Question about Hampton Technologies Brinks Timer
How to program brinks surge protected timer, 44-1075, strip
Bought a Brinks Digital Timer, 44-1075, Strip with 4 timed outlets. However, there were no instructions included with the product. Therefore, I must have a copy of the instructions for this type of Digital Timer to properly utilize this product.
5 Suggested Answers
SOURCE: I lost my instruction manual
1) Contact Hamptonproducts.com
2) Some Brinks manuals are posted on following link:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Brinks
Posted on Apr 14, 2011
SOURCE: How do i set the Brinks 44-1040 timer?
Brinks 44-1040 is a 24-hour plug-in timer, with 1 on tripper and 1 off tripper.
Dial has 24 hours with each hour marked for am and pm times.
Push tripper down and rotate until tripper aligns with time you want for ON and OFF.
Rotate dial until current time lines up with arrowhead located on inner dial.
Turn lamp ON. Make sure bulb is good.
Plug lamp into timer. and plug timer into wall.
Move slide switch one direction or the other to control mode.
When switch is one direction, lamp in ON all the time.
Move switch other direction, and timer programs work.
Dial rotates as time passes, and trippers move on-off lever that turns lamp ON-and-OFF.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Jan 27, 2011
SOURCE: my brinks 44-1020 digital timer
1) I posted Brinks 44-1020 manual
http://waterheatertimer.org/pdf/Brinks-44-1020-manual.pdf
Folks can order Brinks manuals from hamptonproducts.com
2) Manual shows phone number for defects 800-562-5625
3) I test timers, and some arrive defective, and people occasionally tell fixya they got 3 bad timers in a row. I tell them buy different model: for example buy quality timers at Lowes and Home Depot
4) Timer manuals have more words than allowed for free answer, but I suggest you write out steps shown in manual. Most timers have same basic steps so once you know how one timer works, all other timers work same way. This will eliminate human error as possible cause.
5) Here is a list of common problems with timers:
If plug-in timer doesn't work
a) Check receptacle for power
b) Check lamp is turned ON
c) Check bulb is good.
d) Check tabs or pins are set
e) Check override switch pushed fully in position
f) Try timer in different plug and with different lamp
g) Test circuit with inexpensive circuit analyzer from hardware
h) Don't exceed maximum wattage
i) Programmable: check for overlapping programs, and conflicting days.
j) Programmable: write out programming steps
k) Outdoor with photo cell > test with black tape over photo eye
l) Turn photo eye away from light source
Posted on Feb 14, 2011
SOURCE: Need how to use my timer. Brinks digital plug in
Manual appears on following links:
The manual has important illustrations, and has more words than allowed for free answer.
Open manual and get as far along as you can, and then add a comment where manual is confusing and I will help.
The battery is rechargeable type, so plug timer into outlet for hour and then unplug timer to set programming.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Posted on Mar 02, 2011
Brinks model 42-1050 manual?
Brinks timers and manuals: - Water Heater Timer
waterheatertimer.org/Brinks-timers-and-manuals.html
Brinks timers and manuals. ... Brinks 44-1020 manual · Brinks 42-1020 manual ·Brinks 42-1020 instructions ... 42-1050 yard stake · Invisa timer 52-9206 · Brinks ...
I need an instructions guide for Brinks timer 42-1050 - Fixya
www.fixya.com/.../t10900275-need_instructions_guide_brinks_timer_4...
Nov 28, 2011 - SOURCE: Brinks model 44-1050 digital outlet timer- I don't. I have an instruction for a Brinks 44-1030 which I believe programs the same.
Brinks-outdoor analog stake timer-42-1050 Timer will not ...
Dec 14, 2015 | Hardware & Accessories
Timer programs disappear on my Brinks Digital Timer 44-1041. I believe home power failures are the cause but I'm not sure.
Look at electrical rating of timer to make sure it matches the air conditioner.
Often an air conditioner is too heavy a load for ordinary programmable timer... even if timer is rated for inductive load,,, because motor pulls a lot of initial amps that eventually overheat timers.
