Question about Everest & Jennings Health & Beauty
I have a metro 500 and it is about 14Yrs old i never had a problem. After i put the new batterys some thing went wrong with the cnnector cable . My batterys are fully charge but on the joy stick within 15 minuts it is down to one red light and wheel chair slows down, Any seggestions
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 104 Answers
Loose connection on battery? if new batts then you must charge them for a full 24 - 48 hours before using. but posts must be tight. they never fully charged if connections were loose to start check all connections on chair
Posted on Oct 30, 2012
  • 16 Answers
SOURCE: new battries won't charge.
Sounds like the batteries are completely dead, you'll probably need to replace them, sometimes you can only use batteries until they die, and that goes for Wheelchair Batteries too. If they won't charge or keep a charge then they are dead.
Posted on Mar 06, 2009
  • 4 Answers
SOURCE: i have a quatum 610 power chair when i use it the
It is not shutting off. You need to bring it to an expert for service. Your problem sounds like it is electronic, not mechanical.
To stop it from discharging you can disconnect the batteries. The batteries should be hooked up in series 24vdc not parallel 12vdc.
Posted on May 17, 2009
  • 175 Answers
SOURCE: only 1 battery charges
The lights are working, the batteries aren't. Red indicates power to the charger, and it should be on all the time. Green indicates a full charge, usually. If one or both of the batteries are totally dead, then the charger can't "see" them, and you will get a green light, but you will have dead batteries.
All power chairs use sealed, deep-cycle batteries. Deep cycle batteries, are designed for slow amperage dischare over a long time period, unlike a car battery that throws out a lot of amperage for turning the motor over. That's called "cold-cranking amps", and you can load-test a car battery to see if it will throw out a ton of amps for long enough to start a car. There is NO load tester made, or possible for a deep-cycle battery. A load test requires a 24-hour time period, and a complicated formula.
So, your course is to get some fresh, gel-sealed-batteries. You will need type U-1. Specify, gel-sealed-batteries when you go to the battery shop. A fresh set should get the chair up to about 12-16 mile range, which would be about 3-4 hours running constantly at high speed. Good luck.
Posted on Jul 09, 2009
  • 103 Answers
SOURCE: the chair charger has a solid green light and says
Have the batteries load tested.
Posted on Nov 06, 2009
  • 177 Answers
SOURCE: no power to motors joy stick does not woirk
Hi. If you count how many lights were flashing and let us know then I can look up that fault code and tell you what it is. Do you have the free-wheel levers in the correct place? Check the motor and battery connectors. How old is the machine, are the motors or brakes faulty. The machine will not operate if the charger is still connected. Good luck. Neil.
Posted on May 27, 2010
I have a geo metro i believe its a 1996, it says my battery has charge but its not putting a charge through the car. no radio no ac or anything will work. it want even jump. what could this be?
If you open the car door, the production date is on a label
You have the year on your title,your registration & your insurance card
Sounds like a dead battery
You hopefully know how old that is
You could have it tested or if more than
4 years old replace it
Never jump a dead battery ,I know that is what
everyone does & it is a very unsafe practice
Check the cables are in good shape & tight
If they have those clamp on ends buy new
cables that have factory ends
Jul 26, 2013 | 1996 Geo Metro
Truck is draining charge and not charging battiers
I just went thru same thing with my 2003 f-350 diesel. I hooked up my horse Trailor and drove to Von's parked went in came back out and truck was dead. I tried to jump it didn't work. Then over next two hours two tow truck Drivers hooked up to both batteries full power charge direct to my truck and would not start.
End story required two new batteries alternator and cilanoid discussed above. In other post. Also contributing to the cause was really badly coroded cables they looked good at the connection point but wher discovered to be coroded inside the tubing just above the end connections so bow it has all been replaced and I have had no trouble since. Hope this helps. Tanya
Jan 23, 2013 | 2003 Ford F350 Super Duty DRW SuperCab
Problem with a 2006 ford focus My battery light cam on the other day and i brought it to autozone. Checked the battery and it was bad. Got a new battery put in and checked it again. The battery and...
The charging system on your vehicle is computer controlled . Your vehicle is a rolling computer .The instrument cluster has a microprocessor inside , there is also a body computer ( SJB ) smart junction box , Engine computer etc... they all communicate on a serial data network , C.A.N - controller area network . It's hard to know what's wrong when you don't know how it works . There could be codes stored in the computers , these will not always turn on the check engine light .
Ford Smart Charge System Alternator Not Charging
How to Diagnose Controller Area Network CAN
Mar 25, 2017 | 2006 Ford Focus
Well first thing to start is it is a 1990 stanza xe with 160000 original milage and it started fine on sunday then went to go to work on monday went to start it and it tried to start bogged down and the...
Your car probably has an aftermarker remote car starter module installed that you reset, by changing the battery. It has nothing to do with your actual car starter. You will need to shut down(valet) or uninstall that aftermarket remote car starter module to get it to stop trying to start your car with no keys in the ignition.
May 21, 2010 | 1990 Nissan Stanza
I just put a new alternator in my car and the
You could also have a bad battery. If it's putting a strain on the charging system, it will undervolt the whole system. And you need an OBDII sensor reader to get rid of the shifting problem. Your transmission went into limp home mode because of the undervolt. Disconnect the battery for a couple minutes, reconnect the battery and restart the car. Then disconnect the negative cable while the car is running. If the battery light goes off with the cable off, your battery is bad. The problem with electrical devices is that when one thing goes bad, a lot of things go bad because of the first thing. If that doesn't help, take your alternator back to where you got it and have them test it.
Apr 15, 2010 | 1999 Oldsmobile Alero
My metro wont start at all with a new battery
I have had a similar problem which resulted from a worn starter motor. You say you put in a new battery not just charged the old one right? With my car, the engine would make a single click noise when i tried to start it. that was it. music played lights would go on but no engine. Check with your mechaninc if you think it might be the starter. I dont want you to buy a new one and realize your starter was not the problem
Apr 11, 2010 | 1999 Chevrolet Metro
Charging sytem in my 1999 f-150
replace battery cables if they are very old .check alternator wires fuse and fuse link.also check belt.
May 14, 2009 | 1999 Ford F150 Regular Cab
1992 Honda Accord DX will not start, gets spark, gets fuel
check if its getting spark if it is i would check the main relay very common problem .if no spark then i would check the ignition ignitor located in the distributor one last thing to check would be the ignition switch
Feb 25, 2009 | 1992 Honda Accord
After case swap, NDS powers on 2 seconds, screen flickers white, then goes out
this is almost the same thing that that happened to my lil brother ...what happened with his (which probably happened to yours) was that that ds,s have batteries and sometimes they just were-out no matter how old or young the ds is thats your problem you just need to et a new ds
Dec 28, 2007 | Nintendo DS Lite Console
Health & Beauty Logo
Top Everest & Jennings Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Louis Smith
Are you an Everest & Jennings Health and Beauty Expert? Answer questions, earn points and help others
