Question about Rheem MSR50245 Marathon Electric Water Heater 50 Gal
Rheem marathon tripping breaker
Tripping breaker
  • Rheem Master
  • 5,089 Answers
Turn power off. Open covers and inspect for burned parts.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#trip-breaker
Test elements. Marathon takes specific element, and does not use generic element from hardware store.
http://waterheatertimer.org/How-to-test-water-heater-element.html
Posted on Oct 27, 2012
4 Suggested Answers
  • 351 Answers
SOURCE: I have a rheem 81VP2S Electric water heater it
Hi , when a breaker trips immediately, that can indicate a problem in the circuit. But the circuit stays on for a bit , then trips, so there is a problem with the heater. Could be that a thermoastat or heating element is shorted out. You can replace these items yourself, I would check the heat element first. Or there may be some corosion residue around the heater terminals.
Posted on May 03, 2010
SOURCE: Rheem 50 gal keeps tripping breaker. What is the
Do not touch water heater that is tripping breaker.
Open following link for troubleshooting steps:
http://waterheatertimer.org/Test-electricity-to-water-heater.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on May 27, 2011
  • 349 Answers
SOURCE: my rheem 50 gal water
Check all wiring at water heater and possible upper thermostat is bad, and in need of replacement.
Posted on Aug 15, 2011
The thermal breaker keeps blowing
Replace the limit, by tripping often they become even more likely to nuisance trip.
Apr 29, 2016 | Stiebel Eltron TEMPRA 24 Tankless Water...
I cant get the water temp below 125 and I need to for our day care. I have the lower thermostat set to 110 and it still is 125 to 130 degrees. Is there something else I need to do. There is a upper...
You have marathon water heater?
Thermostat is probably bad. Has gone out of calibration.
Replace both upper and lower thermostats for $25 from local hardware store, takes about 20 minutes, turn off power, take photo of wires before starting. These thermostats can be adjusted all the way down to 90 degrees, and then dial up a bit to reach 110.
Copy following link for instructions how to replace thermostat yourself.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
If problem continues, then replace both elements.
Elements are special order made specifically for marathon.
Requires 1-7/8" socket to remove elements.
Upper 3800 watt, order part SP610130
Lower 3800 watt, order part SP210197
http://hometips.me/Mar/Rheem-Marathon-parts-2.pdf
http://waterheatertimer.org/How-to-replace-water-heater-element.html
More information about Marathon:
http://waterheatertimer.org/Review-Rheem-Marathon-water-heater.html
Gene
h
Aug 26, 2013 | Rheem MR105245 Marathon Electric Water...
Rheem marathon vacuum valve
Copy following link for Rheem marathon parts and resources:
Add a comment March 2013 and describe problem in detail.
Mar 22, 2013 | Rheem MR50245 Marathon Electric Water...
Boiler is not turning on
Check the breaker box for a tripped breaker, it should be a dual breaker and if only one side trips, it will not heat. If breaker vibrates, chatters or smokes, it must be replaced.
Feb 20, 2013 | Water Heaters
Rheem Marathon Water Heater leak at pressure relief valve
Unless you are getting more than 150 PSI, you should just replace the valve. It has dirt in it.
Dec 27, 2012 | Rheem MSR50245 Marathon Electric Water...
Electric shower just installed cuts out at fusebox after being on for about a minute
10-20-12
Circuit breaker is tripping on electric shower?
This could be absolute danger until more information is known.
1) Breakers trip because they sense heat, because the wire size is too small, or breaker size is mismatched with wire. Or breaker is loose on busbar.
Copy following links to determine correct wiring and breaker:
http://waterheatertimer.org/Color-codewire.html
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
GFCI circuit breaker will trip because of same heat condition described above, and also trip if ground fault is detected.
Water leaking into element will trip GFCI.
Absolutely you need to get this problem fixed before shower is put back into service.
Call electrician, or the installer, or the manufacturer, or all.
http://waterheatertimer.org/How-to-wire-GFCI.html#spa
Oct 18, 2012 | Rheem EcoSense by 7.4 GPM Tankless Water...
I have a Rheem Marathon 105 gal. electric hot water heater. No hot water ....
Check 240 circuit breaker.
Open top cover on water heater and push in ECO red reset button.
If reset button will not reset, then replace thermostat.
If reset is not tripped out, then either upper thermostat is bad, upper element is bad, or water heater might be getting 120V instead of 240V.
If you have some hot water, then best suspect is lower element.
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
Upvote the help.
May 26, 2011 | Rheem MR105245 Marathon Electric Water...
Rheem MSR50245 Marathon Electric Water Heater 50 Gal Logo
272 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
