Question about Funai F4819T 19" TV
Tv comes on then shuts off
I recently moved my apartment around. There was work being done to it. The television worked fine as I was living temporarily in another apartment. I moved back into my original space and now it shuts off after being turned on. This is frustrating me. What is the real cause of this?
  • 32 Answers
The television is going into high voltage shut-down. Best guess, either a faulty voltage regulator, bad cap, or both. Be careful when working inside a television due to high voltages that are present even when television has been off and unplugged for days. Good luck.
Posted on May 31, 2007
I have a 50ml6200 magnavox. I have changed the bulb twice and tv had worked fine. Recently had our floors done and had to move tv out to shed for a couple of days. Brought tv in worked fine. Needed to move...
the tv got dust when placed out say u need to clean the inside of the light engine, the lamp too but be careful u must use only methylated spirit with a new soft dry bristle brush caution if u touch the lamp with your hands u will shorten its life. the color wheel inside the light engine needs to be cleaned the same way too make sure u do not spill any thing in the components and of course the tv must be off nand left to dry before restarting
Jul 08, 2013 | Televison & Video
Trouble code: Standby LED blinks 9 times
You will need to replace the G board on this tv to fix the problem
Aug 13, 2008 | Sony KP-51WS510 51" Rear Projection...
No Audio!!!
check the speaker maybe its busted
Oct 11, 2008 | Disney 13" TV
Taking it apart to move
not a good idea but they are bulky it can be done i have done just take your time and put blankets around it
Sep 16, 2008 | Sony KP-53HS10 TV
Hcn4226w samsung
The most common problem with all 3 tube rear projectors is a damaged convergence circuit. The Samsung TVs are easier to repair than many others and the numbers that break down is not excessive. For every Samsung with a convergence problem there are a large number that did not breakdown. The fault is caused by bumps or noise in the AC power, not the TV design. This usually produces colored outlines around heads, etc.
Check out the Convergence Gallery. If you see the colored outlines or color shading as in the Gallery, you have a convergence problem.
This requires the replacement of the defective IC or ICs and any damaged or smoked resistors. Usually there is little alignment required after the repair. If you play with all the adjustments before the fix, hours may be spent re-aligning.
Don't monkey with it.
This is a delicate and difficult repair. If not done by someone with some electronic repair experience, the TV will likely end up as junk or cost considerably more for a tech to fix the damage done.
If you live in Calgary, call me. If elsewhere, find a competent tech.
easyab
Aug 04, 2008 | Samsung HCN4226W 42" Rear Projection...
Broadcast Channels not picked up
Go into the add/delete channels and add them then program the setbagain.
Jul 10, 2008 | Philips 51PW9303 51" Rear Projection...
Tv shutting off on its own.
Was talking to one of the experts on the "chat live now" tab and he suspects a power supply problem. Who knows??
May 02, 2008 | Panasonic PT-60DL54 60" Rear Projection...
Insignia LCD 27" w/vertical lines for picture
Happens with mine also usually happens when you change channels alot all you need to do is shut tv off and turn it back on.
Mar 09, 2008 | Insignia LCDTV26 26 in. Television
Zenith 50" R56W36
maybe on your remote press menu and find converence and use the keys to move the red first over the green then move the blue over the yellow ..by standing back and just using the remote....should end up with white lines. and dont hit that button again once set. a tech should do this quickly and charge you minium.
Aug 16, 2007 | Zenith R56W36 56" Rear Projection...
Televison & Video Logo
65 people viewed this question
Top Funai Televison & Video Experts
Demonic-2011
Demonic-2011
Jaime Hernandez
Are you a Funai Televison and Video Expert? Answer questions, earn points and help others
