Question about Polaroid I533P Digital Camera
Lens stuck out, wont turn on
I was taking pictures and it suddenly shut off, so i thought it just needed batteries. i replaced them and then realized the lens is stuck out, the smaller part is inside the bigger part but the big part is stuck out and the lens cover is stuck open. every time i hit the power button the green light comes on, it beeps 3 times, and the screen flashes, but thats it. the lens looks slightly crooked, but i cant seem to get it into place
  • Anonymous Feb 06, 2009
    my camera wont work
    President:
  • 1,197 Answers
if ur very sure that the battery is fully charged... first we would advice you to change the batteries and see ...... if that doesnt work... the battery contacts may be corroded or bent and hence not making correct contact with the battery
.... sometimes there cud be dust or sand particles in the lens retraction passage... blow out air in those places..... this cud help a great deal.... I was able to fix a similar problem by wiggling the outermost part of the lens.as its trying to go in....
also try Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
if that doest help
Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. turn it off, slip in the memory card and turn it on one last time.
if that doesnt help
Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying the above fixes and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
regards
iversh
Posted on Aug 17, 2010
What is wrong with camera that was working fine and suddenly shutter wont shut and is stuck open?
Take it off of bulb it suppossed to stay open on bulb. Set ISO too 100
Set shutter to 1/60th of a sec. And appuatue to 5.6 then take lens cap off and shoot. Goodluck
Jul 11, 2014 | Pentax Cameras
Olympus Stylus 840 - lens won't open
you need to take it or send it for repair. There is nothing you can do yourself.
Olympus Stylus 840 Repair - Google Search
Mar 23, 2017 | Olympus Stylus 840 Digital Camera
Camera Stuck with lens out. Beeps
I dropped the camera on the table a couple of times, twisted the front of it. Suddenly the lens retracted into the camera, the beeping quit, and now I can take pictures again. The Samsung website is horrible.
Jun 03, 2009 | Samsung Digimax S630 Digital Camera
Goes off after lens come out.
Get it repaired under warranty. Sounds like a logic circuit problem.
Dec 10, 2008 | Pentax Optio S50 Digital Camera
Camera doesn't turn on and zoom screen got stuck because camera shut off!
MY CAMERA IS HAVING TROUBLE TURNING ON. THE OTHER DAY I TOOK A PICTURE AND IT SHUT OFF IN THE MIDDLE OF IT WITH THE ZOOM LENS OUT. NOW WHEN I PRESS POWER IT SAYS RETRY POWER ON OR IT WONT DO ANYTHING AT ALL. THE BATTERY IS CHARGED ALSO BUT NOW I CANT USE IT AT ALL
HELP!!!!
WHAT DO I DO!!!
STACY
Jul 21, 2008 | Casio Exilim EX-S500 Digital Camera
Sanyo vpc-503
well if lense stuck in your neighborhood there should be a camera store you should take it in and have your cam. serviced for a clean
the other thing could be memmory card is full
or the camera is on but just not like the light or focus check all above
hope this helped
May 07, 2008 | Sanyo VPC-S500 Digital Camera
My lens is stuck open
goto http://www.digitalcamrepair.com/self_diagnosis_page.htm
for self diagnosis.please let me help you before leaving a bad feed back.
Try
Apr 20, 2008 | Kodak EasyShare V1003 Digital Camera
Power wont stay on
replace ur rechargable battarys. and take new 2100m amps
Feb 07, 2008 | HP Photosmart E317 Digital Camera
Camera turns on and then turns off.
It seems the camera has a lens problem. Probably one of the lens gear is broken or defective. When you try to shoot the lens moves to focus and jams in the middle of the focus so shutter will not release becasue it is not focused yet. There are couple of gears in the gear chain of the lens and it is plastic. the volume of pictures you took might have caused one of the gear to wear down. The solution is to rebuild or replace lens assy. and the cost may be around $100 in US.
Mar 20, 2007 | Fuji FinePix A330 Digital Camera
Polaroid I533P Digital Camera Logo
132 people viewed this question
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
