Question about Whirlpool Calypso GVW9959K Top Load Washer
Calypso washer won't spin and drain properly
I have a Kenmore Elite Calypso washing machine that has stopped and makes a humming noise when I try to get it to spin to finish the load or even try to re start the load as a new one. It's not pumping the water from the final spin. and not reaching a full spinning motion when I try to just use the extended spin option. I have made sure there isn't a kink in the hose and taken some of the wet towels out to make sure it wasn't too large a load..I understand there was a class action law suit on the model I own. I have had no problems up until now. It is 6 years old model # 110.2206
I have a similar problem. My Calypso won't go through a whole cycle. After cleaning up much water from a fast leak and completely emptying the water from the washer the machine seems to be leaking from somewhere on the back side near the top and spilling down. There is some type of long,tube-shaped clear plastic (almost like a a ziplock bag material) that is hanging from the possible source of the leak and when I try to cycle the machine through a rinse and spin cycle suds are emmited through and around the plastic tube. I want to take the hoses off to try to try to see if there is some type of clog but I am worried that more water will spill out as the machine appears to have much water down in the holding tank below(there is also more water in washer since I have attempted more partial cycles.) I believe this water needs to be emptied before I can run a successful cycle on the machine but there seems to be no way to get it out. PLEASE HELP!!!!
Posted on Jan 06, 2009
  • 311 Answers
I've pulled stuf from many a calypso pump and its not the funest pump to clean.some designs never get stuff in the pump others its like theres a sock magnet in there or somthing.your has got a sock magnet.take off the frount and you will see the pump on the right.white,it has two hoses.take the inlet off first if eazyest then will only have to take one can geter done.God bless,tom
Posted on Jan 03, 2009
  • 15935 Answers
SOURCE: Where is the reset switch located on the Calypso
There is no reset.
Simply unplug for 40 minutes to reset the ECU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
  • 1028 Answers
SOURCE: calypso washing machine (top loader)
ck the gray seal along moving plate in bottom they sometimes develop gaps and will catch fabrics and pull threads out
Posted on Jul 05, 2008
  • 487 Answers
SOURCE: Whirlpool Calypso GVW9959K Cleaning Solution
just in the soap dispenser as soon as it starts filling.
Posted on May 01, 2008
  • 72 Answers
SOURCE: I have a kenmore elite auto washer w/ calypso
the pump motor asm is bad about stripping gear off old style or ther could be something in pump stuck
Posted on Nov 17, 2009
  • 15935 Answers
SOURCE: Problem for Whirlpool Calypso GVW9959K Top Load
The C1 error is displayed when the motor tries to pull more than 26 amps to run.
This indicates a problem with the motor or motor controller.
Overloading or excessive suds can also cause this error.
If you like to make a few more checks then the image below contains the instructions for entering the diagnostic test mode.
Its a short cycle that runs all of the components so the operation of each can be checked.
I hope this helps but an intermittent C1 error can be hard to pin down.,wbrrkqqwkwbqsdgxgtqsskgwtqkq,vi/kdkftbfkwxkfsqdgqsg/1/1303472/5961857/image5668img-or.jpg
From the service manual....
"C1 = Average current limit Or Instantaneous current limit.
If a status signal comes back from the motor controller that a current
limit has been breached, the unit will return to standby mode and
display either CA for average current limit trip or Cl for
instantaneous current limit trip.
Average current trip occurs if there is a 2 second average of current
draw greater than 5.55 amps
at the motor windings.
Instantaneous current trip occurs if there is a spike of 26 amps
instantly at the motor windings.
This may signify problems with the drive motor, thermal protector, or
motor controller. Over-loading the unit may cause this problem."
