Question about GE Profile PDW8000G Built-in Dishwasher
Water will not drain
We just installed the dishwasher and some of the water stayed and will not drain out. Its just stagnant. HOw can I fix this problem Thank You.
  • 247 Answers
Two possibilities if you're seeing something like this with a new machine: Something wrong with the way you've plumbed it in, or somthing wrong with the machine itself. If you don't provide some way for air to enter the house drain (just downstream of where the dishwasher hose goes into it), you are likely to get dirty water siphoning back into the machine after it has finished. The way to identify this is to open the door the instant you hear the drain pump stop at the end of the cycle. If the machine appears empty at first, but refills with dirty water over the next few seconds, then you've got it plumbed in wrong. If it stays full from the outset, it's much more likely to be a fault with the machine (which is best sorted out for free by the person who sold it to you). A.
Posted on May 13, 2007
I own a DMR57LFS and it will not shut off and will not drain. The water inside is now stagnant and horrible smelling. Is there instructions on how to remove the lower arm and assembly so that I can...
I would suggest you try starting a cycle on the dishwasher, then activating the Cancel and Drain option by pressing the Heavy and Delicate buttons simultaneously for 3 seconds.
Aug 04, 2011 | Samsung DMR57LF Builtin Dishwasher
Odd odor coming out of dishwasher upon opening it. Smells like rotten milk. What is the best cleaning solution?
After a dishwasher is installed the hose rarely comes to mind - unless a problem occurs and a repair person comes out to inspect the job. If the hose was installed improperly, or if it is lying in a position that does not let it drain, stagnant water will create a bad smell. Examine the hose that is probably inside the kitchen cabinet beneath the sink. If the hose is lying in the bottom of the cabinet, it is probably full of water. A film begins to form inside the hose and the odor begins to grow. The next time the dishwasher is used, the stagnant water ends up on dishes, and in the meantime it can cause a bad smell inside of the dishwasher. Hang the hose at an angle on supports in the back of the cabinet. This alone might get rid of the bad smell inside the dishwasher.
Check the Seal
A dirty dishwasher seal can be a source of a bad smell. Before deciding the dishwasher needs to be replaced, check the seal - especially at the bottom. Old food and grime builds up in these areas and can cause a particularly bad smell. Clean it with a solution of diluted bleach and hot soapy water. One teaspoon of bleach for each quart of water is sufficient to kill germs and the odors they create.
NB I decided to add a little bit of vinegar to the machine after I unloaded it. Sure it would smell pretty strong for a while but then the smell would dissipate. Voila! For two weeks now my dishes have not smelled whatsoever.
Jun 23, 2011 | Maytag MDB6709AW Builtin Dishwasher
My dishwasher is filling with water, but the the arms are not spinning. It will drain. The cycles in between the fill and drain are stagnant. I just purchased it this summer.
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried in vainto clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if the heating element goesbad then that also can mess things up bad... So I would buy new spray arms, and also check out theheating element to make sure it is working... Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Sep 19, 2010 | Amana ADB1600AWS Builtin Dishwasher
Drain water smells, dishes dont get clean
at home depot they sell a product called affresh it cleans the inside of your dishwasher from stagnant water smells also check around the area of your chopper sometimes as chopper gets dulled food can build up in that area they also sell an affresh type for washermachines this is a great product for both types of units
Apr 30, 2010 | Kenmore 24 in. 15079 Built-in Dishwasher
When I don't run my dishwasher, somehow water gets inside and gets stagnant.
Check the drain hose where it connects under the sink. The hose must have a high loop that is the hose should be mounted higher than where it connects to the drain. There is a video at www.appliancehelponline.com/servicemaual.html on installing a dishwasher this will show you proper drain hose installation. If your hose does have the proper high loop the drain is probally somewhat clogged and backing into the dishwasher the high loop usually prevents this.
Mar 23, 2010 | Kenmore Dishwashers
GE Dishwasher that will not advance cycles
sounds like inlet valve is not opening or water has been turned off or kinked.
Sep 14, 2009 | GE Dishwashers
We installed an LG dishwasher (LDF6920ST) a couple months ago. It has a horrible odor (stagnant water). Everything is hooked up according to the installation instructions. Draining problem? There is no...
Check that the drain hose end (connected to a garbage disposal?) is not plugged or connected to a slow/plugged drain.
Then run an empty load and start up the dishwasher and wait until the water has finished flowing in. Then open the door and add one cup of vinegar. Allow that cycle to drain and repeat one more time, adding the vinegar _after_ the rinse water has finished being added.
If problems return, use a phillips screwdriver to remove the approximately 9 screws that hold the lower strainer assembly. You will first need to remove the lower spray arm. Inspect with a flashlight looking for any debris in that sump area.
Aug 03, 2009 | LG LDF6920ST Stainless Steel 24 in....
Smells of stagnant water
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=2349
Had the solution for me and LG doesn't stink anymore.
Aug 23, 2008 | Dishwashers
Bosch Exxcel dishwasher "check light" indicator
**** out the water with a shop vac. Consult manual for self diagnosing keypad codes.
Jun 08, 2008 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
GE Profile PDW8000G Built-in Dishwasher Logo
134 people viewed this question
Top GE Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Steve Allison
Steve Allison
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
