Question about Roper RGX4634KQ Gas Dryer
My dryer will not heat up either. On any setting. I looked through the peep hole in the front and i do not see anything glowing. What do I need to do? please help
  • 3 more comments
  • ballinpimp24 Jan 04, 2009
    Would it be the thermal cupler?
    It is a gas dryer. It is the roper by whirlpool. its model number is RGX4634KQ2
    so it wouldn't be the thermal cupler?
    are those the exact name of the parts I may need?
  • keefers_77 May 11, 2010
    Gas or electric? Brand and model?
  • 57 Answers
It is either the glo bar or your coil pack... If the glo bar is not white hot then it needs to be replaced. if it does turn white hot then it is the coil pack that quit working. You can usually take off one of the covers at the bottom of the dryer to see this.
Posted on Jan 04, 2009
I looked through the peep hole in front of my gas dryer and I don't see anything lit.Dryer spins great, but doesn't heat up. What is the problem?
Igniter - The dryer's igniter is what ignites the gas that has entereddryer-ignitor.jpg through the gas valve. It will glow red, then when it reaches a certain temperature, it will trigger a thermostat that opens up the gas valve and that's when the dryer starts to heat the air. If the igniter has failed, the motor will still run but not produce any heat.
Jan 31, 2012 | Whirlpool Dryers
DRYER RUNS BUT NO HEAT BELEIVE IT TO BE HEATING ELEMENT
With the gas machine you won't actually have a heating element. What you will have is a burner assembly. There are a few common things that can cause a gas dryer to stop heating.
The dryers have a square cap on the front near the bottom. Remove this with a knife or small object. Looking through this hole you are face to face with the burner assembly. Turn the machine on, if after 10-15 seconds you see a glow and the flame starts, you probably have a bad set of coils. Coils can allow the dryer to start, but after the flame goes off, they have problems starting it again. So, when you come back and find damp laundry, it may actually be heating, just not very well. IF there is no glow when you look through the peep hole, keep reading.
The most common part is a thermal fuse. This fuse is located on the back of the dryer. Simply unplug the dryer, pull it out, and remove the back (Eight 1/4 screws). The fuse looks like this http://www.appliancepartscompany.com/xcart/images/D/3392519.JPG it will be on the lower left hand side. If you do not have a multimeter to check continuity you cannot be for sure. This is a cheap start to figuring out your problem.
If you have a multimeter simply check the two terminals where the wires were plugged in for continuity. It should read about .1. This fuse goes bad when it gets to hot. There are few reasons this happens, but the #1 reason is that the vent to the dryer is clogged in some form or fashion. Outside the house where the vent exits should have a strong air flow while the dryer is on. If it is clogged by any means, the hot air cannot escape the dryer and the fuse will blow.
Two of the other commonly replaced parts are inside the dryer, accessible from the front. These parts are the ignitor and the coils.
May 28, 2010 | Whirlpool LGR3624JQ Gas Dryer
Dryer is not heating.i looked in the peep hole and could not see the ignighter glowing
That's the problem, a bad IGNITER. Easy to replace and available at all Appliance Parts Stores.
Nov 27, 2009 | Kenmore Dryers
I have a MD7600 maytag dryer. It runs but it will
when you turn it on give it a few minutes and see if you see a glow. that will be the ingnitor.if glowes low or dont see a glow at all then id say you have a bad ignitor. if you see a bright orange glow then id say your gas valve is bad. the ignitor is located next to the gas valve, usually their is a peep hole in the front of the dryer that you pop off (dime size cap) and you can look in hole and see if you see a glow. ignitor price roughly 20-50 dollars. vale can be pricey. 50-145.00 dollars part only. labor ingnitor 75-125 and for valve 85-165 depending on were you live and who you use. usually one or the other not both and seldom a thermostat could be bad.
Sep 17, 2009 | Maytag Dryers
No heat to dryer
it mean it dont have a gas pilot and it has a ignitor instead ,,,, if you turn on the dryer and dont see a glow then it may have a bad ignitor ,,, on a kenmore it should not have a door to open unless it is a old unit and the newer ones has a peep hole to see into.
Dec 04, 2008 | Kenmore 72602 Gas Dryer
Heating on series 70 Kenmore Gas Dryer
suspect the 2 black coils on gas valve/burner after first heat cycle they will open and not work until cool down
Nov 26, 2008 | Kenmore 70172 Gas Commercial Dryer
Kenmore elite gas dry 6 years old - no heat
PUT YOUR DRYER ON AIR FLUFF AND TURN IT ON. THEN SELECT A HEAT SETTING. IF YOU HEAR A DISTINCTIVE CLICK WHEN YOU SELECT HEAT, THEN CHECK FOR A GLOWING IGNITOR. MOST KENMORE/WHIRLPOOL DRYERS HAVE A PEEP HOLE IN THE FRONT LEFT SIDE OF THE DRYER. REMOVE A PLASTIC COVER TO VIEW INSIDE.
IF THE IGNITOR GLOWS, AND THEN CLICKS OFF, YOU HAVE A BAD SOLENOID (COIL SETTING ON TOP OF THE VALVE). IF IT NEVER CLICKS OFF, YOU HAVE A BAD RADIANT SENSOR( LOCATED ON THE SIDE OF THE BURNER HOUSING). IF NO IGNITOR GLOWING, THE IGNITOR IS BAD.
IF WHEN YOU SELECT HEAT, THERE ISN'T ANY CLICK, THEN THE THERMAL FUSE LOCATED BEHIND THE BACK PANEL DOWN NEAR THE EXHAUST IS BAD. IT IS A SMALL WHITE ITEM WITH TWO THIN WIRES ATTACHED TO IT.
Apr 07, 2008 | Dryers
Intermitten Heat up
make sure that your vent is not plug up can you go outside your house and feel good air coming out the vent when the dryer is turn on if so the only other things it could be is the coils that sit on the ignotor assmebly or the high limit termistat is not working properly the coils are little black circle coils that sit in the ignitor assmly should have a metal braket across the top of them holding them in you can check resistance on these coils if you have an meter
Mar 22, 2008 | Kenmore 72802 Gas Dryer
Dryer won heat timer dosen't avance
huntman, the model posted shows as a gas dryer. In the lower left side there is a square plastic peep hole. Take a putty knife and pull it off. Set the dryer to high heat and take a look in the hole. Does the ignitor glow? If it doesn't you either have a bad thermal fuse or a bad ignitor. Start with the thermal fuse. You will have to remove the back panel to get at it. I will attach a photo. You can ohm it out, or just jump the wires temp. to see if the ignitor glows. If theral fuse is good and the ignitor does glow, you probabley have a bad set of coils. These sit on the gas valve are easy to replace. The timer won't advance without the heat. Check this out first...Catriver..post back.
Mar 15, 2007 | Roper RGS7745PQ Dryer
Roper RGX4634KQ Gas Dryer Logo
78 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
