Question about Canon (6981A002AA) for imagerunner 2200, 2800, 3300 Print Server
Ir2200 trying to network
Installed the network card, and can ping the pronter as well I can get into printer configuration from computer but can not print anything.
  • freddiel Apr 08, 2009
    I have two IR2200 with network cards (FG3-1186). RUI states copier is ready for print and scan (green dots on status page) Installed printer drivers (tried both PCL and PS). Also tried LPR software. The company who just supplied the used copiers states I require £1500 of hardware for each copier to make them print/scan on the network... Seem a lot of money for this.
    Any help appreciated.
  • thirsty2k Apr 29, 2009
    I have imagerunner 2800 connected to network, but I do not know how to access it via Web UI and configure the printer using IP. the company lost the user manual and Cd rom. Please help, need this done coz we have share a single printer scanner. email thirsty2k@yahoo.com
    Sniper:
  • 89 Answers
Andzulisv is correct. You need N Boot Rom as well as Network Card and to flash copier with system software. Call a tech to do this.
Freddiel. Can get network kits very cheaply on ebay.
Posted on Jul 17, 2009
  • 168 Answers
Well if you only put in the network card you areacouple steps short you also need the N chip boot rom then you need to flash the copier with system software from canon most canon techs should have this
Posted on Jan 07, 2009
Network configuration not print
can the machine be pinged? does any computer print to it? print drivers installed. router ok? activity on leds at network connection on copier? net work cable good?
Jun 20, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Amber light is flashing on network card
Switch off the printer, re connect the net work cable, switch on the machine & wait till ready mode comes.. Go to administration on control panel, select configure device,select configuration page, print,, total three print out will come, in that see the IP address.. If any IP address showing, ping that IP from system, if its pings, reload the drivers once again.. check for the print. If no IP adress showing in configuration page, try with another net work cable & try above said exercise.. Even no luck, remove formatter from the slot & re-fix once again & try... Even no luck.. it might be network port faulty. If its warranty contact HP support for free replacement.. If no warranty purchase HP620n or higher version of zetdirect card(net work card) install it... But take service engineers suggestion before replacing the network card..
Aug 01, 2012 | HP LaserJet M4345 MultiFunction Printer
I changed internet providers and now my wirless printer doesn't work
STEP1: Print "Network Configuration Page"
  • Make sure paper is loaded.
  • Push the Setup Button on the all-In-one.
  • Use the Down Arrow key to highlight the Network menu.Push Ok
  • Push Ok again to select View Network Settings .
  • Push Ok again to select Print Network Configuration page .
  • A network configuration page will print.
STEP 2: Check the Printer Connectivity
  • From the printed Network configuration page, note down the printer IP address, (example : 192.168.1.6).
  • Click start, and then click "RUN".
  • In the RUN box, type "CMD" press OK.
  • In the command screen, type "Ping IP address" (Example: Ping 192.168.1.6). Hit Enter.
  • You must get output similar to below.
Pinging 192.168.1.6 with 32 bytes of data:
Reply from 192.168.1.6: bytes=32 time=1ms TTL=64
Reply from 192.168.1.6: bytes=32 time<1ms TTL=64
Ping statistics for 192.168.1.6:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 1ms, Average = 0ms
STEP 3: Configure Port.
  • Click on start >> Control Panel >> Printers and Faxes.
  • Right click on printer icon, select "Properties".
  • Click the PORTS tab on the top.
  • Select your product under the Printer column, and then click Configure Port . The Configure Standard TCP/IP Port Monitor dialog box opens.
  • Look in the Printer Name or IP Address box. This value should match either the MAC or IP Address on your network configuration page. If the values match delete the printer and install it again.
  • If the values does not match,Click inside the Printer Name or IP Address box, and then type the appropriate value (IP address / MAC address) as listed in network config page.
  • Click OK , and then try printing again.
Regards
Riztech
Mar 08, 2010 | HP Photosmart C6180 All-In-One InkJet...
Trying to connect two computers to the internet through a router (not wireless) having problems after connecting both computers to the router, only one computer has internet connection. My internet...
Initially check whether the ip address is assigned in the computer in which internet is not browsing using the command ipconfig/all for windows and ifconfig for linux.If ip is present try to ping the default gateway ip address,if ping is success there is no issue in the cable you used and also with ip address.If ip is not assigned assign ip by manually or by using dhcp of router.Enable and disable the lan card in the router so that sometimes the problem get resolved.After ip is assigned and ping with router is ok .Ensure dns servers are correct else give google public dns server 8.8.8.8.Then try to ping www.google.com in command prompt if ping is success then you can browse.
Mar 01, 2010 | HP Pavilion a1610n PC Desktop
Pls. help us,how can we used land cord to connect printer konica 7035 to computer. we already down load a driver from internet . we try many times to check sa IP address and test print but still we cannt...
Using arp command (UNIX)
From UNIX you can use the arp command to assign the IP address to the network interface card.
