Question about Maxtor Computers & Internet
How much gb has a maxtor n256 model 90841u2 got ?
Code fa520860 jumper j50 cylinders 16383 heads 16 sectors 63 s/n g215m6sc
2 Suggested Answers
mewms_14904
  • 1027 Answers
SOURCE: I would like the diagram to switch an old hdd16.9g from master to slave
If by the diagram you mean jumper settings try this web site, if your drive is not there check the product index page.
http://support.seagate.com/rightnow/images/maxtor_quantum%20jumpers.htm
Posted on Mar 02, 2008
Just transfered hard drive to another computer - in setup- need to know capacity, cylinders, heads, sectors
The specs are:
Capacity (unformatted/formatted):
20.00 GB / 15.02 GB
Cylinders: 16,383
Heads: 16
Sectors: 63
Here is a PDF w/specs
Fireball lct15
(http://www.dll.com.mx/biblioteca/HDD/Quantum/Fireball%20LCT15.pdf)
Hope this helps!
Sep 11, 2009 | Quantum Fireball Lct15 (QML20000LC-A) 20...
Installing old maxtor HD on newr pc, have to change it to a slave
J50 is the one furthest from the power connector. To make it a slave remove ALL of the jumpers.
Jul 26, 2009 | Maxtor Hard Drive
Dell optiplex gx110 733mhz won't recognise another hard drive
this time external hard disk drive to you Dell... this Dell optimized for only that 10GB drive..
Jun 17, 2009 | Computers & Internet
Paramet cyl = ? head=? sect = ? of QML30000LD-A
Written on the FireballPlus AS label it says
C/H/S: 16383/16/63 = 16514064
( averages out to 1817 bytes/sector )
LBA's: 58633344
( x 512bytes/Blk = 30,020,272,130Bytes )
Dec 06, 2008 | Quantum Fireball Lct20 (QML30000LD-A) 30...
I need to replace the hard drive in my Toshiba
The ATA-5 Specification barrier According to the ATA specification, any drive over 7.88GB (8.46 billion Bytes) is supposed to report its "geometry" as 16383/16/63 (C/H/S). Which enables old software to access the first 7.84 to 7.88GB of such a drive, using CHS addressing and the BIOS Int 13h system call. And while a P-CHS over 16383/16/63 can be used to access all the drive capacity-- up to the ATA-5 128GB limit-- that is not the recommended way to do so. Rather, LBA addressing should be used to access those larger capacity drives. (Or at least any partition that goes over the 7.88GB BIOS Int 13h CHS barrier.)
So, LBA uses a 28 bit binary number to specify the sector number on a drive. Thus:
228 = 268435455 Sectors
268435455 Sectors x 512 Bytes/Sector = 137438952960 Bytes
Resulting in the 128GB (137.4 billion Bytes) ATA-5 size limit.
Nov 20, 2008 | Toshiba Satellite 1905-S301 Notebook
Hi i have a 10.1gb Maxtor model 31024H1 IDE hard drive and i need the jumper setting for slave
slave is NO jumpers at all
(Master) - The vertical jumper over the J50 pins is configuring the drive as a Master. The horizontal jumper over the J48 and J46 pins is in the Storage position.
(Master with CLJ) - The vertical jumper over the J50 pins is configuring the drive as a Master. The vertical jumper over the J46 pins is in the Cylinder Limitation position (CLJ).
(Slave) - No jumper is required to configure the drive as a Slave. The jumpers over the J48, J46, J44 and J42 positions are both in the storage position.
(Slave with CLJ) - The jumper over the J44 and J42 positions is in the storage position. The jumper over the J46 pins is in the Cylinder Limitation position (CLJ).
(Cable Select) - The jumper over the J48 position is configuring the drive for Cable Select. The jumper over the J44 and J42 pins is in the storage position.
(Cable Select with CLJ) - The jumper over the J48 position is configuring the drive for Cable Select. The jumper over the J46 pins is in the Cylinder Limitation position (CLJ).
Oct 13, 2008 | Computers & Internet
Mar 02, 2008 | Maxtor Hard Drive
Quantium 10.2 gb fireball CX10A011 specs. ie sectors, mode, etc.
The specifications to enter the information manually, are on top of the harddrive. Kind of hard to discern, huh? That's because harddrive sizes from 6.4GB through 20.4GB are listed on top.
C/H/S = Cylinders/Heads/Sectors
The Quantum Fireball CX10A011 hardrive is a 10.2GB harddrive.
You will see -> C/H/S....10.2 - 16383/16/63 on top.
That is ,
16,383 Cylinders
16 Heads
63 Sectors
As for the 40GB model, it should be similar. If not, come back and post.
Jan 22, 2008 | Quantum 13Gb FIREBALL CX 3.5" IDE HD p/n...
Computers & Internet Logo
66 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
