Question about Panasonic DECT 517 Cordless Phone
V-tech 5.8 cordless and just installed the vonage I can call out but it want ring?
I have Vonage phone, and TimeWarner cable. My
Remove your router for the vonage equipment. Direct connect to modem. Does your internet ****? If yes its TW issue. If no its Vonage issue. Try it for a day
Hope this helps!
john
Oct 03, 2009 | Computers & Internet
Two phones in use with Motorola VT1005 result in very low volume
disconnect the POTS line incoming to your home on the outside of your house. This will make the phone wiring within the house a standalone network. Plug the Line 1 jack of your TA into any available phone jack and the remaining jacks in the house will be energized. This will create the same environment as you had with POTS.
Jun 07, 2009 | Panasonic KX-TG2740 Cordless Phone
How to set the number of rings before the machin answers
Log into your Vonage account and change the number of rings or seconds to intercept for VM. In my Packet8 service, I can set a number of parameters for dual ring, intercept, and/or turn voice mail on and off. The last time I worked on a customer's Vonage we could do the same.
Carl
Feb 11, 2009 | Uniden DECT 6.0 Cordless Telephone...
No dial tone on headset 2
If you have a regular phone, then connect it directly to the Vonage phone router. Be sure and connect to the correct port on the router (mine has 2 ports, and I use both, but a single line subscriber would only hook to Line 1).
See if you get a dial tone with the standard phone hooked up (we are testing that the Vonage is good.first, then we'll deal with the Uniden phone.). If not, what do the light's indicate on the Vonage router? Have you subscribed to Vonage? Do you have a cable between your router and the Vonage router?
Reply back back what you find and I can help you more.
Jan 23, 2009 | Uniden 5.8GHz Cordless Phone
Unable to send or receive fax over vonage/dsl
I also have vonage and this fax macine - the incoming fax was going to vonage answering machine.
I went to setup (that little button above and to the right of the OK button to "basic fax setup" and changed my rings to answer from 5 to 2. This will work for me, because I only set it to auto answer when I know a fax is inbound - you might want to adjust so you can aswwer a call if you do not have a dedicated fax line.
Good luck
Dec 05, 2008 | HP OfficeJet 7310 All-In-One InkJet...
My in-laws have vonage telephone service with comcast internet, before they just had at&t with no problems. Now when they are having a telephone conversation the connection seems to cut in and out and...
With choppy audio and one-way audio, either party on the call hears the audio breaking up, or no audio at all. Dropped audio is when a call is in session and both parties are unable to hear each other.
  • From your Vonage account, there is a feature called the bandwidth saver. This feature controls the amount of bandwidth used for a phone call. Try adjusting the bandwidth saver to either medium or normal. After you adjust your settings, test and see if there is a difference in the audio quality. Please note that when you change bandwidth saver it could take a few minutes for the device to reboot and take the changes. From your Vonage account, there is a feature called the bandwidth saver. This feature controls the amount of bandwidth used for a phone call. Try adjusting the bandwidth saver to either medium or normal. After you adjust your settings, test and see if there is a difference in the audio quality. Please note that when you change bandwidth saver it could take a few minutes for the device to reboot and take the changes.
  • Reboot all of your devices (Vonage device, any routers and cable / DSL modems). How Do I Restart My Phone Adapter and Network Devices?
  • Ensure that your Vonage device is at least four feet away from any other device.
  • Ensure your Vonage device is in a well ventilated area to keep from overheating.
  • Ensure no file sharing, P2P applications, or large downloads are running while you are using the phone. These activities can use up most of your bandwidth, leaving little left for your calls.
  • Connect your Vonage device directly to your cable / DSL modem, if it is not already. If this helps the audio quality, then the problem is occurring between the Vonage device and modem.
  • If your Vonage device connects to another router and not directly to your cable / DSL modem, try disabling any firewalls or SPI (Stateful Packet Inspection) on that router. Click here to learn about firewalls and SPI.
  • If you wish not to disable your firewall, then you can port forward the Vonage traffic to the adapter. Click here to learn about port forwarding.
Wireless Routers and Cordless phones — If you have a wireless router and a cordless phone:
  • Ensure all wireless devices and cordless phone bases are at least four feet away from each other.
Home wiring — If you are using home wiring:
  • Ensure the land line has been disconnected in the Demarc box. Ensure the land line has been disconnected in the Demarc box.
  • Ensure there are no more than five phones connected through the house wiring. The signal fades as more phones are connected to house wiring.
  • Test with one phone directly connected to your Vonage device. If this fixes the issue, there may be a problem with your house wiring.
If you have made it through this checklist and you are still experiencing an audio problem, our first class customer service is available to assist you. Please have handy your account ID, phone number, name of your internet service provider (ISP), and model numbers for your Vonage device and any other devices in your network.
Dec 03, 2008 | Vtech mi6896 Trio Cordless Phone
No connection
deregister headsets and then run register again
Jun 09, 2008 | Vtech 5.8 Ghz Handset Cordless Phone...
Have vonage fax and phone service
I am new in the network field.How can i set up a LAN net work using 5 hosts.What are the devices that I need to set up this net work?This is my email address.You can send it there:tunjiman23@yahoo.com.Mnay thanks
Apr 02, 2008 | NetGear RangeMax NEXT WNR834B Wireless...
Vonage phone servive
usually when u get an error code 003, it means ur internet is out, if u have problems getting online it effects the phone. if u have bad cables or an old modem or like wireless or satelite isp's can cause this issue as well, try power cycling the whole network modem-vonage device. al
Mar 09, 2008 | Vtech mi6896 Trio Cordless Phone
Panasonic DECT 517 Cordless Phone Logo
29 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
