Question about Vizio VO420E 42 in. LCD TV
WHAT ARE THE SIZE BOLTS I NEED FOR MY VIZIO VO42OE BASE MOUNTING BRACKET
3 Suggested Answers
  • 81 Answers
SOURCE: what size of mounting bolts do I need for mi visio
You can find your mounting bolt size on the Vizio website by searching for your specific model number. I pulled up an example to show you where you can find the information. This is NOT guaranteed to be your model, so do not buy these screws unless you own this model TV.
http://www.vizio.com/vo420e.html
If you click on Tech Specs, then scroll to the bottom of the screen and you will find a table labeled Wall Mount Specifications. This should give you the measurements for all the screws you need.
Posted on Jul 18, 2011
  • 11 Answers
SOURCE: the vizio remote nor the comcast remote will turn up/down the volume or power the tv on or off
The comcast codes will give u a list to try just start going down them but not all of the codes are compatable
Posted on Sep 13, 2012
Is there a special bracket to mount the 50 inch D series vizio to the wall?
Many aftermarket mounting brackets are virtually universal in application provided your 50-inch Vizio TV can meet the size and weight limitations stated.
Nov 29, 2014 | Vizio VP504F 50-inch 1080P Plasma TV...
What size are the table top mounting bolts for a philips 47pfl3603d/f7 tv?
The size of the mounting bolds are M8x ...., where .... = 12mm inside the TV and xxx mm outside depending of the thickness of the bracket. 30bd4761-3c8f-44f5-b84e-adf07806dc82.jpg
Jun 02, 2014 | Philips 47PFL7403D 47 in. LCD TV
I want to fix my lg tv to a bracket but I don't know what screw/ bolts i can use and fix the bracket to the back of the tv thanks.
the screws are philips round head type fine thread u will need to go to a tv bracket dealer shop specify the size of the tv and u will be sold the bracket which comes with the standard screws for mounting
Jul 11, 2013 | Televison & Video
Vizio E470VL - What is screw size for mounting stand?
I don't know if the screws would be different depending on the tv model, but on a Vizio Model E470VLE 47" LCD HDTV, the screws for the base are M4 x 30ST.
May 21, 2012 | Vizio Televison & Video
Missing screws for detachable stand for vizio e370 va
Try to contact (says your set is Vizio here) the company who made it...Also try to GOOGLE MODEL NUMBER OF SET WITH "MOUNTING BOLTS"
Mar 24, 2012 | Vizio E370VA 37 1080p 60Hz LCD HDTV
How to change a crank position sensor on 2006 suzuki forenza
5) Install the rear A/C mountingbracket. Tighten the rear A/C mounting bracket bolts to 35 Nm (26lb-ft).6) Install the A/C compressor. 7) Install the power steering pump. 8) Connect the negative battery cable.12_16_2011_6_00_05_pm.jpg
If this helps, please say so! Thanks! :-)
Dec 08, 2011 | 2006 Suzuki Forenza
What size of mounting bolts do I need for mi visio
Jul 18, 2011 | Vizio 42 in. LCD TV
I need to konw the size of the two bolts which bolt the right rear brake caliper bracket to the backing plate on a 2003 chevrolet silverado
What size are the bolts? Did you break them? Your local part store will have have caliper mounting bolts that can be purchased.
May 28, 2011 | 2003 Chevrolet Silverado 1500
What size bolts do i need in order to mount it under the cabinet. the bolt that comes from the cabinet into the micro
mcdevito75 here, Best Bet bring the mounting bracket and bolts recieved with the unit to your local hardware store. they will give you the correct bolts need to mount undera cabinet.
Jun 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Replace alternator
This is for both size engines since you didn't list the motor size......
REMOVAL & INSTALLATION 2.0L Engine
  1. Disconnect the negative battery cable.
  2. Remove air intake resonators.
  3. Remove the air cleaner-to-throttle body tube and the mass airflow sensor.
  4. Unplug the connectors and remove the cables from the alternator.
  5. Raise and support the vehicle.
  6. Release the drive belt tensioner and remove the drive belt from around the alternator. NOTE: It is not necessary to remove the drive belt from the engine.
  7. Remove the alternator mounting bracket bolts and remove the mounting bracket.
  8. Lower the vehicle.
  9. Remove the power steering pressure hose bracket retaining nut and bolt and remove the bracket with the hose from the engine lifting eye.
  10. Remove the alternator mounting bolts and remove the alternator from the vehicle. To install:
  11. Place the alternator into position and install the mounting bolts finger tight.
  12. Install the power steering hose bracket and tighten the retaining nut and bolt to 70–106 inch lbs. (8–12 Nm).
  13. Raise and support the vehicle.
  14. Install the alternator mounting bracket and retaining bolts and tighten to 15–22 ft. lbs. (20–30 Nm).
  15. Release the drive belt tensioner and install the drive belt pulley over the alternator pulley.
  16. Lower the vehicle.
  17. Tighten the alternator mounting bolts to 15–22 ft. lbs. (20–30 Nm).
  18. Install the alternator connectors and the cables. Tighten the terminal nut to 80–97 inch lbs. (9–11 Nm).
  19. Install the air cleaner-to-throttle body tube, mass airflow sensor, and the air intake resonators.
  20. Connect the negative battery cable.
Apr 01, 2009 | 1999 Mercury Mystique
Vizio VO420E 42 in. LCD TV Logo
70 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
