Question about Panasonic TX-26LXD1 26 in. LCD Television
Panasonic viera tx26lxd1 AV problem
My dvd recorder was attched to av2 all worked fine then one evening i turned it on and it was a bit grainy and in b&W.i plugged it into av4 and all was fine again but the little AV4/rgb sign wont diappear at the top left of the screen any help greatly recieved i noticed chesny posted a similar comment in april
SOURCE: Display
press and hold down the i button on the remote and the screen program number will disappear
Posted on May 14, 2007
  • 558 Answers
SOURCE: Panasonic Viera
vga board is bad ot the components on it are blown out.
Posted on May 08, 2008
SOURCE: Panasonic viera has flashing channel info in upper left corner
I had this exact same issue just yesterday. Channel info would flash intermittently. While set was in this mode, could not enter menu, change channels, etc. from remote or front panel controls. Similar to tjh492, I thought it might be an overheating issue. But unplugging the Viera and waiting for set to cool made no difference.
I then remembered that this issue popped up the instance I surfed to a particular channel (FWIW, 26-3 "Me Too" on Comcast here in Aurora, Illinois, USA). I had a hunch that there might be an issue with the signal on the channel that prevented the Viera from properly syncing, so I decided to unplug the antenna cable. Once I did that, the channel info displayed steady. I was then able to change channels (of course screen was blank as antenna cable was unplugged) and enter the Viera menu. I immediately went to channel set-up and manually removed channel 26-3 from the channel list. After reconnecting cable, Viera was back to normal. Since I'm not a big fan of "Me Too", problem solved :)
Not sure why a digital channel sync issue would effectively make the Viera remote and front panel controls inoperable. Pure speculation, but it could be that the Viera microprocessor was overloaded trying to sync to channel and this prevented any interrupts from remote or front panel controls.
Posted on Jun 24, 2009
  • 21 Answers
SOURCE: 42"viera TH42PX50U wont turn on just 10 red blinking lights
Based on my research 10 blinking lights means the video controller inside your TV has malfunctioned and needs to be replaced.
Even though Circuit City went out of business Panasonic should still support their product through manufacturers warranty.
You can contact them at one of the support #'s below
Consumer Electronics
  • Technical Support: 1-800-211-7262 (Mon-Fri, 9AM-9PM EST, Sat-Sun 10AM-7PM EST)
Plasma & Monitors
  • Technical Support: 1-888-972-6276 (Available 24 hours, 7 days a week)
I know you may be frustrated with your TV malfunctioning, I had similar issues with my LG. When you call, for prompt and professional service simply give them the model # and explain that the red status light blinks 10 times when you attempt to turn on the TV.
Hope this helps
Posted on Aug 15, 2009
  • 8457 Answers
SOURCE: cannot remove input label from Panasonic Viera's screen
Are u using HDMI/1 hook up HD box and signal?The HDMI/1 port still work?Do u use the device in the HDMI/1 port lately dose it work?Replaced the HDMI cable,Unplug the tv about an hour,plug it back in,reset it back to factory setting again.See if this work,not than ur HDMI/1 is shorted.
Posted on Mar 23, 2010
SOURCE: my panasonic viera wont turn
We had this problem. Very common to Panasonic. The problem is your A board. Panasonic is cheap because they spec'd a board that was possiblly defective. As long as you purchased within 1 year, you should be covered by manufacturer's warranty and Panasonic will send someone to your home to repair. Otherwise, if you don't have extended warranty you will have to pay.
Posted on Nov 28, 2010
0 characters
1 Points
AV1 red, white and yellow cable ports not working. I use digital satellite service for my television through a box from my provider which only uses the AV1 port? I checked all the wires which were working...
Your post is a little confused (or I am!), why would a digital box only provide a low resolution output which is what the composite standard is - yellow video composite red/white=stereo audio.
You also say that you checked the wires, so you've seen the picture and heard the audio on AV2? So why not use AV2? There is no reason to use AV1 other than you may be using the other inputs for other equipment.
Check that the output from the cable box really is composite and not component, and if it really is composite check the AV colour system in the TV menu is set to Auto (or NTSC if you are in USA, PAL in Europe)
I think you (or I) may have misunderstood how to connect it, can you have a look at your cable box and see what the output sockets are labelled and report back/clarify also detail what your cable equipment is please?
May 17, 2014 | Panasonic Viera TX-32LX70 32 in. LCD TV
Viera TX-26
Did He record the DVD for you???? or is it a store bought, if it is a store bought take it back if he made it for you then tell him to do it again and close the session for playback on a TV
Mar 17, 2014 | Panasonic Flat Panel Televisions
Cant find AV2 on a panasonic
Check the input connections. The input connection to AV-2.
Jul 03, 2012 | Panasonic Flat Panel Televisions
5 year old panasonic viera LCD works great until tonight, screen turned into vertical and horizontal rainbows, can see vague picture behind all the lines like looking through thin black horizontal venetian...
make sure your speaker to your sheron sound isnt to close to it .also if dvd player is the source then move away from tv will demagnatize the tv theres a magnet in them
Jul 05, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
I cannot record from a Daewoo DVD recorder ( 8150P) through my Viera TV ( model TX-L32S20B ). The screen says No Signal and instructs me to check inputs. I've tried using all cominations of AV1 and AV2...
If you want to record from the TV to the DVD recorder you have to first select a channel on the TV that you want to record and then take an AV cable ( Yellow / Red / White ) and connect from the Monitor out socket of the TV to the AV in of the Daewoo DVD recorder. Drop a blank DVD select AV on the Recorder and press the record button.
Mar 08, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
I have a 42 inch panasonic viera th-p42g10a. i have dvd connected to av1, foxtel to av2, av3 is vacant. I have lost volume to both dvd and foxtel connections, yet i still have volume when watching normal...
This is a problem with your components. You can have the components replaced with a new set which may be expensive, or live to learn using av3 only with a switch system.
Mar 03, 2011 | Panasonic VIERA TH-42PX80E 42 in. Plasma...
Which conections for the video and audio cables should be used for the Wii? I put them into the side panel (because of easy access), but can not get the start screen for wii after all is turned on....
once you have matched up the wii audio and video cables to the side panel yellow for video
white and red for audio
thinking you plugged them into one of your tv's av slots
now use your tv remote to switch through your tv's inputs (av1) (av2)
some tv's have a button like that on the tv itself.
Oct 09, 2009 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
Remote won't turn on set.
Panasonic is te best in TV or DVD.I have 10 years a Panasonic TV.Please dissasambly and clean the remote control rubber pad and change the battery every 8 mounth,and all is OK.
Sep 01, 2009 | Panasonic Viera TX-32LX70 32 in. LCD TV
I have an external DVD Recorder / Player attached at my TV via AV1 and an external DVB digital TV box linked to AV2. Both external units are linked togerther to enable direct recording from the external...
I have a LG tv set. When i press the tv/av button on the remote my tv shows av1, av2 earlier but now it is showing only av. So i am unable to watch my dvd player. Need help.
Jul 04, 2009 | LG 37LG30 37 in. LCD HDTV
Panasonic Viera TH-37PX8B Green Screen When Turn On DVD Player
I had the same problem, after reading the forums and playing around for a while I cracked it. It was to do with the output from the DVD player, in the DVD player setup I changed the output from RGB to s-video and bingo! Hope that helps
Jun 10, 2008 | Flat Panel Televisions
Panasonic TX-26LXD1 26 in. LCD Television Logo
Top Panasonic Flat Panel Televisions Experts
Are you a Panasonic Flat Panel Television Expert? Answer questions, earn points and help others
