Question about Ematic 7" eBook Reader
I cannot get my ereader to connect to the internet
I have put in my wireless code over and over but it continues to show no connection.
When accessing the internet on tablet the `Unfortunately, internet has stopped` message appears even though it is showing that wifi is connected
Verify that your router has a good internet connection and that its local IP service (usually through DHCP) is running. Try entering the router's TCP/IP address (e. g., http://169.168.1.1) in your browser's address bar to see if you can get the router's status page.
One of the more common failures in older routers is IP service dropout, particularly if the router overheats because something was stacked on top of it. This will result in client error messages such as the one you describe.
Another possibility is an authentication failure, but that would generally mean somebody messed with the wireless network access password, or there's a bug in the wireless coding (as in some ASUS laptops - this was fixed in a firmware update).
May 28, 2016 | Samsung Galaxy Tab 10.1 Wifi - Tablet -...
I have Acer Iconia B1 it has put itself in safe mode I've tried everything but cant acess wifi my settings show I have a strong signal and connected but the WiFi ?? symbol is not blue, what can I do
I'm afraid you can't access wireless Internet while in safe mode.
Try pressing Alt and F10 when turning on your computer and choosing safe mode with networking instead of safe mode.
May 10, 2015 | Acer Tablets & eReaders
How do I get it on my wifi network? it keeps telling me it is avoiding the network because of poor internet cinnection.
If you have poor internet connection problem with your WiFi, try with the following steps,
1.)Reset the wireless router by using the power switch on it or by unplugging it and plugging it back in.
2.)Place the wireless router in an ideal location. The higher it is, the better, but don't put it near metal objects.
3.)Get as close as possible to the router with whatever device you're trying to connect.
4.)Keep the router and your connecting device away from other electronics. You should especially keep away from phones, fax machines and microwaves. etc.,
5.)Adjust the Wifi antenna if it has one.
6.)Change the router's channel, especially if other wireless routers are nearby.Following these steps would give you stable internet connection and also increased speed in connection. You can check your internet speed from ScanmySpeed.com before and after following these steps.
Dec 25, 2014 | Tablets & eReaders
How to connect my tablet to internet
I'm assuming your tablet has wireless (WIFI) on board. If so, go to your settings screen and look for wireless networks (usually a tab somewhere in the settings screen). Make sure WIFI is turned on and then search for available networks.
On most tablets, available networks will automatically show up. Select the one to connect to that you prefer, type in the password when it asks, and you should be good to go.
Jun 19, 2014 | Tablets & eReaders
Connecting tablet to internet
I have no connection on my android tablet and when I try to connect it keep say authentication problem
Dec 21, 2011 | Tablets & eReaders
My new tablet will not connect to internet. i have the usb plugged into mt laptop. i do not have a wireless router?
open network connections on your laptop and select both the wireless adapter AND the internet connection adapter in there and right click on them and click bridge connections. Then go into the network setup wizard (XP) or network and sharing center and click connect to a network and choose adhoc connection. then open wireless settings on the coby kyros and connect to the adhoc connection on your laptop. You should then be able to connect to the internet on it
Mar 26, 2011 | Coby Kyros 716829701508 Tablet PC
TRYING TO CONNECT WIRELESSLY TO THE INTERNET DOESNT WORK
wow! thats a very nice wifi card. prism.
anyway, here is a link for your windows 2000.
this connects you to any wifi hotspot other than boingo.
cheers
Mar 27, 2008 | Fujitsu LifeBook P1120 Tablet PC
Ematic 7" eBook Reader Logo
Top Ematic Tablets & eReaders Experts
Ap12
Ap12
Michael Harrier
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you an Ematic Tablet and eReader Expert? Answer questions, earn points and help others
