Question about Samsung Digital Color Security Camera Fixed Lens SOD14C SOCC120 With Rj11 Connection
Samsung sod14c wiring hookups - Samsung Digital Color Security Camera Fixed Lens SOD14C SOCC120 With Rj11 Connection
Connect i pod to tv
You need a three end wire with a iPod hookup one end looks like your charger and the other has three RCAs red white and yellow. Try radioshak
Jan 29, 2012 | Samsung Cell Phones
How do I know if I have a 3-wire or 4-wire system connection for my samsung electric dryer?
Remove the back panel where the wire is connected to the dryer...
Here is the hookup for 3 to 4 or 4 to 3 wire hookups
Please rate me
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
Dec 12, 2010 | Samsung DV218AEW Electric Dryer
I have a Samsung SyncMaster 933 HD TV that we are using for a video hookup. We have plugged the white and red RCA jack into the back but did not get a picture. Does this TV have to be on a certain channel...
The white and red wires are for sound only, you will need to connect a video source, usually a yellow wire.
What is your video source? dvd, computer, vcr, cable
Write back and i will help more
Lone99star
Jan 11, 2010 | Samsung SyncMaster 913V 19" Flat Panel LCD...
How to hook up speakders?
The monitor does not have output sound since it is only an input device. You will have to hookup the speakers to your device (laptop, computer, gaming console) that you are connecting to the monitor. The speakers in the monitor are ready to receive a signal so that it can amplify it and let you hear it. If you hookup your speakers to the monitor it is the same as if you were trying to hookup two sets of speakers to each other.
Nov 04, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
I GOT A SAMSUNG SOD14C , OKAY I WANT IT TO CONNECT TO A DVR WITH BNC INPUTS, BUT.. MY CAMERA USES RJ11E WICH NUMBER OF THE RJ11 JACK BELONGS TO POWER, VIDEO AND AUDIO?? SO I CAN RECONNET?
I salvaged an SOD14C and found this out by playing around with it.
the 6 pin RJ11 is wired as follows, holding the cable, connector up, cable hanging down with the pins facing you the pins count from left to right.
Pin 1 is green it is the Microphone +
Pin 2 is red it is the +12 Volts DC
Pin 3 is yellow it is the Speaker +
Pin 4 is the bare copper shield it is the common (-12 Volts DC, Microphone -, and Video -)
Pin 5 is whitish clear it is the Video +
Pin 6 is black it is the Speaker - got-samsung-sod14c-okay-want-connect-kkfjmd05sw3quyoyjvycjykz-5-0.jpg
Hope this helps!
Mar 09, 2009 | Samsung Weather Resistant Security Camera...
Trying to get hooked up
I made a hook up from the shr 1040 to a pc monitor using a VGA converter box. Cost less then 40 ( check amazon) and simple to use as well as still use your pc on your monitor,
Aug 27, 2008 | Samsung 4 Channel Dvr
Samsung Digital Color Security Camera Fixed Lens SOD14C SOCC120 With Rj11 Connection Logo
107 people viewed this question
Top Samsung Home Security Experts
Bill
Level 1 Expert
bobby little
Level 1 Expert
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
