Question about RCA Televison & Video
My RCA 55LA55RS LCD TV will not power up... it has a clicking sound as if it's trying to start, but just clicks off. The Screen has no light emulating from it... but I do hear the cable program au
It stops the clicking noise only when it is unplugged from the wall. sky@wdsd.com
SOURCE: Vizio 42" 1080p HDTV LCD.
This is likely due to heat expansion (turned on) and contraction (turned off).
Posted on Nov 26, 2007
Coldcut
  • 1554 Answers
SOURCE: LG 47" LCD TV - 47LC7DF Clicking Noise
the old saying is that any issues will likely show up in the 1st 3 days if you run it for 72 hrs. if it dosent fail then it will last.
other than going to the show room and seeing if their unit does the same.
they will likely want to send a service guy to check it out and decide for himself.
Posted on Feb 25, 2008
I was told that these clicking noises (which happen on my Magnavox LCD too) were due to the "power required" at the internal switch. Seems that the power required to immediately turn on the TV is too much for a standalone household outlet, so it "surges" power in a series to get enough there. Hence, the clicking sounds are actually mini power surges to send more power to the internal circuits to turn the TV on.
If your set is like mine, these noises generally stop after a minute or two, correct?
Posted on Mar 29, 2008
SOURCE: 50" philips won't power on. get the 4x red blink led light
Well, I did get it fixed yesterday - thru no help of your site - but if you would like to know how I did it ,just email me back & I will send you my address so you can send me check for my fee!! It is rediculous that I must pay for a plan for someone to answer a question these days. I assure you I will pass this site onto my many friends who have these type of problems and reccomend the do not visit much less PAY for a service they can get for FREE other places on the web.
Posted on Jan 11, 2009
SOURCE: Plasma Hyundai 42'' TV ,NO SOUND OR PICTURE
most times then not it's the capacitors on your power board that blew there for not supplying the tv with enough power if you open it up and check the capacitors it should be leaking some kind of liquid or the tops have bubbled up. its an easy fix cost>>2 dollars each
Posted on Jun 01, 2009
Proscan tv flickering
I'm sorry that the picture on the TV has constant flickering. Please follow the troubleshooting steps and check the operation:
  • Please make sure that the connections are secure and proper.
  • Try connecting a different video source like DVD player or VCR and check the operation. If it works with another device, the issue might be with the input device currently.
  • Also try connecting the device to a different port in the TV if no other devices are available.
  • If the issue persists, try with a different cable.
  • Perform a power resetting and check the operation. To perform the power resetting, unplug the TV from wall outlet for more than 2 minutes and then reconnect it.
Thanks for understanding. Please let me know if you require any clarifications/additional help.
Oct 18, 2011 | Proscan 42LA45H 42 in. LCD TV
I have a RCA 32" Flat Screen TV that shut off and
The sound was came from the clicking of the relay. This kind of symptoms is an indication of out-of-regulation condition on the power supply section. This is caused by faulty electrolytic capacitor. It will dropped the supply voltage and will trigger that kind of symptoms.
Faulty electrolytic capacitor mostly has a physical indication of fault like bulged/dome at the top and can be easily identified. See sample picture of faulty electrolytic capacitor below.
capacitor with bulged/dome at the top.
Check these parts on the power supply section. Once found, replaced it with same capacitance and working voltage which is printed on its body itself. Click this LINK for more info regarding electrolytic capacitor.
If you don't have necessary tools and test instrument and can't troubleshoot the unit yourself, I would advice you to look for a qualified TV Technician to isolate the faulty parts.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Aug 05, 2011 | RCA L32HD31 32 in. LCD HDTV
I have a 52 RCA flat screen that the sound works but the pic doesn't. I can hear a clicking sound and then the power button light starts flashing
This RCA projection tv model have known to have many parts of capacitors components are dying and dead on the tv power supply board.That the board section where the tv power a/c cord plug into it.U have all the tools and can do bsaic soldering work too?Yes,try website like Tvrepairworld.com to buy the capacitors compponents set they put together and replaced all these capacitors parts on the tv power supply board section,will solved this problems.
Jul 06, 2011 | RCA HD52W56 52" Rear Projection HDTV
RCA L37WD12 out of control
Ur Tuner board have problems,just not dead yet.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.The Tuner board main IC have intermitten short,that why take out A/C power input work for awhile,and than back to the same problems.
Apr 22, 2010 | RCA L37WD12 37 in. LCD HDTV
Rca L32hd31 lcd no picture blank screen.
Your mainboard is damaged, replace it and that will solve your issue.
Jun 06, 2009 | RCA L32HD31 32 in. LCD HDTV
RCA 32 in TV no picture no sound just a beeping noise TV power is on
the tv has one part of the power supply working this is needed to have the microcontroller ready to work. But the tv needs more than that for work im talking 'bout the high voltage power supply who is now damaged. the parts required depends on the diagnosis in the bench but at least two are needed. the cost of this repair of course depends in how many parts are going to be replaced, but i concider this repair kind of average in this technology.
Apr 13, 2009 | RCA 32V524T TV
Loud clicking noise and nothing on screen
Maybe your TV is shutting off the power due to a shorted out backlight bulb.
Nov 17, 2008 | RCA L26W11 26 in. HD-Ready LCD Television
Dec 13, 2007 | LG 47LC7DF 47 in. LCD HDTV
Televison & Video Logo
140 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
