Question about Refrigerators
Kenmore side by side freezes up about every two weeks. I replaced thermostat and was told that I need a timer. What is a timer and is that what I need?
  •  George Michael Smith
    George Michael Smith Oct 27, 2012
    Hello Diane. What is the model number on your fridge. I'm guessing you replaced the defrost thermostat on the fridge?
    Problem Solver:
  • 4 Answers
A DEFORST TIMER IS RESPONSIBLE FOR DEFROSTING THE EVAPORATOR .THIS PROCESS TAKES PLACE EVERY 7 TO 8 HOURS..THERE IS A HEATING ELEMENT THAT IS PLACED BESIDE THE EVAPORATOR THE DEFROST TIMER CAUSES THE HEATING ELEMENT TO BECOME RED HOT AND IT IS THIS HEAT THAT MELTS THE FROST IN THE FREEZER COMPARTMENT.
Posted on Oct 27, 2012
  • 262 Answers
SOURCE: Kenemore side by side refrigerator made by Frigidaire freezing everything in fridge
on some models you can by pass the filter assembly you can do this by looking at the rear of the ref.at the water inlet valve you will see the lines going to the filter remove these line and look at the way the water goes into the ref you can move these lines around to bypass the filter this will tell ya if the filter assembly is bad I have seen where you cant use the filter on these machines and have to go to a in line filter.good luck and get back to me on this i will help you as much as i can
Posted on Jan 08, 2008
jmgldsmth
  • 1889 Answers
SOURCE: Kenmore side-by-side fridge. Timer not working.
the defrost timer should be located on the back of the machine a label should point to the hole
Posted on Apr 28, 2009
jumptrout51
  • 3361 Answers
SOURCE: fridge is freezing up.
The defrost heater must be replaced when the defrost T-stat is replaced.
The main control board located on the rear of the fridge controls defrost sequence.
Posted on May 15, 2009
  • 10865 Answers
SOURCE: Our side by side refrigerator is only two years
You nailed it. Replace the stat.
Posted on Jun 29, 2009
  • 1044 Answers
SOURCE: refrigerator not freezing
It appears that your thermostat setting is not correct. Please put it on HI cool and then check if the fridge is working OK . The problem could be due to leakage of gas. Please check this If both these fail then get your fridge checked up by a technician as there could be a internal problem. Most likely it is the above 2 problems.
Posted on Jan 30, 2010
Freezer not freezing
You may need a new defrost timer,heater or thermostat if there is frost build up in the freezer
Sep 30, 2012 | Kenmore Refrigerators
Kenmore mini fridge freezes all contents even when set on lowest setting 1
three things you have to check your defrost timer,your defrost thermostat, and your defrost heater you would need to use a multimeter on all three of these and check for continuity between each side of the terminal ends the one that gives you no continuity is the one that you would need to replace hope this helps
Jun 26, 2010 | Refrigerators
Frost free fridge freezing up
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 11, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Mine freezes up and I too have to use a hair dryer about once
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control. Since your heater does come on but not when it needs to I suspect the electronic control.
Sep 08, 2009 | GE GSS25LGM Side by Side Refrigerator
Refrigerator won't defrost.
Replace the defrost thermostat and defrost heater in the freezer.
Aug 19, 2009 | Kenmore 71279 Bottom Freezer Refrigerator
Fridge is freezing up. not going thru defrost cycle we have a side by side ge fridge and it freezes up and we unplug it letit defrost and it will be fine for few days.& then is does it again; we...
May 15, 2009 | General Electric GSS25JET Side by Side...
My freezer coil keeps freezing up. I replaced the
In the freezer coil is a defrost heater coil, and a defrost thermostat. You have to expose the freezer coil to find them. If your local dealer can't get parts, I get mine from Repairclinic.com.
Apr 29, 2009 | Kenmore Refrigerators
Will not cool proper on fridge side
THIS IS A DEFROST PROBLEM EITHER THE THERMOSTAT OR DEFROST TIMER IS BAD! THE THERMOSTAT IS LOCATED BEHIND THE WALL IN THE FREEZER COMPARTMENT ATTACHED TO THE COILS TO KNOW IF ITS BAD IF WILL HAVE A RAISED SPOT ON THE BACK LIKE ITS BUSTING OPEN CHECK THAT
Apr 27, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
59 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
