Brother Fax 525MC set up answer phone message
We no longer have the instruction book for Brother Fax 525MC and want to record a message for the answer phone. How do we do it? colin.joy@slingshot.co.nz
rizla
  • 1463 Answers
SOURCE: how to set message for answering machine lost directions
hi is this your phone here http://evaluezone.com/dxi986-2.html
also you can get the manual from here as well .
or a search on there web site Uniden | A World Without Wires
may find the right manual .
riz.
Posted on Nov 19, 2007
I lost the directions for my NW Bell GHZ answering machine. I would like to change greeting and set the time. How do I do this? It is model 36288.
Posted on Feb 24, 2008
leroyal
  • 2120 Answers
SOURCE: Brother 4100e Fax Problem - Caller ID won't work with Fax Machine
Usually, fax machines don't have caller ID capability.. If the sender's fax number appears on the faxes you receive, it's just that they have programmed it into their fax machine as a header.
Posted on Sep 12, 2008
SOURCE: answer machine
I need a instruction book for 5.8GHz i6772 phone
Posted on Sep 16, 2008
old marine
  • 2130 Answers
SOURCE: I can send faxes, but not receive them on Canon Pixma mx310
Do you have the phone you are answering with connected through the fax machine? If you have the machine set in 'tel priority' mode, the machine will not begin receiving a fax until you press 'FAX' and the 'color' or 'black' button. Alternatively, if you have your phone connected to the 'telephone' jack on the machine (next to the 'L' jack), you can press '2' and '5' on the telephone keypad to turn the machine on in fax receive mode.
Posted on Oct 16, 2008
I need to redo the phone answer recording on my cannon fax phone 845
Instructions will be in the user manual , as each model differs, and if you no longer have the manual, Google Cannon . com for a user manual or instructions.
Sep 27, 2016 | Cannon Office Equipment & Supplies
Hi. My At&t Cordless 2 Hand set Telephone (EL52213) Answering machine (ON) doesn't record incoming messages. The Message window shows 0. The Telephone base is connected with my FAX machine (Teleph
If your Phone service is recording messages, that disconnects your line. You need to have them turn that feature off, OR set the answering machine to answer is less rings, say two or three. If the FAX machine listens to the line, it can still be set at a higher amount of rings, say four, and should still answer any FAX signal as it's sent to the answering machine.
Jan 25, 2015 | AT&T Lands Phones
I have a brother fax-525MC -there is a very long delay between the call being answered and the outgoing message being played......so long that most people actually hang up and don't hear our message...
There is no adjustment that can be performed to cure this problem. I can only suggest you clear the machines memory and start again as it will return the software as to as it was when new.
You must press menu*2864 within 3 seconds. the screen will show "Maintenance". now input 01. the screen will shows "Initialise" and return to "maintenance". Press 55 and it will show "White level" then go back to "Maintenance" now press 02 and the same happens. When back in maintenance press 99 to exit it. Now there will be nothing AT ALL in the machines memory and it should perform as new once more.
May 05, 2011 | Brother FAX-525DT
How do I tell my 2820 to prepare to receive an incoming fax? My phone line and my fax line are the same number. It continues to ring but the fax machine is not answering. I have also turned the answering...
To have the machine answer faxes and record voice messages unattended change the answering mode to message centre. If you are home and pick up the phone , but it is a fax, not a phone call push *91 on the phone you answered on, and hang-up the phone. the fax machine will tyhen start receiving.
Dec 27, 2010 | Brother IntelliFax-2820 Laser Fax
We can send faxes but we can not receive faxes. The fax machine that sends the fax tell it that our line is busy. Is that a machine problem or a phone line problem?
Problem lies in your Receive Mode setting. If you don't have a dedicated phone line for the fax machine, you need to set it up for either Manual where you answer every call or Fax/Tel whereby the Fax machine determines if the incoming call is a fax or phone call. Instructions per Intellifax 4100 Manual.
Select a Receive Mode
Choose the mode that best suits your needs by pressing the Mode button
repeatedly until the FAX and FAX/TEL lights show the setting you want to use.
Manual
You must answer every call yourself.
The Brother machine must be started manually
to receive faxes.
Fax
For use with a dedicated fax line.
Every call is answered as a fax.
