How to enlarge print when copying on Envy 4500
To enlarge the print when copying on the HP Envy 4500, you can adjust the zoom or scaling settings in the printer software. Here are the steps to follow:
1. Load the document or photo that you want to copy onto the scanner bed.
2. On the printer control panel, press the Copy button.
3. Use the arrow buttons to navigate to the Zoom or Scaling option and press OK.
4. Use the arrow buttons to select the percentage by which you want to enlarge the print. You may be able to choose from a list of preset options (such as 125%, 150%, or 200%), or you may be able to enter a custom percentage.
5. Press OK to apply the changes and start the copy job.
If you're using the printer software on your computer to control the copy job, you may need to follow slightly different steps depending on your operating system and the version of the software you're using. However, the basic process should be similar. Look for options related to zoom, scaling, or print size, and adjust the settings as needed to achieve the desired level of enlargement.
