Question about Electric Strider Midi 4 Wheel Mobility Scooter - Midnight Blue
Parts for strider scooter
Need throttle pot part #34010
3 Suggested Answers
  • 346 Answers
SOURCE: my strider scooter is failing the speed goes up
Hello,please rate my answer as in thumbs up 1 to 4.
Visit:WWW,ALLDATASHEET.COM Download as a PDF File to save to an Adobe Reader.Try this 1 :troubleshooting_2007 SHOPRIDER.pdf.its 36 pages long,but 18 pages are what im almost sure you will need,it starts with batteries & then onto scooters.pages 19 to 36 are all about the wheelchair.im sure you will be happy with the info in it.& as i did for my scooter print & save it in a polythene sleeve folder for future.Have a nice day,Colin.
Posted on Oct 08, 2010
SOURCE: Electric Strider Maxi 4 Wheel
yes ring ausmedic on 1800245169 they will help
Posted on Dec 02, 2010
I have an error code of 7 Flashes = drive lever not central, but it is.
hi, the lever maybe but is the actual throttle pot stem ? look a the screw slot located a the end of the pot stem ? bet you it's slightly to the left or right ...
Regards
Rob
www.gewizrepairs.co.uk
Mar 10, 2015 | Electric Strider Midi 4 Wheel Mobility...
Why when mobility scooter not moving when engaged but when disengaged moving slightly
The unit is not made for "medical approved" market and does not have a POST (Power On Self Test) to confirm wig-wag (throttle) is in neutral when it first turns on. SOLUTION: Put the scooter up on blocks so the drive wheels are off the ground. With the SPEED KNOB turned fully clockwise, adjust the wig-wag (throttle) so the cart will not run and the brake is engaged when the cart is in neutral. There are usually Allen screws in the wig-wag handle that can be loosened and re-tightened once the wig-wag pot is properly centered for neutral.
Aug 09, 2014 | Electric Strider Maxi 4 Wheel Mobility...
Scooter goes in reverse on switch on
hi ,that sounds like the throttle pot is no centre, some controllers will signal a fault some don't so it's possible the throttle pot stem has turned round, check by looking at the base of the stem , you should see a cross head, now that should be dead centre to you when turning on...
Regards
Rob
And please join me on Facebook https://www.facebook.com/gewizrepairs
Apr 23, 2014 | Electric Strider Mini 4 Wheel Mobility...
Erratic throttle control
The speed pot and throttle pots do wear in time. These parts are readily available and are not too difficult to change. A service manual can be downloaded from the mnufacturer's website. It has detailed instructions and part numbers.
Feb 16, 2014 | Pride Sonic 3 Wheel Portable Scooter
Days Strider Midi 4 Plus faults
HOW DO GET THE REAR WHEEL OFF MY SCOOTER NUT VERY TIGHT
Jul 10, 2012 | Electric Mobility Mobility Electric Power...
Hi my days strider midi4 keeps going in reverse for about 4 seconds after you take the throttle off
spares sounds like the throttle pot is not being centered upon release making the scooter move in reverse or forward depending on which way it is off center. try pushing on the thottle lever slowly forward when you stop to see if that stops the creeping. Then you can try to adjust the pot by loosening the lever and retightening it in the forward direction that stops the creeping. You might have to order a new throttle pot assembly to get this working right. Hope this helps
Nov 18, 2010 | Electric Strider Midi 4 Wheel Mobility...
Maxi strider scooter
Hi
Are you sure it 's the cable ? and not the wig wam or throttle speed pot that you operate with your thrumbs.
Regards
GeWiz.
May 03, 2009 | Electric Strider Maxi 4 Wheel Mobility...
Electric Strider Midi 4 Wheel Mobility Scooter - Midnight Blue Logo
37 people viewed this question
Top Electric Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you an Electric Health and Beauty Expert? Answer questions, earn points and help others
