JVC HD52-z575 issue
Hello.
I have a JVC HD52-z575 TV. The power indicator and LED lights blink rapidly simultaneously. The lamp is realtively new and I just replaced the ballast. When I replaced the ballast the TV came on with no issue. The following night when I turned the TV on the lights started blinking again.
I noticed when I turn the TV on and look in the venting area behind the TV the lamp lights and after about 3-5 seconds it goes out. It does this 3 times before the lights on the front start blinking. Does anyone have any idea on what the problem might be?
SOURCE: Weird Rapid Metallic Popping Sound
I think i have the same problem, but i can get audio still. did the poping plinking sound come from the inside back panel of your TV? it sounded almost like a arc wielding noise?
Posted on Dec 01, 2007
yalmer
  • 552 Answers
SOURCE: JVC HD-ILA Projection TV
From the manual...
The POWER LED
and LAMP LED are
blinking
alternately.
• It may be a malfunction that the fan is locked or the temperature has increased.
The POWER LED
and LAMP LED are
blinking rapidly
simultaneously.
• The lamp may not have been installed correctly, or it may be due to a malfunction.
• The lamp door may not be closed correctly.
The LAMP LED
continues blinking
• It may be a malfunction of the internal electrical circuits
Posted on Feb 16, 2008
  • 1039 Answers
SOURCE: power led and lamp/program led blink stimultaneously. even after unpluging and let tv cool, still no picture
Check lamp.
Posted on Apr 25, 2009
fieldy14
  • 456 Answers
SOURCE: rapid blinking light (lamp) on a JVC model HD
It normally means the lamp is in need of being replaced, and its all depending on the use of the TV as well as how long the lamp life is. You should be able to access the lamp via a small section near the rear or the back of the TV unit, if the lamp is blown or faulty it will look the same as a blown light globe.
To obtain a new lamp contact the brands authorised repair agent as they will be able to get trade prices and in turn, give you the best price,
Also make sure that whoever replaces the lamp resets the lamp use time as the TV will still not start if you don't reset the lamp use time as it will still think it has a faulty lamp. I hope this helps, good luck.
Posted on Dec 05, 2009
  • 12 Answers
SOURCE: the power led and lamp program led are binlking
Your lamp is burned out, order a new one for your tv model and follow the instuctions that the bulb has and you can do it yourself, dont get conned into thinking it is more technical than it is by the repairmen on this site
Posted on Feb 08, 2010
Power led and lamp led blink simultaneously on my jvc hd65s998 rear projection tv
You might need to replace your lamp driver, or ballast as some call it. This is what strikes the lamp to make it light.
Mar 20, 2013 | JVC Televison & Video
I just replace the bulb in my JVC HD-52Z575 everything was fine for about 10 days. Now when I turn the TV on it works for about 30 to 45 min before it shuts off, the fan kicks in, and the LED power light...
Ballast Board? it is what Powers Lamp, or CK Lamp Fan if it stops running and is not Keeping Lamp Cool
set is designed to shut off to Protect lamp from being burted up, you could have either Bad Ballast Board or Defective Lamp Fan,there is a few test you can do to see which Part is Bad.
Jan 25, 2010 | JVC HD-52Z575 52" Rear Projection...
Power light and red led light blinking rapidly and simultaneously
This could be easy or hard first i would check the lamp inside this unit and if it looks cloudy,burnt,or has a bulged in the middle peice of the lamp which looks like a stem then i would suggest replacing that lamp, and if that is the issue go to the main menu after the lamp was replaced and working and look for reset lamp timer hit enter .Now if that is not the issue then you could have a problem with the audio IC which is more likely or the power supply.
Jan 18, 2010 | JVC HD-61Z456 Television
The power led and lamp program led are binlking rapidly simultaneously
Dec 03, 2009 | JVC HD-70FH96 70" Rear Projection HDTV
Please help!!! Problem with JVC DLP TV
You need to replace the power supply board. The new ones have a bigger heat sink - obviously JVC knows about the problem because they made the new ones bigger. It cost $250 from JVC and I installed it myself - took about 3 hours to do. If you are not tech savvy call a repairman. Hope this helps.
Feb 03, 2009 | JVC HD-52G786 52" Rear Projection HDTV
How old is your TV?
Lamps in DLP TV has specific working hours and physically lamp will look good but won't give light ( actually consume more current and protection circuit stops power supply)
Thank you.
Dec 04, 2008 | JVC HD-52G786 52" Rear Projection HDTV
Hello i have a JVC model # HD56G786 DLP TV. The problem i have is that the set will not turn on. Whe i try to boot the set up it starts as normal as the blue power light stays on and the small red...
I would agree with you on that the power board could be at fault. The best course of action would be to get the board/TV checked out professionally. It could be the dry joints, resistors or capacitors.
Dec 04, 2008 | Televison & Video
From the manual...
The POWER LED
and LAMP LED are
blinking
alternately.
The POWER LED
and LAMP LED are
blinking rapidly
simultaneously.
The LAMP LED
continues blinking
Feb 16, 2008 | Televison & Video
The power LED and LMAP LED are blinking rapidly simultaneously
Will you will have to replace it now because this is the most likely cause for the blinking lights. Look in the instruction book for the directions on how to remove the lamp. You will find that it has burned out. It is easy to replace. You can order one from JVC or a service center, or a parts distributor.
Dec 03, 2007 | JVC HD-52Z575 52" Rear Projection...
Televison & Video Logo
73 people viewed this question
Top Televison & Video Experts
