i restore my toshiba satellit pro a200 back
If you have a backup, you can do that, off your hard drive. Otherwise, you will need to get a replacement disk from Toshiba.
Feb 25, 2010 | Toshiba Satellite Pro A200-EZ2204X...
Toshiba a200-1VO
hi
please open the laptop then push the semos battery plz start the computer then shut down then enter the semos battery then start computer password is reset other plz install the bios this laptop
Jun 06, 2009 | Toshiba Satellite A60 Notebook
Cannot get wireless connection with my Toshiba satellite A200-AH6
Hi
Please try the Canadian Toshiba Driver site: http://209.167.114.38/support/Download/ln_byModel.asp
Once you have selected your Model, click the Go button, a popup window will appear and the Wireless Drivers are at the bottom of that list.
Hope that helps
toypaj
Feb 28, 2009 | Computers & Internet
Toshiba Satellite L200 version of Laptop with OS vista
some keys in my laptop toshiba l200 suddenly stopped without any reason so i want to know how can i fix it and if may be infected by virus
May 19, 2008 | Toshiba Satellite Pro A200-EZ2204X...
Computers & Internet Logo
222 people viewed this question
David Payne
David Payne