-Suggest buying another or the same timer, and using intermediate relay ... like a solid state relay... or miniature relay... and so the timer turns on the relay, and the relay handles the high amp switching ... and this means the timer lasts longer
http://waterheatertimer.org/H230A.html#solid
-Or buy 17 program CN series timer, and use relay or contactor
http://waterheatertimer.org/Programmable.html#PB
-Or buy several of the Brinks timers and replace when they go bad.
-Also consider surge protection... because simple power outage will blow out electronic circuit boards. Check household grounding also.
http://waterheatertimer.org/How-to-wire-Whole-house-surge-protector.html
Gene
Water Heater Timers Save Money
Jul 06, 2015 | Hardware & Accessories
Is there a manual for brinks 44 1040?
1) Possible instructions, are same as 44-1030, except 44-1040 has two outlets and 44-1030 has 2 outlets:
http://waterheatertimer.org/pdf/Brinks-44-1030-manual.pdf
2) Add a comment and clearly describe timer buttons and I will find manual that will work for Brinks 44-1040 timer 6-event daily timer
3) This timer is rated for resistive loads such as incandescent bulb and does not appear rated for LED or CFL inductive loads
Dec 24, 2012 | Hardware & Accessories
How do I program my brinks plug in timer 42-1025?
On the 42-1025 timer face, turn the dial so the correct time is lined up with the arrow. Pull tabs up when you want the timer off, leave tabs down when you want the timer on. You can have multiple on-off cycles. In the attached photo the current time is 10am, and the timer is set to come on at 4:30am and go off at 7:30pm.
Nov 24, 2012 | Hampton Technologies Brinks Timer
Progaming brinks timer 44-1073
Timer is not identified:
Check options below
1) Add a comment and describe timer in detail, and include photo of timer posted on Flickr for possible identification.
2) Contact Hampton Products.com for possible manual.
Sometimes they respond, and sometimes not.
http://www.hamptonproducts.com/contact-us.php
3) Open following link for Brinks manuals that is updated as new manuals arrive
http://waterheatertimer.org/pdf/Brinks-44-1010-manual.pdf
4) If you are looking for a manual to post on your site, I cannot find one at this moment.
5) If you have instruction sheet and need help programming timer, then add a comment and say what part of instruction is confusing, or take advantage of fixya live help and expert speaks with you over phone while you program timer.
Sep 30, 2011 | Hampton Technologies Brinks Timer
Need how to use my timer. Brinks digital plug in home timer. Model # 44-1020. 6 settings per day. Battery backup
Mar 02, 2011 | Hampton Technologies Brinks Timer
My brinks 44-1020 digital timer was set up right and dose not work. i bought a new one and that one also dont work am i doing something wrong or is there a lil trick to it
Feb 14, 2011 | Hampton Technologies Brinks Timer
Please assist me in setting this light timer. brinks-42-1020
Instructions for Brinks 42-1020
1) There are plastic segments located around outer edge of timer dial.
These segments divide each hour into 15 minute periods.
Push segments down like a piano key for all hours you want timer ON-or-OFF
2) Push switch to Auto ON -or- Timer
3) Turn lamp ON, make sure bulb is working, plug lamp into timer.
4) Plug timer into wall.
Manually rotate timer dial clockwise to observe light turning on-off.
This action will say if light is ON when segments are up or down.
5) Unplug timer, and set segments for times you want lamp to turn on-off.
6) Rotate timer dial clockwise until current time lines up with arrowhead located on inner dial
7) Plug timer back into outlet. Dial rotates as time passes, segments click a switch that turns lamp on-and-off.
Add a comment for more free help, or to further clarify this free answer.
For a price, fixya expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 11, 2011 | Hampton Technologies Brinks Timer
Brinks model 44-1050 digital outlet timer- I don't know how to program it-lost instructions HELP!
I have an instruction for a Brinks 44-1030 which I believe programs the same. If you email me at tedban@gmail.com I will send you a PDF scan of the instruction.
Dec 11, 2009 | TORK Hardware & Accessories
Hampton Technologies Brinks Timer Logo
612 people viewed this question
Top Hampton Technologies Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hampton Technologies Hardware and Accessory Expert? Answer questions, earn points and help others
