Question about Homelite Electrical Supplies
Homelite HG 3500A generator not producing electricity
Run great but not producing eletricity
5 Suggested Answers
  • 4 Answers
SOURCE: 5500 generator stopped producing eletric after
First check with the dealer and see if it is still under warranty. If it is not, make sure nothing is blocking the air flow around where the control modules are located. This could cause the voltage regulator and other electronic parts to overheat. Next check the brushes and make sure they are free of any dust or build up preventing them from making contact.
If everything is OK the next thing I would do is change the voltage regulator.
Posted on Nov 25, 2009
SOURCE: Homelite generator model # LR 5500 not producing electricity
I have the same unit and same problem.
I have lost my owners manual. Did you figure out what needs to be done to correct the no output issue.
Posted on Jul 13, 2011
kel1guy2002
  • 3740 Answers
SOURCE: i have a hg 6000 homelite generator, runs great
Hi and welcime to FixYa. I am Kelly
This is going to sound odd but.... this is how it it is recommended to field flash and inverter type generator. (Brushless) The steps are to (not kidding...) use a male mail interconnecting wire from your house wiring and plug in your generator and turn ON the main CB for 1 minute.
If this does not work.... See steps below amnual links.
Owners manual link: (Click on get manual)
http://lawnandgarden.manualsonline.com/manuals/mfg/homelite/hg6000_1.html
Or try this direct link:
http://lawnandgarden.manualsonline.com/support/homelite/portable-generator/request-manual-299128
This is a brushless generator... Not sure what the smoke was but... the yellow wires are for the capacitor winding. If you probe the capacitor terminals with one of the wires disconnected with a meter on R x 10,000 you should see a brief jump in resistance and then the meter drifts to infinity.
reverse the test leads and test again looking for the same result.
Next read resistance Yellow wire to Yellow Wire (Stator capacitor loop check) It should read low resistance
Also read Brown wire to Brown wire. This is the DC stator loop check. Is should read resistance.
Main winding checks Red to Blue and White to Brown that goes to the main breaker. OR Turn the Main breaker on.. White to lower left pin of 30A 4 pin output recepticle. Bot red to blue and White to Brown MUST read low resistance
These are all the checks except the rectifier and the rotor. You will probably find something during the above tests. If not... respond here and I will pass on the rotor and diode tests.
Kelly
Posted on Aug 27, 2011
2wiseman08
  • 14 Answers
SOURCE: why won't my homelite generator output current when running?
If the brushes are bad on the armature you will not get power
Posted on Jul 09, 2012
Why won't my homelite generator output current when running?
Jul 09, 2012 | Electrical Supplies
I have a hg 6000 homelite generator, runs great but does not give me any power. i used it a year or so ago an everything worked fine. got a lil smoke from where windings are. the generator was made in...
Kelly
Aug 27, 2011 | Electrical Supplies
Mar 07, 2010 | Electrical Supplies
Nov 17, 2009 | Coleman Powermate Powermate 5000W...
Homelite portable generator, LRIE4400...no out put fr unit..has been discontinued fr a few yrs..no parts available..known fr circuit board failure..my dad's , maby 50hr on unit..how can I bypass..or obtain...
If the engine is running but no output from the plugs....the VERY common problem is loss of magnetism in the generator after storage.
With the generator off.........
Look at the side of the generator part.....do you see a small + and - on any terminals?
You may have to take a cover off.
Take a 9 volt battery and momentarily put current from this small battery through these terminals.
Now.....start her up and check for power at the plugs.
This fixes 75% of "no output" after being "stored" generators.
Sep 09, 2009 | Electrical Supplies
Runs great but will not produce electricity
To flash the excitor circuit on a coleman ( the generator is built by generac) you need a 12 volt battery. You quickly apply 12 volts via your 120vac recepticals. NO MORE THAN ONE OR TWO SECONDS! Then check you ac voltage. Most of the time the brushes are burnt up when voltage is low. Check the brushes first. You can access them by taking the end cap off of the generator via two to four screws. The brush holder is easy to spot, two wires leading to the front of the amature. Hope this solves your problem.
Mar 29, 2009 | Coleman Powermate Premium Plus 6250W...
Generator stopped producing electricity
if the generator has been sitting for a while you might have to excite the magnets to start producing power. plug in a reversible drill and with the generator running turn the drill in the reverse direction by hand while holding the trigger in the forward position.
Mar 24, 2009 | Yamaha 4500 Watt Electric Start Generator...
Electrical Supplies Logo
399 people viewed this question
Top Homelite Electrical Supplies Experts
wadingriver
wadingriver
John Trevino
Lawrence Oravetz
Are you a Homelite Electrical Supply Expert? Answer questions, earn points and help others
