Question about Husky Electrical Supplies
Have husky 6250 Generator. Have Carb problems. Where is carb located and how to you take it apart? Anyone know where I can get an instruction or schematic for the thing?
Trying to clean it out with Carb cleaner.
  • 52 Answers
SOURCE: Coleman Powermate 6250 generator only runs with Choke on? pull
Cbronson
how old was the fuel in the tank and carb bowl? This could have built up varnish and make the float heavier
Another issue that my customers bring in are 4 stroke generators that have 2 stroke fuel put in tank.
Posted on Jan 14, 2009
gmchat
  • 4 Answers
SOURCE: what carb does the powermate 6875 use?
check this web site http://www.powermate.com/productmanuals.php?cat_id=3 you can down load the manual and parts list for your gen.
Posted on Mar 27, 2009
Richie_asg1
  • 1036 Answers
SOURCE: I can get my G1000M generator not running.
Fuel - air mix incorrect. Clean airfilter, and probably adjust idle settings. Open way up while running to clear any debris in the needle valve - then close off again untill stall - open up and adjust for correct idle.
Posted on Oct 10, 2009
  • 3 Answers
SOURCE: i have a coleman powermate premium plus 6250
if you are running the engine at full CHOKE, then it is flooding the engine, but if you meant off full choke, then the carb is still stopped up. Try soaking in carb cleaner overnight after removing jet & all rubber goods. HOPE THIS HELPS.
Posted on Jan 17, 2011
  • 3 Answers
SOURCE: My 6250 generator has been dormant for a few
Before doing anything buy some "Start" gas additive. I found it at Wal-Mart for $7.00 a can. Use as directed. This will clean the smudge from the carb and allow the gas through. If not, try tightening the bolts that hold the carb to the engine. If they are loose the carb will breathe air and not gas. If still not running, clean the carb and jet real well. Bill...
Posted on Jun 28, 2012
Why does my husky 6250 generator run but not produce power?
Anon, If it has sat for quite a while, you may have to field flash/re exite the generator. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to re energize Dead Generator
Flash Your Generac Portable Generator with Corded Drill
How to test your Electricity Generator AVR Brushes and Alternator on...
Diagnosing Generator That Has No Power Output
Jun 08, 2016 | Husky Electrical Supplies
Looking for a carb for a Coleman Powermate 500/6250 generator with a 10hp Briggs and Sratton engine...any suggestions?
As it is a Briggs Engine most quality Briggs dealers can get the carb. It isn't special to Coleman I don't believe.
Oct 08, 2013 | Coleman Powermate Premium Plus 6250W...
Husky generator 1850 watt wont stay running
does ithave fresh gas theres a chance there is water in the gas if thats not the case is the choke could be stuck on or the carb. is gummed up
Oct 28, 2012 | Husky Electrical Supplies
I have a coleman powermate premium plus 6250 generator,put in new plug ,new filter ,changed oil,cleaned the carb,put in new gas. runs ok at half choke but when go full choke it starts backfiring and runs...
Dec 17, 2010 | Coleman Powermate Premium Plus 6250W...
Spark but no fuel . coleman Powermate 6250
Check the oil level. The protection on low oil level may have stopped it.
Jun 23, 2010 | Coleman Powermate Premium Plus 6250W...
Coleman 6250 PoweLeaking gas at bottom of motor housing. Can not
The gas is leaking from carb but in the motor not out.
You should check and repair the carb flow valve. The floating unit may be full and bent down.
Jun 20, 2010 | Coleman Powermate Powermate 5000W...
What carb does the powermate 6875 use?
Mar 24, 2009 | Coleman Powermate Powermate 5000W...
Cbronson
Jan 14, 2009 | Coleman Powermate Premium Plus 6250W...
Electrical Supplies Logo
196 people viewed this question
Top Husky Electrical Supplies Experts
JOHN LAPIER
johnny rebel
Are you a Husky Electrical Supply Expert? Answer questions, earn points and help others
