Question about Magic Chef 9512 Electric Single Oven
Oven igniter does not light unless hit
We have a 1995 Magic Chief single oven. To start the oven, even since we got it, I would turn on oven, wait about 30 seconds and then take a wooden spon and hit the igniter and it would light. The problem is that if I baked something a long time and oven turned off (as too hot), it would never turn back on unless I hit igniter agin (which I have trouble doing as oven is now too hot). the igniter was made by EATON Controls in Illinois with following specs: G-LP .5 psi, 3.03/3.3 VAC, 3.3/3.6amps. I now want to bake more often than in past. What should I do
    Sergeant:
  • 311 Answers
You can check you connections to see if loose wire nut.normaly people will say they hit the oven safty valve and gas will come out.the amp draw on that ignitor is as ive been taught 3.2 to 3.5 if low than that it will have a hard time opening the safty valve.ive sold and installed 100s of ignitors and a few valves.hope that helps.god bless tom
Posted on Jan 03, 2009
MY MAGIC CHEF, CONCEPT SERIES, W/MAGIC CONTROL CENTER DOESN'T LIGHT.
I have a Magic Chief Concept Series oven - Replaced the Thermo-coupler and the control switch. I now have a pilot light but the thermo-coupler doesn't get hot enough to light the burner, But if I take a lighter and put it on the thermo-coupler it will but when I take if off it shuts off after a few seconds. Could you please give me Ideas of what could be wrong
Dec 18, 2012 | Magic Chef Ovens
Electric ignite r glows but oven doesn't light
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems
Replacing the Igniter
heatman101
Jan 16, 2011 | Magic Chef 9122 Gas Single Oven
Magic Chef: 9122: ingniter works and turns oven on BUT after a few minutes it turns itself off and later it turns itself on again and so on. Igniter problem or thermostat problem?????? Thank you for your...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Nov 11, 2010 | Magic Chef 9122 Gas Single Oven
Oven will not light. burner won't even light if I try lighting it with a lighter. I thought maybe it was the igniter but am wondering if the burners go out on these. This is a problem that has been getting...
heatman101
fdfsd
Jun 29, 2009 | Magic Chef 9122 Gas Single Oven
I just cleaned by hand by magic chef wall oven and now I can't
Pilotless ignition means that a hot surface ignitor lights the oven burner. It does take a little bit of time to light the burner. Maybe 30 seconds. If you want to make sure it lights take the bottom panel out from the oven and observe the hot surface glow and the burners light. No real danger as the gas valve will only open after the hot surface ignitor has satisfied the gas valve. Let me know how it goes. ken
Jan 02, 2009 | Magic Chef 9122 Gas Single Oven
THE OVEN WILL NOT HEAT
How old is the unit? Sometimes the igniter can glow but if it isn't drawing the right amount of power to open the gas valve then that is the safety that is built into the oven... So unless the power requirement is meant gas valve will not light. Even though the hot surface igniter is glowing red hot. chances are the igniter is bad. Let me know what turns up. ken
Dec 03, 2008 | Magic Chef 9112 Gas Double Oven
How to light Oven Pilot for Magic Chef stove 31000 PAW
There is a cover plate that has two screws holding it down. Inspect the pilot area and you will see a hot surface igniter sitting right next to it.. That is what lights pilot and then the pilot lights main burner. You need a new igniter. Also do not touch any part of the hot surface igniter as human oil will shorten the life of part.
Nov 25, 2008 | GE JGRP17 Gas Single Oven
Magic chefa313-230lw gas ignitio
hi .thanks for the question . A very common problem with gas ovens replace the igniter thanks the appliance doc
Sep 29, 2008 | Magic Chef 9512 Electric Single Oven
Stoves oven
check for 110 volts at the igniter if you do have it then change the igniter... whirlpoolpartssurplus.com
May 19, 2008 | Magic Chef 9122 Gas Single Oven
Magic Chef 9512 Electric Single Oven Logo
137 people viewed this question
Top Magic Chef Ovens Experts
Dan Webster
Dan Webster
Sal De
Oloyede Monsuru
Are you a Magic Chef Oven Expert? Answer questions, earn points and help others
