Question about HP Officejet 5610 All-In-One InkJet Printer
Cartridge jam won't clear HP 5610v
After installing a new print cartridge, the carraige is stuck and now, won't slide across so I keep getting an error about the jam and the carraige makes a bunch of noise trying to move. I've jiggled it but can't seem to get it to work again. Any ideas? Thanks alot.
  • Anonymous Jan 27, 2009
    I have the exact same problem
I had the same problem and just got it to work. go to
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00577763&lc=en&dlc=en&cc=us&lang=en&rule=22243&product=441125
go to the section "Moving the carriage" turn on printer and then unplug power. If you still cant move the carrage then remove both toner cartridge and all the trays. Then completely disconnect printer and stand it upright (so paper feed and cartridge tray is on top) Look thru the paper feed area to the left side of toner carrage and you will see a little plastic tab around the bottom back of the carrage. That tab is suppose to be inside a track on the bottom of the carrage. I think that when we put in or took out toner we must have pushed it to hard and that piece jumped out of the track and has "locked" the carrage. I just pushed the carrage up carefully and used a letter opener to move the plastic tab back into place (tab is spring loaded) print working fine now. Hope this solves your problem
Posted on Feb 15, 2009
  • bayla
    bayla Jan 28, 2014
    Hi SunriseFlower. I know it's been a few years since you posted the solution above. However, I am also having trouble with a little black piece that is supposed to slide into the left side of the carriage cradle on my officejet j5780. I think we are referring to the same little piece. It was hooked to spring, and I could not tell where the other end of the spring was located. While I was trying to jiggle this little plastic piece, I accidentally disconnected the spring, and it flew into the empty space around the "service center". It seemed like this piece was not adjusting into place in order to keep the carriage docked, and then releasing, to allow the carriage to move out of the service station, when ready to print. Before I can continue my pursuit of whether this is the cause of my carriage jamming, I need to re-attach the spring. But I don't know what this piece is called so I can not really search google for directions of where to connect the other end of the spring. Without the spring attached, it definitely will maintain a carriage jam, because it's not being moved gently from one position to the other. It's just staying in one place, and blocking the carriage from moving altogether. If you can figure out what this piece officially does, or what it's called, I would be very appreciative!
Whenever i try to print it does 1/2 page then the cartridge keeps getting stalled on one side. Error message on screen says print cartridge stalled, error message on printer says clear carraige jam. Cannot...
If there's a carriage jam. While the printer is turned on, Open the access door of you printer.
If the carriage is stuck at the left side, try moving it manually by hand to the right most part of the window. If it's stuck on the right, try moving it by hand to the left.
If you've already done that. While the printer is turned on, unplug the power cord from the back. Close the access door. And then plug it back in.
Make sure you restart the computer first just to avoid documents getting stuck in the print queue. Try printing again. Usually it does the trick.
Feb 03, 2011 | Office Equipment & Supplies
Carraige jam. Screen says to clear carriage jam
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
May 08, 2010 | HP Photosmart D5360 Printer
CARTRIDGE FOR 5610V
Black Cartridge HP 27
Color cartridge HP 22
Photo cartridge HP 58
Jan 27, 2010 | HP OfficeJet t45 All-In-One InkJet Printer
Print Cartridge stuck
Look at the pad on the right side of the printer under where the ink cartridges are loaded. It may have ink deposits built up into lumps which interfere with the movement of the cartidges on the rod. Clean the deposits by scraping the lumps and removing all debris. This worked for me.
Jan 23, 2010 | HP PhotoSmart 7550 InkJet Printer
Carriage Jam - HP Officejet J3680 All-in-One
the silver bar the carrige slides on has lost all its lubrication. Try putting some chapstick on the silver bar
Sep 30, 2009 | HP Officejet J3680 Multifunction Printer...
Get error message on my HP Photosmart 7760 that "Print cartridge cradel stuck. Clear jam then press okay"...but there is no jam. :( Help...thanks.
jam not on the paper but, check the space where the printhead slides on, see if there is something blocking the path
Jun 26, 2009 | HP PhotoSmart 7760 InkJet Printer
Paper Jam/Cartridge can't move
Hello Julie how are you? Regarding on your problem try to remove your cartridge then installed it properly. Or try to open the back of you printer and try to see if their is a small piece of paper left during a paper jam incedent you have.
Jun 16, 2009 | HP Officejet 5610v All-In-One InkJet...
Carraige jam
If you can move the cartridge carrier, move it all the way to the left, turn the printer off and then on again.
Your printer may not be parking the cartridge completely so check the area that the cartridge rests over when parked for a sponge or wiper that is out of place.
I've pulled broken light bulbs, paper clips among the many things that can cause the cartridge from parking in the rest stop.
Regards,
Worldvet
Jul 09, 2008 | HP OfficeJet 4215 All-In-One InkJet...
Cartridge carraige jamming
plz send it for repair as it is due to hardware failure
May 28, 2008 | HP PSC 1210 All-In-One InkJet Printer
Print cartridge cradle is stuck ican't find where it is jammed
This might help . . . Mine finished printing one doc & then made a terrible noise & sent a message to my screen that "print cartridge cradle is stuck." When i opened door, i could see it was stuck off to the left side so left cartridge was obscured. I could not get it to budge, although i kept turning it off, gently pushing & turning it back on. Finally, i got my hand inside & determined that the little door to the left-side cartridge had popped open & was causing it to remain stuck. After some struggles (turn off printer first!) i was able to maneuver it around & close it tight. Now, all is well . . .
Apr 16, 2008 | HP Office Equipment & Supplies
HP Officejet 5610 All-In-One InkJet Printer Logo
574 people viewed this question
Seeker5211
Seeker5211
