Mx 750 error code b200
Meaning of error code b200
cns assoc
  • 677 Answers
SOURCE: does not print error b200
Helo, found on web. Good Luck :0)
The error code is standard for many of the late model MPxxx printers. The B200 error is "Printhead Temperature exceeded", What this means that while you were printing some document, either one or more of the printhead ink wells ran out of ink and the printing continued. Printhing without ink in the wells will OVERHEAT THE PRINTHEAD NOZZLES and can potentially burn the out. The printer has a built in temperature sensor to detect the ambient temperature and to monitor the temperature of the head. This data is always collected and monitored and saved in the EEprom data and the Service Test print data.
If the error will not go away once you have unplugged the priner for at least 5 minutes, then there is the possibility that you have already burnt out the head. Remove the printhead and use a 5x magnification glass to look VERY CLOSE at all of the nozzles to see if you can detect any possible burnt out nozzle.
It many come down to need a new printhead.
HERE IS THE LINK, IF YOU HAVE PROBLEMS.
http://www.fixyourownprinter.com/forums/laser/13864
Posted on Nov 07, 2009
  • 37 Answers
SOURCE: Error Code B200
Try keeping the paper only in the bottom tray (there's a tray in the bottom) Try pulling any paper out of the top and just close that top tray. Open up the head so that u can see the ink cartridges and turn the printer on and off and maybe it will center itself again. If it's still not working (even if lights aren't red and print head wont align in the center) try manually moving the head back and forth like 18 times so you can lubricate that rail in the back that's holding it. After that, re-turn it off and on again.
Posted on Aug 02, 2010
  • 37 Answers
SOURCE: canon pixma MP480 printer error code B200. What is B200?
upbeatjunk
  • 231 Answers
SOURCE: canon pixma MX 340 error
One of our FixYa experts has already addressed this issue. You can find the solution here:
http://www.fixya.com/support/t1257840-error_code_b200
I hope this helps! If this did help you, please give a thumbs up!
Posted on Jun 28, 2011
reyjoshua07
  • 1157 Answers
SOURCE: MX 850 b200 error. Started
Hi sakima,
This error code indicates a Voltage High Error of the Canon printer. The service manual write this, the internal temperature exceeded the specified value.
- Print head
- Carriage unit
- Logic board
Solutions:
1. Try using a different power outlet and see if that works and if that doesn't work try cleaning the print head:
2. Open the printer and wait for the carriage to slide over. If for some reason it does not follow these instructions:
* Unplug the printer
* Manually slide the carriage over until you can get the ink cartridges out.
3. Remove the ink cartridges from the print head.
4. Use cotton swabs dipped in hot water or a mix of hot water and alcohol to thoroughly clean the print head.
5. Repeat this until there is no ink residue coming off on the cotton swab
6. Allow to dry and replace the cartridges
7. Try to print something
If it doesn't fix the error then you need to replace the print head, 90% the print head is the problem. If the problem persist then the board inside of the printer is faulty and you will have to replace it.
Hope it helps.
Thank you for using FixYa.
Posted on Aug 31, 2011
Error b200. How can I fix this?
Hi, that eror means the print head is defective and need to be replaced
Sep 08, 2016 | Canon PIXMA MX892 multifunction printer
Mx-b200 error code f2
Replace the drum/toner cartridge with OEM not third party
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Aug 05, 2014 | Sharp MX-B201D Copier Machine
What is the solution to error code f2 sharp mx-b200
oem cartridge not third party
Aug 05, 2014 | Sharp Mx-b200d Digital Multifunction Copy,...
Canon mg5250 -error code B200
B200 usually means that the printhead has failed. It's a generic "overtemperature detected" error that indicates that the thermal sensors inside the printhead have detected heating to the point where the printhead has probably failed. In a well-intentioned attempt to prevent further damage, the printer has shut itself off; however, by the time this occurs, the printhead is usually destroyed. The following video shows a likely next step: http://www.youtube.com/watch?v=I9uBEOMCd44
Jun 05, 2013 | Microsoft Windows 7 Ultimate for PC
Canon pixma MX 340 error code : " B200 "
Jun 28, 2011 | Office Equipment & Supplies
Does not print error b200
Nov 07, 2009 | Canon PIXMA MP510 All-In-One InkJet...
42 people viewed this question
k24674
jasbo
jasbo
