Question about Xerox Phaser 6121MFP/N Multifunction Laser Printer
Code 0092 xerox phaser 6121
Error 0092 cinghia trassferimento
  • 2072 Answers
SOURCE: Xerox Phaser 8500 Error Code:
That is a problem with the movement of the print head. There are 2 main causes of that.
1, On the left side, looking from the front, about 3/4s of the way back on the lower frame there is a 1 inch by 1 inch stainless steel print head block, There can be ink spilled over into it causint the print head not to tilt forward and back properly. That block can be removed and cleaned pretty easily. There is a spring assambly just hooked over it and that needs to come off, and you may need a pair or channel lock pliers if the block is really full of ink. Clean that block and remove as much excess as you can.
2, The Print head wiper blade may be tacked to the print head, This would occur if the machine was powered down improperly or there was a power failure.That would require removing both side covers and the ink loader, Where you insert the ink sticks. Once there you access the print head area, the blade would be between the print head and the drum.
That is the 2 most likely causes of that prpblem
Posted on Sep 03, 2008
  • 2072 Answers
SOURCE: xerox printer error code (04,025.46)
This is a print head position issue.
TRY FIRST (Solutions without parts):
1. Check that the wipe mechanism has homed. 2. Check the printhead position and verify that it has initialized properly / manually home the printhead and power cycle the printers power and check for the error to return. If not then the error was most likely due to non-process function (something out of sequence).
Part likely to be the cause:
GEARBOX AND MOTOR,PROCESS DRIVE - PL 4.0, Item 14.
Posted on Jan 21, 2008
  • 2072 Answers
SOURCE: i have xerox phaser 8560MFP error cod 07,010.43:14059
there is a stainless steel print head block on the lower back portion of the frame that gets contaminated with spill over ink from the catch tray. That causes the print head not to move properly.
The wiper blade may also be tacked to the print head.
That code means the print head is not moving into the print position properly.
That stainless steel block is about 1 inch square.
Posted on Mar 11, 2009
  • 526 Answers
SOURCE: Phaser 8560 error code
Most likely you are using generic ink or ink not made for that specific machine. The black ink is the one causing the problem. the printer will then need to be reset.
Posted on Apr 15, 2009
  • 7 Answers
SOURCE: error code 09.036.44:38950
09,03x 35 = Cyan 36 = Magenta 37 = Yellow 38 = Black The error indicates an ink stick was jammed. You have to clear the ISC (ink stick count) error. Turn off the printer. Turn on the printer. As soon as you see XEROX start moving across the display hold down the back and help buttons until you see "beginning service mode" on the display. Release the buttons, it will now come up in the service mode. Scroll down to the function menu, hit ok, scoll to clear isc faault, hit ok. Hit the back button to get back to the first menu then exit diagnostics, hit ok when it asks if you want to restart in customer mode.
Posted on Jun 10, 2009
ALL I WANT IS THE CODES FOR A CITIZEN TVS
TV Cineral 0092, 0451 TV Citizen 0060, 0039, 0280, 0030, 0056, 0046, 0092, 0186 TV Clairtone 0185
Apr 22, 2016 | Televison & Video
Tip
XEROX PHASER 7750 7760 FAN ERROR.
Hey guys this is a Xerox Phaser 7750 and 7760 fan error video tutorial.
In this video you will learn how to fix the error code 48 on the Xerox phaser 7750.
Also you will learn how to fix the error codes 010-391,010-392,010-398 that are related to the Xerox Phaser 7760.
This video shows how to remove covers.
All the wires that you need to disconnect from the machine to fix these errors.
There is also another video part two that shows you how to reinstall everything back
in it’s place. Step by step tutorial hope you enjoy.
http://www.youtube.com/watch?v=yMud-Md2xpc
on Dec 30, 2009 | Office Equipment & Supplies
How to fix fuse failure code 0500 phaser 6121 Xerox
0500 is a fuser failure error. Need to replace fuser.
http://www.iteminconline.com/126e02770_126e02770-xerox-6121mfp-fuser-110v-new.htm
Nov 15, 2015 | Xerox Office Equipment & Supplies
Xerox 6121 mfp jam at fuser
if it's in warranty engineer. Otherwise check at the back if there's any paper in the fuser, or a sensor in the wrong position. (Fuser get's warm.. for recognition)
Nov 25, 2013 | Xerox Phaser 6121 MFP/D laser toner
How to reset toner chip on Xerox Phaser 6121 mfp printer?
You would have to replace the chip, there is no reset for it. Plus you would need to refill the cartridge with more toner as well.
Sep 04, 2013 | Xerox Phaser 3100MFP/S Laser Printer
Erreur service 0092
hello,
I have problem with my epson sx16 (error 0092).
what possibiliti I have for repar this engine.
Thak you and Have a goog day
John
Feb 10, 2013 | Epson ACULASER CX16
One for all universal remote codes for Model # URC-4081B00 TV brand Panasonic
I obtained this information from "http://tv.manualsonline.com/manuals/mfg/one_for_all/urc_4081.html?idRes=16985".
Programming information for other devicescan be found there.
Ron
ONE FOR ALL Universal Remote - URC-4081B00
PROGRAMMING TV CONTROL
(The brands are listed in alphabetical order below.)
To program TV control:
1. Turn on the TV.
2. On the remote control, press TV once. Press and hold SET until the LED blinks twice, then release SET.
NOTE: The remote control will exit programming if more than 10 seconds elapse between key presses.
3. Enter the first four-digit code for your TV. If you perform this procedure correctly, the LED will blink twice.
NOTE: If the LED emits a long blink, the code is invalid. Repeat steps 2 through 3 and try entering the same code again.
