Question about Weslo Cadence Ct 5.8 Treadmill
My Weslo treadmill needs to be aligned and tightened. Can I get a service tech to fix it?
The control panel won't stay on the legs. The legs are loose. The treadmill is so loose it is not safe to transport it.
5 Suggested Answers
SOURCE: I have a Weslo 10.5 treadmill. It was my daughters
You have to put the speed all the way down. Hold down the start button for 10 seconds till it stops blinking and then hit start again and move the speed up. It's a child safety feature on the treadmill.
Posted on May 07, 2009
hasan mahmud
  • 35 Answers
SOURCE: weslo cadence treadmill fuse keeps tripping after
dear sir,
this types of problem occurred due to reason given below:-
1) if your motor belt too jammed. motor need more power to rotate it.
2) motor internal coil insulation problem.
3) semi short circuit in the internal control circuit.
how to check :-
at first look the label on motor try to find out the motor Ampere then measure with a ammeter if it drawing current is high from label mentioned ampere
then motor is faulty.
for check the circuit if u don't have any previous idea plz contact with qualified technical person.
hope that u get the answer.
thanks
Posted on Oct 22, 2009
  • 40 Answers
SOURCE: I have a Weslo 92060 treadmill. I need to replace
It's laborious, takes a little time. With 2 people who know what they're doing, an hour or so, under and hour if it goes smoothly. With one amatuer, probably most of the day.
With a Weslo, I don't recomend it, simply because it's not worth the repair.
Posted on Nov 01, 2009
Testimonial: "Thanks."
maxtreadmill
  • 832 Answers
SOURCE: treadmill will not operate when plugged up.
check the outlet first by plunging in a light to make sure their is power and that the house breaker was not tripped. then plug in the power cord next locate the reset/off circuit breaker on the treadmill frame near the power cord. Switch the circuit breaker to the reset position. Then place safety key on console and the display should light up if not then you may have a lower board problem.
Posted on May 17, 2010
Weslo Candence 5.9 won't run after being moved
Check for any loose electrical connections between control panel and motor especially any plug together connections. Moving may he have loosened or unplugged one of these connections. Hope this helps.
Dec 29, 2013 | Weslo Cadence G 5.9 Treadmill
Weslo g-40 won't come on
see the videos and LUBE the deck belt +rollers bearing .
Feb 04, 2013 | Weslo Cadence G-40 Folding Treadmill Sale
It won't turn on
SEE the video and proceed according. God bless you
Nov 13, 2012 | Treadmill Doctor Weslo Cadence 835...
My treadmill is brand new and not coming on
Hi ispeaktobefr,
Please check the following:
1. Please make sure that the battery is fully charged, because it won't work if not.
2. If the motor turns slowly then your motor is ok, if not the motor is bad and would need to be replaced.
3. If the motor is ok then the motor controller ( the board with the metal ) is malfunctioning and would need to be replaced.
4. You may also check the fuse.
Hope it helps.
Thank you for using FixYa.
Jul 14, 2011 | Weslo Cadence 60 SE Treadmill
Weslo Cadence 450 Treadmill Manual
When turned on it acts like the walking surface is grabbing.Itgoes and stops its not as bad when speed is increased,but it still feels like it is grabbing.
Mar 22, 2009 | Cadence Exercise & Fitness
How do you adjust the belt for a Weslo Cadence 815 treadmill?
Hi, I don't have a manual on your particular treadmill but most all treadmills use the same type of belt tension and tracking, which is an allen screw adjustment on the rear tension bar. One on either side. You should have been provided an allen wrench with your treadmill, if not then use one of your own the proper size. Make the adjustment with the unit running at its slowest speed. Clockwise tightens the tension and will draw the belt. Good Luck, this should Fixya!
Mar 14, 2009 | Cadence Weslo 825 Treadmill Walking Belt
Weslo Cadence Ct 5.8 Treadmill Logo
18 people viewed this question
Top Weslo Exercise & Fitness Experts
Electro Med Services...
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Are you a Weslo Exercise and Fitnes Expert? Answer questions, earn points and help others
