Question about 74 1974 Delta 88 5.7L V8 Water Pump
Finding location of heater blend door on delta88
    Problem Solver:
  • 30 Answers
Under dash
Posted on Apr 14, 2014
Where is rhe air temp. Door actuator in a 2003 ford 450 truck
Ford Superduty Erratic Temp Blend Door Actuator Removal - YouTube
? 12:29
https://www.youtube.com/watch?v=dYPOtin3JUk
Dec 1, 2013 - Uploaded by FordTechMakuloco
Only buy the Ford Actuators, you can get them cheaper here- ...
Simple how to fix blend door heater a/c actuator 2002 - 2008 ford ...
? 7:12
https://www.youtube.com/watch?v=EEWuJuhCtmc Aug 24, 2013 - Uploaded by kirk colombo
Simple how to fix blend door heater a/c actuator 2002 - 2008 ford explorer noise .... I literary just finish ...
08-10 Super Duty Blend Door Actuator Location - Dual System ...
? 1:24
https://www.youtube.com/watch?v=s7awF2fTKf4 Mar 22, 2012 - Uploaded by srmastertech
Here is a quick view showing the location of the temp blend door actuators on the Ford Super Duty's with ...
Ford blend door fix - 15 minutes - YouTube
? 3:22
https://www.youtube.com/watch?v=wsjGxreGlkA Jul 21, 2013 - Uploaded by SoonersWarriors
Ford blend door fix - 15 minutes. SoonersWarriors. Loading ... Ford Vehicles: Frequent Blend Door Actuator ...
Blend Door Actuator Ford Super Duty 08-10 - YouTube
? 9:45
https://www.youtube.com/watch?v=mbzjCPYENZQ Oct 4, 2013 - Uploaded by MostExcellentDude
This applies to 2008-2010 F250 and F350 with the dual climate control. This video shows the locations for the ...
blend door actuator 2003 ford f450 Google Search
Aug 16, 2017 | Ford Cars & Trucks
Need to find location of blend door for heater on dodge caravan 2007
Usually it is a shaft that attaches to the blend door and the actuator. Sounds like the door is broke and the HVAC unit must come out to replace the door as the unit has to come apart.
Dec 01, 2013 | Cars & Trucks
Heater on nissan almera
That noise is the heater and AC air temperature control electric blend door motor trying to move a duct door that is sticking due to heat warping. You will need to remove the entire dash assembly and replace the blend door. This door is located between the AC core and the heater core and "blends" the air from each (hot from heater core and cold from AC core) to give the desired air temperature,.
Oct 11, 2012 | 2001 Nissan Almera Tino
2004 monte carlo blend door where is it located?
The blend door is under the dashboard where the air ducts are located for your AC.
Sep 04, 2011 | 2004 Chevrolet Monte Carlo
I have no heat. the blower works but no heat coming out? the guy i just bought it off of said he just replaced the heater core??? help?
check to see if both heater hoses goto heater core is hot, if they are then you have a blend door actuator problem
if one hose is hot and the other is colder then you have air pocket in the system.
Feb 28, 2010 | 2005 GMC Canyon
Were is the blend door located on the 2004 jeep grand cherokee overland
blend doors are located in the heater box behind the dashboard.. if you are having heating problems because of faulty blend doors, try heatertreater.com they have a permently quick fix solution that really does work. i have fitted quite a few with no problems, even better heat than standard jeep blend doors..
hope this helps
Dec 24, 2009 | 2004 Jeep Grand Cherokee
I HAVE A 98 JEEP GRAND CHEROKEE MY HEATER BLOWS HOT AIR ON ONE SIDE COLD ON THE OTHER I NEED A DIAGRAM OF MY HEATING SYSTEM TO SEE WHERE MY DOORS ARE LOCATED
hi
the blend doors are located behind the glovebox were you will find the heater box the doors are inside this, to remove the heater box you will have to take out the complete dash. try heatertreater.net they have a diy easy fix solution to replace damaged or broken blend doors, i have fitted a few off these kits all work fine with no problems..
hope this helps
Dec 14, 2009 | 1999 Jeep Grand Cherokee
No heat Heater core is hot
If heater core is getting coolant circulating through it then you may have a temp blend door, or blend door actuator not working properly. The blend door is located in the air box under the dash, and the actuator is located on the air box. You may be able to visually check the operation while turning the temp knob, by locating the coresponding actuator on the air box and monitoring the movement. If it is moving ok and still no heat then the blend door, or lever is broken, which will require removal of the dash.
Oct 17, 2009 | 2001 Dodge Ram 2500 Truck
Air conditioning silverado
The problem is in the heater box. To be more specific, the blend door. Check blend door operation and blend door motor. Located right side under dash. Remove blend door motor, with vehicle running, move switch from panel to defog and see if blend door motor moves.
Jul 25, 2009 | 2005 Chevrolet Silverado
96 LINCOLN TOWNCAR STUCK ON HEAT ONLY !
The heater and a/c blend door actuator motor is located behind the center of the dash just below the windshield. The steering column must be detached and lowered and the dash must be removed to access the blend door motor.
Jul 07, 2008 | 1996 Lincoln Town Car
74 1974 Delta 88 5.7L V8 Water Pump Logo
23 people viewed this question
Top Oldsmobile Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
George Agios
George Agios
Robert Swatek
Robert Swatek
Are you an Oldsmobile Vehicle Part and Accessory Expert? Answer questions, earn points and help others
