Question about Brandt Dishwashers
Brandt DW13X dishwaher door falls open quickly when opened
  • 51 Answers
SOURCE: Kitchaide Dishwash Door
There is normally 2 heavy springs & cables that control the "falling" of the door located in the bottom of the machine or it the door itself. Sounds like one (or both) have snapped.
Posted on Jul 25, 2007
SOURCE: Door falls open
I have had this issue TWICE now on a three year old dishwasher, and Sears charges you $150.+ to fix it. It is quite simple to fix, there is a special part that has all the pieces attached to it, except for the spring. You will have to remove the screws that are holding your dishwasher under the counter. This could be behind the rubber on the sides. I had to remove a gray plastic circle piece on the inside to see the screw (it pops right out, don't loose it!). Pull out the machine enough to see the out side- side. You will see a (plastic) white roller, string(rope), and a piece that attaches to the dishwasher. There is a number on the white plastic piece that looks like a L (it just slides out). Thess pieces are called the Dishwasher Door Balance Link. You will need to order these pieces, they are all inclusive, and come for both sides of the door, at a whopping price of $15.00. VERY simple to install. Attach one end to the spring, line up in roller then attach to the dishwasher. It is easier to look at it and follow what is on the dishwasher than me clearly explaining it. I feel that paying $1000.00 dollars for a dishwasher would warrant using metal pieces instead of substandard plastic, for this application. These door are very Heavy and like I have said I have replaced them twice with a waiting time of three weeks for the repair man. Please try it, you can do it.
Posted on Dec 31, 2007
  • 833 Answers
SOURCE: WHEN OPENING THE DISHWASHER DOOR, IT DROPS QUICKLY.
Yes.  Generally, there are two springs on the bottom of the door-oneon each side- inside the motor housing that have broken.  Get them from any supplier.  Remove the kick plate, locate the spring locations and install them.  There is usually a hook on the door assembly and a hole in the frame where they go.  Illustrations of this are available on line at parts suppliers if you need them.  The parts are just a few dollars.
Posted on Dec 04, 2008
  • 10 Answers
SOURCE: Dishwasher falling forward
Open the door and look up at the leading edge of the dishwasher..you should see two metal eyelets that may or may not need to be bent up or swung into position. Take two sheetrock screws and screw one into each eyelet up into the underneath of your countertop that will hold it in place
Posted on Oct 05, 2009
  • 534 Answers
SOURCE: Have problem with door on Frigidaire Electolux
there is a spring that connects to the side of the door (both right and left) than connects to the holes on the bottom of the dishwasher frame. These springs have either fallen off or broken. To see the area where they connect you will need to remove the very bottom panels below the door. Look at the frame where the leg height adjustment screws are and you will see several holes in the frame the springs will most likely be right there and just need to be reconnected to the frame itself. If the springs are not there then the springs will more than likely be right at the bottom left and right side of the doors. These springs should be set in the 3rd hole back from the front if the door drop is still too fast set the spring further back on the frame.
Hope this helped
Dave
Posted on Feb 04, 2010
How to operate top loader brandt malice AA washing machine
Hi guys! Please help me. I used the Brandt Malice top loader with a horizontal drum. I don't think the doors on the drum were clipped closed properly and now when I open the machine the drum is not facing up so I can't open it? It also won't spin. What do I do? There is clothes in there and the machine is off, but the drum seems stuck? Please help!
Sep 29, 2013 | Brandt WFH1176 Front Load Washer
My trunk door opens automatically but wont stay up it falls quickly and hard to about mid point then jerks a few times and starts to fall again.
The hydraulic props on both sides of the trunk door need to be replaced. They do wear out over time. They are covered under the 3 year 36,000 miles warranty.
May 15, 2011 | Chrysler Aspen Cars & Trucks
The glovebox falls open quickly instead of opening slowly.
Hello, and welocmed to FixYa. Please allow me to assist you.
More than likely, if your cabin air filter was recently changed, the mechanism to allow the box door to open slowly was not reconnected. We see this issue quite often.
Suggestion: Open the glovebox. Look at the side closest to the passenger door. You should see a small plastic cylindrical device with an arm fastened to the side of the glovebox dor with a phillips screw. If the arm is disconnected, just remove the screw and reconnect the arm.
A less common occurance would be the other side of the cylinder being disconnected, also. Either way, it sure sounds like your loweing device has somehow been disconnected.
Thanks for choosing FixYa for assistance.
Jun 09, 2010 | 2009 Toyota Venza
Dishwaher detergent dispenser is not opening
go to searspartsdirect.com and put the model # in they will ship the part to you.
Mar 02, 2010 | KitchenAid 24 in. KUDS25SH Built-in...
Ariston LI 45 door will not remain closed and will
Strip the door and re-set the switch. Ensure the metal part of the catch on the machines main body is not distorted
Jan 31, 2010 | Ariston Technologies Dishwashers
How to replace a kleenmaid brandt dishwasher door handle
Go to www.espares.co.uk
Look for "Dishwasher Door Handle Opening Pedal" - Genuine spare part for select Blomberg and Hygena dishwashers.
This is the part you need for a Kleenmaid/Brandt DW3 dishwasher.
Jan 22, 2010 | Dishwashers
Oct 05, 2009 | Dishwashers
Jul 25, 2007 | KitchenAid KUDC25CH Dishwasher
Dishwashers Logo
26 people viewed this question
Top Brandt Dishwashers Experts
Are you a Brandt Dishwasher Expert? Answer questions, earn points and help others
