Question about Indesit W 123 Front Load Washer
Indesit 1600 WE165 washing machine - filling with water after wash
After wash cycle has been completed and clothes emptied, the drum fills with some water within a couple of hours. I can't find the manual and am told that problem may be to do with filter and that it may need cleaning. If this is the cause, I am not sure how I go about removing the panel at the bottom edge of the machine. Please advise if you have a suggestion as to the possible cause and a remedy for. Many thanks in advance. Marion
  • 247 Answers
Doesn't sound like a filter problem to be honest. If the water that's coming in is clean, you're probably looking at a leaky inlet valve. With the machine unplugged from the mains, remove the top, then look for the valves (which are the items that the inlet hoses screw into). One at a time, remove the rubber hoses that connect them to the various bits of the insides of the machine to identify which valve is leaking. New valves are available quite cheaply on the net, and are easy to install. If the machine is filling up with dirty water, it's probably being siphoned back in from the drain. The drain hose mustn't be a tight fit in the standpipe it hooks into and mustn't poke in too far. Also, the standpipe needs to be reasonably tall. Have a look at page 7 of http://imagebank.indesitcompany.co.uk/pdf/service/HBWM81.pdf - it's a manual for a different model, but the drainage requirements will be the same. A.
Posted on May 13, 2007
SOURCE:
Indesit wie 147
I think you have to fill it with water first. My machine won't work unless the previous cycle has a chance to complete. i.e., it has to fill with water before the wash cycle starts, or it has to have water before it rinses/spins dry.
Mar 14, 2014 | Washing Machines
Bosch washing machine fills with water throughout any cycle
Just a guess but could the fill valve be defective, not shutting off completely when it should?
Nov 21, 2013 | Bosch Washing Machines
Indesit WIXL85 water level
On a normal wash cycle, you will see very little if any water sloshing around, this is quite normal on todays washers.
You shuold see a lot more on the rinse cycle, as it is a higher fill.
It is usual to more less fill the compartment with powder, unless you are only washing a few items, then half fill it.
Hope this helps.
Dec 19, 2009 | Indesit W 123 Front Load Washer
Moffatt washer is washing and draining but not spinning out the clothes
All content © 2000 © 2009 Washerhelp
> Home / Repairs DIY washing machine advice (part 8) Washing machine sticks or stops mid-cycle repairs-sm.gif A very common fault on washing machines is when the program timer fails to complete the cycle and stops part way through. Many people blame the program timer for this but although it is a possible cause, there are many more likely causes for this fault. The program will stick if the heater isn't working, if the thermostat fails, if it can't fill up with cold water for the rinses, if it can't empty the water etc. There are too many possible causes of this fault to be able to give anything other than rudimentary advice. However, the common causes of a washing machine sticking that can easily be fixed are filling and emptying problems.
Check that the cold water supply is available to the washing machine, which is a common cause for sticking on rinses. If the washing machine appears to stop mid-cycle and isn't filling with water on rinses then see Washing machine won't fill with water (or no water goes into washing machine) before calling an engineer. If the washing machine can't drain the water out then it will stick on the rinses, or it will abort with an error code. If you can see water still inside the washing machine then check the following advice Washing machine won't empty water
Dec 03, 2009 | Washing Machines
My Indesit WE165 fills up with water
there is a little hose that runs from the back of the pump
up to a pressure switch that contols water level in drum
I had a problem similar to this and found hose had split making
the drum overfill, replaced hose cured problem
Apr 19, 2009 | Indesit W 123 Front Load Washer
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Washing machine WK61420GB drum does not turn
replace the brushes in the motor ( approx £5 parts)
Dec 30, 2008 | Siemens WK61420GB Front Load Washer /...
Drum filling with dirty water
hi as your machine got a non return valve on it to stop water from getting into your machine via waste pipe. worst case is call indesit as i am sure you now get 5 years parts g/tee as indesit is now part of hotpoint still cheaper than another machine hope this helps
Jul 11, 2008 | Indesit W 123 Front Load Washer
Smartdrive 703 Model Washing Machine Leaving brown stains in clothing after some wash cycles. Stains are small and seem to be something coming through to the clothess from the slits in the drum holes. ...
if you do cold washs all the time you get a build up of sludge between the drums you need to fill it with hot water and let it soak for a few hours and then put through a high wash to rinse out,no clothes.Or you can remove the drum and wash it .hope this helps
Mar 14, 2008 | Washing Machines
Indesit W 123 Front Load Washer Logo
616 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
