Question about Dryers
LITHONIA TH 400M TB HSG light
What wires do i use to hook up to 110 volts
2 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: I need to use a 220 volt battery charger on a 110
Why not just get a meter pole with a 220 outlet installed near your parking space?
Posted on Mar 06, 2010
How to hook up electrical? 220v single phase? What color wires on which connections of the plug?
Identify the prongs. If you have wired a 110-volt fixture or plug, then you are aware that the different prongs connect to different colors of wires. The same principle holds true for 220-volt plugs, and this is very important to keep from tripping the circuit breaker. A three-prong plug will connect to two colored wires that each supply 110 volts and a bare copper wire which is the ground. One of these colored wires will be black, while the other one should be red, white, or blue. The four-prong plugs connect to a black and a red wire that each supply 110 volts, a white neutral wire, and a bare copper ground wire.
Read more : http://www.ehow.com/how_6830969_wire-220_volt-ac-plug.html
How to Wire 220 Volt AC Plug eHow
Dec 16, 2015 | Ovens
How do you disconnect ballast wires from Lithonia Lighting Fluorescent fixture?
The feeder or supply power wires (black and white) are the primary of the ballast or transformer, if we are talking about house wiring. The secondary side of the ballast (usually red, blue and yellow wires) supplies from 600 to 800 volts to the lamps. This makes this job very dangerous. Are you sure you want to do this job? Buy a repacement fluorescent fixture, the cost of the ballast will be about the same as the cost of the fixture.
Aug 29, 2014 | Home
Proper wire hook up
black goes to L1 white goes to L2 make sure to look on side of motor to change from 220 volt to 110 volt either a knob or changing wires brown and white to different locations hope you didnt fry motor
Jul 26, 2013 | AO Smith 1.5 hp 3450rpm 48Y Frame 115/230...
We have 48" lithonia flouresent
even if there is power at the sockets, ballast may not have power to fire off the lamps, how old is this fixture, and you need to replace the ballast same as in fixture, if you replace ballast make diagram of wiring so you can rewire it like it was wired from store.
Aug 21, 2011 | Lithonia Lighting White Finish 2 12" High...
Have Whirlpool model RPD306PDB15. Internal light works, but no illumination on touch pad. Is pad bad and in need of replacement?
FIRST THING IS CHECK YOUR BREAKER TO MAKE SURE YOU ARE GETTING A FULL 220 VOLTS,,,, THEN TAKE THE UNIT OUT OF THE WALL AND CHECK THE VOLTS WHERE THE WIRES HOOK ON THE TERMINAL BLOCK,,( MAKE SURE THE POWER IS OFF WHILE YOU TAKE THE UNIT OUT, THEN WHEN IT IS OUT AND YOU MAKE SURE THE WIRES ARE NOT PULLED REAL TIGHT, THEN TAKE THE PANEL OFF TO GET TO THE TERMINAL BLOCK, THEN TURN THE POWER BACK ON TO CHECK THE VOLTS),, IF YOU ARE GETTING THE FULL 220 VOLTS THEN IT IS LIKLEY THE TOUCH PAD HAS WENT OUT,, I HAVE SEEN ALOT OF THESE BUT MOST WERE JUST NOT GEETING ENOUGHT POWER,, IT RUNS ON 220 VOLTS 110 TO POWER THE ELEMNTS AND LIGHT AND 110 TO POWER THE ELECTRONICS
Jan 19, 2011 | Whirlpool RBD305PD Electric Double Oven
Changing ballast
Here is the link for wiring Lithonia Power Sentry Ballasts: http://www.acuitybrandslighting.com/Library/LL/documents/Installation%20Instruction%20Sheets/PS.pdf
Hope this helps Sparkylikes480
Mar 27, 2009 | Lithonia Lighting Psq500 Power Sentry...
Maytag model MDE7057AYW 5600 Watts dryer runs ,but
5600 watts will not operate off 120 volts.
This is a 220/240 volt hookup.
There are 2 legs of 120 volts each that operate the dryer.
The only part requiring 220v is the heater.
Otherwise 120v routes through the various controls and relays.
Mar 12, 2009 | Maytag Dryers
Electrical hookup
no its 220 red to one 110 line blk to the other 110 line white to neutral should be a solid metel wire to take that to ground
Jan 26, 2008 | Jenn-Air JED8430 Electric Cooktop
Wiring a stove
If there is no 220 outlet in the location where you're planning to put the stove then you need to run wiring to the new location. There are two seperate phases of 110 volts coming to your home. The voltage between each of these phases and the neutral wire is 110 volts. When your house was wired only 1 of the 110 volt signals was run to your 110 volt outlets. In order to create a 220 volt outlet you need both of the 110 volt signals run to the outlet.
If you have a straight shot between your breaker box and the location where you need the 220 volt outlet then this is not too big a deal. If you have finished ceilings and walls inbetween then this will be much more difficult.
If you're not comfortable with electrical wiring this would be a good time to call a licensed electrician.
Nov 18, 2007 | Ovens
Dryers Logo
Top Dryers Experts
