Question about Emerson TC2556D TV
Emerson TC2556D I have an Emerson TC2556D that will shut off at times. It will remain off for anywhere from 2 to 20 minutes before turning back on. I can try and turn it on with the remote and manual but it seems to have a mind of its own and will remain off for some time.
  • Rodger Campbell Jun 01, 2007
    Thank you. We will give it a try.
  • Anonymous Apr 28, 2008
    AFTER WATCHING THE TV , IT JUST SHUT OFF, IT WON;T TURN BACK ON , EVEN THOUGH YOU CAN HEAR THE POWER ON FOR JUST A MOMENT/
  • 934 Answers
Doesn't sound like there's any pattern on this shutdown??? I'd suspect poor solder connections first. Might look at R447 and R448 located in the right front corner of the PCB. They are both 2.7k/2w resistors that get quite hot during normal operation. This heat can cause ring cracking and thus the symptoms you're describing here. Don't limit your search there. If you find either or both of these ring cracked take the time to inspect the rest of the board with great attention to detail in the higher thermal areas of the board.
Posted on Jun 01, 2007
My flatscreen Emerson tv keeps muting from time to time,most days it works fine but on some days it starts acting up again. What should i do?
Try unplugging it for a couple minutes and plug it back in, this will reset the tv's computer board. Make sure you turn it off before you unplug it.
Jan 01, 2016 | Emerson 32 Inch LED HDTV
How do I get my emerson microwave to turn off after the timer is finished?
There are a couple of microwave ovens out there where after it has finished cooking, the light and fan continue to run until you open the door. Then the fans shuts off, but the light remains on. When you close the door, then the light shuts off. If the light and fan go back on when you close the door, then you have a bad door switch.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Oct 20, 2014 | Emerson Microwave Ovens
TAKES 45 MINUTES TO COME ON
Evidently there is an internal power supply problem.
Nov 12, 2013 | Televison & Video
Emerson lc320em9 wont stay on, why?
I would suspect an issue with the power supply board, maybe even puffed up filter caps on that board---that is the place to begin.
May 16, 2012 | Emerson LC320EM9 32 in. LCD HDTV
We have lost the remote control and need a replacement
If you type emerson TC2556D into the search bar on your browser, several options will come up. lloks like you can get a new remote for $9.95-$19.95 for that model.
Jan 11, 2011 | Emerson TC2556D TV
My car wont start
sounds like security shut down which will start run for second then shut down after several time the security will shut down completely.......you can try what is called the relearn proceedure..this is what you dealer will do...might have to put battery charger on car first... then put key in ignition and turn to the run position do not crank leave it in the on position for ten minutes...... then turn key to the off position then back to the run position again for another ten minutes.....for the last time turn key off then back to run for the last ten minute cycle.... after the final ten minutes is up turn key to off position then attempt to start... let me know
Aug 31, 2009 | 1997 Chevrolet Cavalier
My mother just bought an Emerson MW8119 Microwave and can't figure out how to only set say 15 seconds cook time. Is it possible?
Hi! I just purchased the same microwave, and came online to find the solution. I was then able to find the correct answer to this problem. On this model, Emerson does not put a "time cook" button for odd cook times such as 15 seconds. Instead, they have you push the "Power Button" prior to setting the cook time.
If you want to cook on full power, press the power button once, and then enter your cooking time and press start. If you want to cook on 50% power or 30% power or something like that, push the "Power Button" several times until the appropriate power level is displayed, then enter the cook time and press start.
The reason that it starts up right away when *********** pushes the 1 button is because Emerson has the quick cooking feature for 1 minute through 6 minutes. You only have to push the number once to get the 1 minute cook time or anywhere through 6 minutes respectively.
Hope this helps!
Jun 22, 2009 | Emerson Microwave Ovens
Television not getting all of the channels
I hate to tell you this but you cannot add channels without an original replacement remote, and that costs about 40 bucks here http://www.remotes.com/remotes/servlet/rs?a=gmi&smodel=TC2556D&brand_pn=EMERSON_TC2556D&mode=large&uid=11743431409220 This remote if you notice has an add, delete,and the auto buttons. A universal will not have these functions on it. Good Luck.
Mar 19, 2007 | Emerson TC2556D TV
Televison & Video Logo
64 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
