Question about GE JVM1660 Microwave Oven
Coupler has stopped turning
Sounds as if it wants to turn but no rotation. Happened after I was placing a firly heavy load on the turntable repeatedly. It is a GE over the range unit JVM1661 made in 2001.
Am hoping to buy parts and repair it myself.
  • GE Master
  • 9,098 Answers
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
But first you should also be sure that the internal cooling fan is working, because in this model, that's where the stirrer and turntable motors get their power - from a tap on the cooling fan motor!
Probably the easiest way to check this is to remove your stirrer cover, place a cup of water on the tray, then microwave for about a minute.
Watch through the glass and see if the metal stirrer is slowly rotating.
If not, the problem may be a bad cooling fan.
It is vital that the cooling fan runs, or the magnetron will be destroyed, too.
If you're not sure how to remove your stirrer cover, it's covered in your owner's manual.
If for some reason you don't have your owner's manual, you can download GE owner's manuals and installation instructions here.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Jan 03, 2009
Turntable stopped rotating
Sure, if parts are available.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
In some brands, you have to cut the motor cover off with snips, then use a screw when reassembling it.
You can find links to helpful exploded view diagrams and part ordering help here.
Apr 22, 2013 | Microwave Ovens
Turn table stop turning at times
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
May 29, 2010 | Frigidaire Microwave Ovens
Microwave turntable doesn't turn. Everything else
The turntable system typically consists of the motor, the coupler, the turntable support with rollers, and the tray.
Here is a video of how a turntable motor should sound when you rotate it by hand.
But if you've recently had trouble with the cooktop lights, then the control board may be damaged.
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
Nov 28, 2009 | Frigidaire Microwave Ovens
Spacemaker XL1800 turntable turns sometimes
I would say an internal post broke inside the motor. This often happens when a heavy item is placed on the tray.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Mar 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Turntable sometimes works, mostly doesn't
It sounds like you have a jamming turntable motor.
Jan 28, 2009 | Microwave Ovens
Turntable does not turn.
To replace either, you need to unplug power, then remove the bottom cover of the oven. In some brands, you have to cut the motor cover off with snips, then use a screw when reassembling it.
The best place to order Sharp parts is Tritronics. Or you can call them toll-free at 866-779-5835.
Dec 23, 2008 | Sharp R-530ES Microwave Oven
Carousel stopped turning
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
Dec 05, 2008 | Kenmore 63682 / 63684 / 63689 Microwave...
My Samsung microwave no longer spins. Any ideas? Please help
You can order Samsung parts here.
Aug 19, 2008 | Microwave Ovens
Turn table has stopped working in sharp r-930cs
We have the service manual for that model and have uploaded it to our site for you here.
Chances are the coupler or motor is bad.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 16, 2008 | Sharp Microwave Ovens
Dacor dcm24 microwave
To replace either, you need to unplug power, then remove the bottom cover of the oven. You may have to cut the cover off with snips, then use a screw when reassembling it.
Here are those part numbers:
66388 Turntable motor
66489 Turntable coupling
You can order either of there here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 08, 2008 | Dacor DCM24 Convection/Microwave Oven
GE JVM1660 Microwave Oven Logo
192 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
