Question about PSA E-Torque (ULT33180)
I have an ultra case model ULT33180. I need to know the wiring diagram of the power switch. It has 4-8 wires running to it.
  • 818 Answers
Http://www.ultraproducts.com/PDFs/spec_sheets/ULT33180/ULT33180_1.pdf
Posted on Jan 03, 2009
How do i hook up 3 function switch
1) Copy following link to see wiring diagrams:
http://waterheatertimer.org/How-to-wire-switches.html#triple
2) There are two basic wiring type, depending if power wire and neutral arrive in switch box first, or power wire and neutral arrive in ceiling box.
3) Most homes, the power wire is in ceiling box.
In this case, a minimum of 4 wires are needed between ceiling box and switch.
Dec 09, 2012 | Leviton 1755 Triple Rocker Switch Decora
I need a wiring diagram for a generac gp15000e generator
I have a 15000 ultrasource generator the start and stop switch was taken out i need to put it back The problem is i dont know which wire goes where and when i look at the wire diagram the numbers are different the numbers on my unit are 15, 11, 133, 14, 12, The 15 and 11 are the same wires the start and stop switch has 6 males on the back to plug the wires into Does anyone know which wire goes where???
Nov 05, 2011 | Generac Guardian Ultra Source 15,000 Watt...
Trying to install a push button ignition need to know which two wires to run to the button, without having to spend hours tracing and guessing. A diagram showing the wires would be great.
Your switch has 4 terminals.
1. Red is the hot wire from the battery.
2. Dark Blue is the run wire. This wire powers PCM, and engine and well as all accessories when the key is on.
3. Yellow is the start wire. It powers the engine, ECU and starter circuit when the key is turned to start.
4. Last terminal is accessories. I don't know the color, but it will power the radio, blower, windows, mirrors, etc. when key is turned to ACC. Some diagrams of the switch are below. Please let me know if you have any questions.
Nov 12, 2010 | 1996 Dodge Dakota
I know the circuit diagram but how do you
If the power originates at the location of the light (or other item being switched) you need a 3-core cable from there to to each switch location.
If the power originates at one of the switch locations you need a 2-core cable from there to the fixture and a 3-core cable to the other switch location. (If the cable to the second switch location is routed through the junction box at the fixture then you only need 4 cores from the first switch to the junction box--three switch wires and the neutral wire for the fixture.)
In all cases described above the ground (earth) wire is separate and not included in the count.
Oct 21, 2009 | Lutron CW-2-SS Claro Two-Gang Screwless...
How to wire 3 switches in a 3 gang box
WARNING: Do not attempt to do this work unless you completely understand the information provided below. If in doubt call an electrician.
Always make sure the power is disconnected from all possible sources before making any connections. Your description of the problem indicates that there may be multiple power wires coming into the same box. In that case local codes may require that the box be partitioned to prevent exposure to voltages up to 220 volts.
You need to determine where each wire goes to know how to connect them together. You cannot rely on color alone. If the power supply runs through the box to the loads then most (but probably not all) of the white wires will be connected together. If the power runs to the load boxes first then none of the white wires in the switch box should be connected together. They are used to run the switched/dimmed power back to the loads (and should be taped to cover the white in the box). In that case each switch has its own power input and they should not be tied together. A wire (could be black or white with black tape) brings power from the load box, gets connected to the input terminal of the switch and the corresponding black wire carries the switched power back to the load. The fan/light switch will have one power in and a switched power out for the fan and another for the light. The 3-way will have one "power" in (or it could be the final power out to the light) and two "carrier wires that connect to the other 3-way switch. If the power supply goes through the switch box then there will be at least 10 wires in that box. In that case see the attached diagram: a5fa64a.gif
Sep 23, 2009 | Cooper Industries Cooper Wiring 2158V 3...
Wiring diagram and user-owner manual, fraser nash
need wiring diagram
ultra multi mode meter plus
Apr 17, 2009 | Electronics - Others
Computer Case ULT33180 Powers down about 4 seconds after started
Ive done something similar, I took the CMOS battery off the motherboard and put it back in after about a minute to reset the bios. Unplugged the power supply from the motherboard and flipped the power switch on the back of the power supply (on and off a few times) and plugged the power connector back onto the motherboard. I know it sounds like an odd way of fixing this problem but has worked for me.
Jan 03, 2009 | PSA E-Torque (ULT33180)
Mic wiring diagram
Same as Omega
#1 Mic Audio
#2 Receive
#3 Transmit
#4 Up/Down for channels
#5 Ground/Shield
#6 13 volt
Jan 13, 2008 | Magnum DeltaForce CB Radio
PSA E-Torque (ULT33180) Logo
183 people viewed this question
Top PSA Computers & Internet Experts
David Fischer
obsteiner
JonSnell Electronic
JonSnell Electronic
Are you a PSA Computer and Internet Expert? Answer questions, earn points and help others