Perform the following procedure:
1. Turn off the print controller and the main body printer.
2. Log in as superuser on a host on the same subnet as the network interface card. However, if
the server resides on another subnet, complete this procedure to store the IP address in the
3. Find the MAC address of the network interface card. The address is printed on the Status Page
each time you turn on the print controller and the main body printer.
4. Edit the hosts file (usually /etc/hosts) or use NIS or DIS to add IP address and node name of
the network interface card. See the network administrator for the IP address. For example, a
network interface card with a name of printfast and an IP address of 192.9.200.200 has the
entry:
192.9.200.200 printfast
5. Add an entry to the arp cache for IP address and Mac address of the network interface card,
as:
arp -s 192.9.200.200 0:40:c8:0:0:ff
RS6000 (AIX) requires the ether option after arp -s. For example:
arp -s ether 192.9.200.200 0:40:c8:0:0:ff
6. Check the print controller and the main body printer to see that the network interface card is connected
to the network. Turn on the print controller and the main body printer.
7. Send a ping command to the network interface card to verify it is running on the network, as
for example:
ping 192.9.200.200 or ping printfast
The network interface card will not respond to this ping command but it will read its IP address
from the packets.
8. Turn off the print controller and the main body printer and back on again and then send the
ping command again to verify that the network interface card obtained its IP address. A confirmation
message displays as:
192.9.200.200 is alive
9. Remove the entry from the arp cache using the following command. Specify the network
interface card either by its IP address or by its name, for example:
arp -d printfast
Konica Network Interface Card INSTRUCTION MANUAL 2-5
Chapter 2 Setting Up the Network Interface Card
Using MAP
By using MAP (Management Access Program) included the CD-ROM that comes with the network
interface card, you can automatically identify the network interface card on the network and set it up
for TCP/IP by using Web Utilities. To use this method to assign the IP address to the network interface
card, the following procedure should be performed on computers in advance:
• TCP/IP correctly configured
• IPX/SPX-compatible protocol installed
• MAP installed and MAP setup correctly executed
About how to set up TCP/IP and how to install IPX/SPX-compatible protocol, refer to Windows Help
menus for example. For MAP, refer to “Using MAP (Management Access Program)” in this chapter.
To change an IP address already assigned to a network interface card, you can not use the
arp command. Use Web Utilities instead. These methods also allow you to set up subnet
mask and default gateway, etc.
Using NIManage
Refer to “Chapter 7 AppleTalk Configuration”.
 Accessing Web Utilities
The network interface card is provided with an HTTP server having Web Utilities. By accessing this server,
you can change settings of the printing system. There are two ways to access Web Utilities, through a Web
Browser, either through Netscape Navigator, version 4.x or greater or through Internet Explorer, version 4.x
or greater.
• Use MAP to have the network interface card on the networks identified automatically, thereby accessing
Web Utilities.
• Use a Web Browser to type the IP address assigned to the network interface card, and thereby access
the Web Utilities. For example:
http://192.168.0.128/
If you designate the proxy setting in your Web Browser you cannot access the Web Utilities.
For more information see your network adminisrator.
2-6 Konica Network Interface Card INSTRUCTION MANUAL
A utility called MAP is provided on the CD-ROM that comes with the network interface card.
This program automatically identifies the network interface cards on the networks and lists them on Web
Browser screen. From this Web Browser list you can select a network interface card to change its settings
and control Web Utilities.
Aug 31, 2009 | Konica Minolta Office Equipment & Supplies
Canon IR3300 would not scan when use the
give the same class ip address to your printe and computer and install ms office soft ware, and then microsoft tools click that we find the microsoft document scanning create shortcut to the desktop.
ping the printer for computer
run the network scan gear and click on the ip, enter the ip address in the blocks and then the discover.
then scan the document for the ir 3300 scanner.
Apr 15, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Network printer problem
Check all this--------------
1>check the printer proper driver.
2>check the printer port configuration.
3>Replace the usb cable(no need but can try)
4>check the printer permission of the pronter with share option
5>check the printer services.
6>check the printer port(If you can)
I think all this help you.
Mar 12, 2008 | Office Equipment & Supplies
Windows2003 server networking problem
if the pc mother board came with a driver, install network driver/speed.make sure your network card are working very well and you can fastening the speed of the modem before querying it
Jan 31, 2008 | Microsoft Windows Server Standard 2003 for...
KM-3035 scanning issues
the 30/40/5035 series machines have two network cards in them. One for printing and one for scanning. and they have separate IP numbers also. make sure you have scanfile utility running on your pc or wherever you are sending the files and the folder set up in the utility. then set it up on the scanner network card.. Not the printer.
Oct 15, 2007 | Kyocera Mita KM-3035 All-In-One Laser...
Computers & Internet Logo
975 people viewed this question
Top Canon Computers & Internet Experts
Computer Links
Tony
old marine
old marine
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
