Question about Cisco 7940 IP Phone
Cisco 7940 stuck in tftp timeout - Cisco 7940 IP Phone
  • 3 Answers
SOURCE: convert CISCO 7940 to SIP
you need different files to upload by tftp
by example version 8
P0S3-08-2-00.sb2
P0S3-08-2-00.sbn
P0S3-08-2-00.bin
P0S3-08-2-00.loads
OS79XX.TXT (tells the version)
SIPDefault.cnf
Posted on Aug 26, 2008
ward_knutson
  • 64 Answers
SOURCE: Converting Cisco 7940 IP Phone to SIP
Unlocking a Cisco 7940
Method 1:
1) Unplug the phone
2) Plug the phone back in while holding the # key
The phone will soon display “Reset key sequence detected”
3) After several lights flash press the following keys in order:
1 2 3 4 5 6 7 8 9 * 0 #
4) The phone will then ask you if you want to save the network configurations:
Save network cfg? 1=yes 2=no
5) The phone will soon display “Factory reset initiated” and will continue
through the boot up process.
If that process fails to work for some reason there
is a second method.
Method 2
Complete these steps:
  1. Press Settings.
  2. The Network Configuration lock symbol must be unlocked. If not, exit to the main window and press ** # again.
  3. Press 3 on the keypad (or scroll down) for Network Configuration.
  4. Press 33 on the keypad (or scroll down) to Erase Configuration.
  5. Press the Yes softkey.
  6. Press the Save softkey.
The phone will now be reset.
Also see this link
http://www.cisco.com/univercd/cc/td/...tain.htm#93250
Posted on Nov 25, 2008
RPaterson
  • 48 Answers
SOURCE: My Cisco ip Phone 7940
Solution #1 sure is funny, but however the "not-ringing" is a known bug with Cisco 7940 IP Phones. At IdacomUSA, we will gladly and professionally repair and refurbish your phone and get rid of that problem for ya.
http://idacomusa.com
Posted on Feb 18, 2009
RPaterson
  • 48 Answers
SOURCE: 'in call' volume cisco 7940
The handsets will eventually go bad. If it is every single handset that you have, the problem is with the system. But if the problem is only with a few of your phones, you might consider replacing the handsets. We at IdacomUSA.com have replacement Cisco handsets for sale at only $25. Hope this helps you out :)
1-800-903-9190
Posted on May 18, 2009
  • 82 Answers
SOURCE: my red light wont go out on cisco 7940 phone, even
Has this just stopped working, or has it never been working?
On the call manager / CME the MWI (Message Waiting Indicator) needs to be configured. This could be undertaken either via the GUI or from the CLI
For instance ...
ephone-dn 30
number 8000...
mwi on
ephone-dn 31
number 8001...
mwi off
and also mapped to each phone to enable MWI status
ephone-dn 1 dual-line
number 111
label Chris
name fred
call-forward busy 800
call-forward noan 800 timeout 10
huntstop channel
mwi-type visual
Complete config details are at:http://www.ciscosystems.com/en/US/docs/voice_ip_comm/cucme/command/reference/cme_m1ht.html#wp1018439
If this helps pls leave feedback
Posted on Feb 04, 2010
Hi,i wanna use cisco ip phone 7940 as sip ip phone.when i power up the phone ,it can get ip from network,but finally,it shows "TFTP timeout"in display led.All the buttons can not be used.What...
the DHCP server should be providing the address of the TFTP Server as DHCP Option 150. The most likely problems are:
Option 150 not defined, or not the correct IP address of the TFTP Server.
Or possibly your TFTP Server is not functioning properly.
If you have not Option 150 defined, the phone will use the default gateway as the TFTP server address.
Cheers, Simmo99.
Dec 29, 2010 | Cisco 7940 IP Phone
7940G IP Phone: how to solve the protocol application invalid prob...
Hi
This happens when you IP phone communicated with the Voice vlan with the IP address of data vlan.
To solve it manually enter the IP address of the TFTP server and option 150 on the DHCP server.
remove the voice vlan from the switch port and reboot the phone
again add the voice vlan and reload the phones
May 17, 2010 | Cisco 7940G IP Phone
My red light wont go out on cisco 7940 phone, even when i have no messages
For instance ...
ephone-dn 30
number 8000...
mwi on
ephone-dn 31
number 8001...
mwi off
number 111
label Chris
name fred
huntstop channel
mwi-type visual
Feb 04, 2010 | Cisco 7940 IP Phone
I AM TRYING TO SET UP MY VOICE MAIL, BUT EACH TIME I PRESS THE MESSAGES BUTTON, ALL I GET IS A RECORDING WHICH TELLS ME TO CONTACT THE OPERATOR. SO THEN IT TELLS ME THAT THE OPERATOR IS NOT AVAILABLE.
That is because you need to setup the voice mail in Cisco Unity and also setup the phone in the call manager. Unless you have voice-mail setup it states.....Cisco Unity Messaging system....is the beginning of the message.
Aug 07, 2009 | Cisco 7940 IP Phone
My Cisco ip Phone 7940 will not ring.
Give me your number, and i'll call you! Solved! =-D
Jan 27, 2009 | Cisco 7940 IP Phone
Convert CISCO 7940 to SIP
P0S3-08-2-00.sb2
P0S3-08-2-00.sbn
P0S3-08-2-00.bin
P0S3-08-2-00.loads
SIPDefault.cnf
Aug 25, 2008 | Cisco 7940G IP Phone
Upgrade firmware on a cisco ASA 5500 firewall
This is for the pixes, I haven't upgraded an asa yet...should be close or the same
* find latest version of code, these are usually *.bin files located on http://www.cisco.com/cgi-bin/tablebuild.pl/pix
* confirm the flash and RAM requirements of the PIX OS software versus what the PIX has (”sho ver”)
* make sure you have a backup of the old PIX OS and PDM to the tftp server (or at least confirm the software is there)
Note: You cannot back them up from the PIX, so you will need to download them and put them on the tftp server * put in a change control form
* once change controls confirms date/time do the upgrade:
wri mem*** only if you save your configs via tftp wri net conf t ca save all copy tftp://your tftp server ip/pix635.bin flash:imageskip this if you don't use pdm copy tftp://your tftp server ip/pdm-304.bin flash:pdm *** if this is a failover pair, upgrade the other pair reboot
Sep 06, 2007 | Cisco ASA 5500 Firewall
Phone stuck in Configuring IP
Did you check the TFTP settings on the IP phone? You may need to disable DHCP on the phone and assign the TFTP manualy or make sure the correct TFTP server is assigned.
Jan 12, 2007 | Cisco 7940 IP Phone
Open Questions:
See all Cisco 7940 IP Phone Questions
Cisco 7940 IP Phone Logo
1,594 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
brian soufane
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