4. Aim the remote control at your TV and press POWER once.The TV should turn off. If it does not respond, repeat steps 2-3, trying each code for your brand until you find one that works. If it still does not work, try searching for the code (see Searching For Your Code on page 23).
5. Write your TV code in the boxes below for future reference.
NOTE: Remember, to use the One For All 4-Device Video Expert remote control to operate your TV, press TV first.
Setup Codes for TVs:
A
AOC 0030, 0019, 0052
Admiral 0093, 0463
Aiko 0092
Akai 0030
Alaron 0179
Ambassador 0177
America Action 0180
Ampro 0751
Anam 0180
Audiovox 0451, 0180, 0092, 0623
B
Baysonic 0180
Belcor 0019
Bell & Howell 0154
Bradford 0180
Brockwood 0019
Broksonic 0236, 0463
C
CXC 0180
Candle 0030, 0056
Carnivale 0030
Carver 0054
Celebrity 0000
Cineral 0451, 0092
Citizen 0060, 0030, 0056, 0039, 0092
Concerto 0056
Contec 0180
Craig 0180
Crosley 0054
Crown 0180, 0039
Curtis Mathes 0047, 0054, 0154, 0051, 0451, 0093, 0060, 0030, 0145, 0056,
0039, 0166, 0466, 1147, 1347
D
Daewoo 0451, 0019, 0039, 0092, 0623, 0624
Daytron 0019
Denon 0145
Dumont 0017,0019
Dwin 0720, 0774
E
Electroband 0000
Emerson 0154, 0236, 0463, 0180, 0178, 0019, 0179, 0039, 0177, 0623,
0624
Envision 0030
F
Fisher 0154
Fujitsu 0179, 0683
Funai 0180,0179, 0171
Futuretech 0180
G
GE 0047, 0051, 0451, 0093, 0178, 0135, 1147, 1347
Gibralter 0017, 0030, 0019
GoldStar 0030, 0178, 0019, 0056
Gradiente 0053,0056
Grunpy 0180, 0179
H
Hallmark 0178
Harley Davidson 0179
Harman/Kardon 0054
Harvard 0180
Hitachi 0145, 0056, 0151
I
Infinity 0054
Inteq 0017
J
JBL 0054
JCB 0000
JVC 0053
K
KEC 0180
KTV 0180, 0030, 0039
Kaypani 0052
Kenwood 0030, 0019
L
LG 0056
LXI 0047, 0054, 0154, 0156, 0178
Luxman 0056
M
MGA 0150, 0030, 0178, 0019
MTC 0060, 0030, 0019, 0056
Magnavox 0054, 0030, 0179, 1254
Marantz 0054, 0030
Matsushita 0250
Megatron 0178, 0145
Memorex 0154, 0250, 0463, 0150, 0178, 0056
Midland 0047, 0017, 0051, 0039, 0135
Mitsubishi 0093, 0150, 0178, 0019
Motorola 0093
Multitech 0180
N
NAD 0156, 0178, 0166
NEC 0030,0019, 0056
NTC 0092
Nikko 0030,0178, 0092
O
Onwa 0180
Optimus 0154, 0250, 0166
Optonica 0093, 0165
Orion 0236, 0463, 0179
P
Panasonic 0051, 0250
Penney 0047, 0156, 0051, 0060, 0030, 0178, 0019, 0056, 0039, 0135,
1347
Philco 0054, 0463, 0030, 0145, 0019
Philips 0054
Pilot 0030,0019, 0039
Pioneer 0166
Portland 0019, 0039, 0092
Prism 0051
Proscan 0047
Proton 0178, 0031, 0052, 0466
Pulsar 0017, 0019
Q
Quasar 0051, 0250, 0165
RCA 0047,0051, 0093, 0019, 0090, 0135, 1047, 1147, 1247, 1347,
1447
R
Radio Shack 0047, 0154, 0165, 0180, 0030, 0178, 0019, 0056,0039
Realistic 0154, 0165, 0180, 0030, 0178, 0019, 0056, 0039
Runco 0017, 0030
S
SSS 0180, 0019
Sampo 0030, 0039, 0052
Samsung 0060, 0030, 0178, 0019, 0056
Samsux 0039
Sansei 0451
Sansui 0463
Sanyo 0154
Scimitsu 0019
Scotch 0178
Scott 0236, 0180, 0178, 0019, 0179
Sears 0047, 0054, 0154, 0156, 0178, 0179, 0056, 0171
Semivox 0180
Semp 0156
Sharp 0093, 0165, 0039
Shogun 0019
Sony 0000
Soundesign 0180, 0178, 0179
Squareview 0171
Starlite 0180
Supreme 0000
Sylvania 0054, 0030
Symphonic 0171
T
TMK 0178, 0056, 0177
Tandy 0093
Technics 0051, 0250
Technol Ace 0179
Techwood 0051, 0056
Teknika 0054, 0180, 0150, 0060, 0019, 0179, 0056, 0039, 0092
Telefunken 0056
Tera 0031
Toshiba 0154, 0156, 0060, 1256
Totevision 0039
V
Vector Research 0030
Victor 0053
Vidikron 0054
Vidtech 0178, 0019
W
Wards 0054, 0165, 0030, 0178, 0019, 0179, 0056
White Westinghouse 0463, 0623, 0624
Y
Yamaha 0030, 0019
Z
Zenith 0017, 0463, 0092, 0624
May 16, 2012 | One For All Televison & Video
Need Manual for Beldray 0092 12 stitch sewing machine
try these sites you'll probably have to email about a manual
sewvacdoctor.com
a1sewingmachines.com
Apr 22, 2012 | Sewing Machines
Xerox Phaser 6121MFP/N Multifunction Laser Printer Logo
678 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