Fax/Tel
For receiving fax and voice calls on one line.
The FAX answers every call and receives a fax or
double rings for you to pick up a voice call.
TAD
For use with an answering device.
The TAD answers every call and stores voice messages.
Fax messages are printed.
Apr 20, 2009 | Brother IntelliFAX 4100 Laser Fax
Answer phone message
I would like to change my brother fax -T94 machine from French to English and also to set up an answer phone message on it. Thanks Denis,
Apr 01, 2009 | Brother FAX-T94 Plain Paper Thermal...
NEED THE MACHINE TO ANSWER WHEN THE PHONE SENDS THE SIGNAL.
After making my post, I went to the official Brothers website for the 4100 FAQs and "Operating Instructions." Here's what I found. Set your 4100 set to the "Fax/Tel" mode. Press "Menu", then the number 2 (Fax), then number 1(Set-up Receive), then number 1 again (Ring Delay). Use right arrow key to increase. Once increased, press the "Set" key. You'll see the message "Accepted." Now press the "Stop" key to exit "Menu." This will now give you up to 4 rings before the fax auto answers. Inorder to send a signal by phone to remote start the fax just follow the instructions I copied directly from Brothers instructions for the 4100: If you answer the call on an extension phone (this is any phone plug into a phone jack on the same line) and hear a beep every 3 seconds (automatic fax) or just silence (manual fax), press *51(remote activation code) on the telephone keypad, wait to hear the Brother machine turn on (chirping sounds) and then hang up. I don't have anyone that can send me a fax right now to test it out. I'll have to try it in the morning. Hope this works for you.
THEOH
Feb 23, 2009 | Brother IntelliFAX 4100 Laser Fax
Answer machine
I HAVE A VTECH PHONE AND LOST POWER TO IT. AND I'M TRYING TO SET THE ANSWERING MACHINE UP, I CAN'T FIND THE INSTRUCTION BOOKLET AND I CAN'T FIND IT ON THE INTERNET. I HAVE A 5.8GHZ VTECH MODEL IA5874 VTC-IA5874-R. I KEEP GETTING THE LETTER (A) ON THE BASE PHONE AND IT WILL NOT RECORD ANY MESSAGES THAT ARE LEFT. I DID WHAT THE MENU SAID TO DO BUT STILL WONT RECORD ANY MESSAGES, NEED HELP TO WHERE I CAN FIND THE INSTRUCTION BOOK OR HOW TO FIX IT. THANK YOU
Oct 15, 2007 | Vtech 5.8GHz Cordless Phone with Digital...
Setting the voicmail
Voicemail or telephone answering device (TAD). There is a BIG difference. Voicemail is product of your telephone service provider. If you have voicemail, most providers have a solution to this that you must arrange through them. If you have an answering machine, you can set your Brother to TAD mode. In TAD mode, if your answering machine picks up, (you must set your answering machine to answer in less rings than your fax), your fax will "eavesdrop" to listen for the fax tones from the sending machine. If it hears these tones, it will disconnect your answering machine and accept the incoming fax. If it does not hear the tones, it allows the answering machine to record the incoming message. If you are home. If you answer the call and hear a tone every 2.5 to 3 seconds, that signals an incoming fax. Simply touch *51 on the keypad of the phone you picked up on. You will hear some shrill tones. That is your fax machine attempting to receive the incoming fax. Hang up the phone you are on and it will receive the fax. In any case, make sure that the receive mode is NOT set to AUTO. Set the receive mode to TAD or MANUAL. If these instructions were not clear enough, let me know and I will send you DETAILED instructions. You can find the manual here: http://www.brother-usa.com/Data/Documentation/Fax/User/UM_FAX2820_FAX2920_MFC7220_MFC7225N.pdf If you need additional assistance, please let me know before you rate this solution. Ed
Jun 29, 2007 | Brother IntelliFax-2820 Laser Fax
Brother MFC660CN - asnwer machine message length too short
Here is a link to the manual for a very similar model: http://www.brother-usa.com/Data/Documentation/Fax/User/UM_FAX580MCMFC660MC.pdf On page 9-5, it describes how to extend the recording time to a maximum of 60 seconds.
Mar 21, 2007 | Brother MFC 420CN All-In-One InkJet...
k24674
jasbo
jasbo