Posted on Sep 23, 2010
Both the coupler and the lid switch have been replaced yet unless you lift and close the lid it won't engage the spin cycle
Search Results
    Why am I getting an FL error code on a Kenmore Calypso ... > Manage My Life > Questions
    I have a Kenmore Calypso washer model 11022062100 and there is water in ... Why am I getting an FL error code on a Kenmore Calypso washing Machine?
    fl error code on calypso washer-need help!! - Home > Home Forums > Laundry RoomJul 22, 2006 - An FL error code keeps flashing on my Calypso Washing Machine. I can't do laundry. Could someone please tell me what I need to do to ..."F dl" light come on - Kenmore Elite HE3 Washing Machine are the errors for error code F/dL Door Lock Error Condition A Door Lock Error... The Kenmore Elite HE3 is a washing machine by Kenmore. ... On Amazon I was able to get the CCU (Kenmore CCU Central Control Unit .... and a dose of WD40 on those contacts should keep that from misbehaving in the future as well.Kenmore Elite Calypso FL error code - ApplianceBlog
Jan 27, 2016 | Washing Machines
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
What is the model number of your unit?
When does it make the noise? Spin cycle, wash cycle?
Dec 02, 2012 | Kenmore Washing Machines
Water pump out??
The washer filled with too much water, causing a switch to trip. Then everything stops. It tries to drain during FL but if it can't drain, the washer powers down.Choose Drain & Spin to let the washer drain. Then you have to take the washer apart. Fix the problem. I personally can't tell you what to do because I don't own a Calypso.
Bad Pump
High Water Flow
Other Causes
Jul 30, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Plastic in drum
Nov 25, 2008 | Kenmore Elite 45986 Front Load Washer
Washplate problem Kenmore Elite Calypso washer
Hello genny2626
You said,your 6 year old Kenmore elite top loader's wash plate doesn't seem to go through its proper motions. When the lid is closed and the washer has filled and the agitating cycle begins, you can hear a vibrating noise as if the plate is trying to move on the gentle cycle, but when the lid is opened, nothing has moved at all. The drain and spin work fine, and the machine goes through an entire cycle without error messages, but the clothes aren't clean. You said, you have heard a lot of horror stories of how expensive these washers are to repair, so would like an idea of what's wrong beforehand.
Here are a list of common vibration noises
Noisy, vibrating, off-balance
 Is the washer level? Does the washer rock when pushed
against the corners?
The washer must be level. The front and rear feet must be in
firm contact with the floor. Check that the locknuts are
tightened. See “Level the Washer.”
 Is the floor flexing, sagging or not level?
Flooring that flexes or is uneven can contribute to noise and
vibration of the washer. A ³⁄₄" (1.9 cm) piece of plywood under
the washer will reduce the sounds. See “Location
 Is the load balanced?
Evenly distribute the load in the washer basket and make
sure the height of the load does not exceed the top row of
basket holes. See “Starting Your Washer.”
 Do you hear clicking or other noises when the cycle
changes from washing to draining or spinning?
When the drive system shifts or the washer basket settles
between cycles you may hear noises that are different from
your previous washer. These are normal washer noises.
 Is the washer gurgling or humming?
Is the washer level? The wash load
should be balanced and not overloaded. The washer must be
level. The front feet should be properly installed and the nuts
tightened. Reset the rear leveling legs (if needed). See the
Installation Instructions.
Did you completely remove the yellow shipping strap with
cotter pins? See the Installation Instructions.
• Are the gears engaging after the drain and before spin, or
is the upper part of agitator clicking during wash? These
Let me know if any of these are the solution!
Oct 13, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite Calypso Washer
I'm in the process of tearing apart my Calypso, Ugh. I found the diagnostic chart inside the machine. 5L is actually 'SL' which means suds lock, and can be an indicator of a failed pump, an extra heavy load, excessive detergent, or excessive suds. Corrective action is to press Stop/Cancel to clear the display.
Mar 26, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washer kenmore elite calypso 21086
promblem with the lid switch is it happing durning the drain spin cycle
Jan 20, 2008 | Kenmore Elite 21086
Whirlpool Calypso GVW9959K Top Load Washer Logo
863 people viewed this question
Dan Webster
Dan Webster
Sal De
