Question about Technics Audio Players & Recorders
Only sound from 1 channel but view meters working on both channels Techniques RS-B18
This is a DBX and dolby B and C Would not care as have 2nd deck but this is the only one with dbx and some of the tapes were recorded with dbx
  • Edward Oct 28, 2012
    have cleaned head with alcohol No better. Checked cables and they work fine. Any ideas?
  • Technics Master
  • 1,258 Answers
On the easy side it could be a dirty switch. On the hard side it might need to go to a Technician as there could be an open capacitor or other component failure. The unit can be fixed if given to the right person who is familiar with the cassette deck repair. I have been doing it for 40 some years so far.
IF you need my help, E mail me skywavebe@sbcglobal.net
Posted on Oct 29, 2012
4 Suggested Answers
  • 319 Answers
SOURCE: akai gx 747 dbx reel to reel need repair and service zip 95624
What problem(s) are you having with unit?
Posted on Apr 23, 2008
  • 54 Answers
SOURCE: Nakamichi CR-4 Only Recording on One Channel...need help!
Hmmm.....heres a really stupid question but........is the head clean ? There may be a bit of oxide shorting the one side of the head out. Try cleaning the head with a q-tip and some 99% pure isopropyl alcohol. If you have done that ( you seem to be more knowledgeable than most ), I would suspect either the circuit that drives the right channel record head, or the head itself. Is the head running flat against the tape?. Is there a record/play relay or record relay somewhere in the circuit ?. I think at this point you really need a schematic. Do you have the AC oscillator signal ( bias ) present on the right record head ?. I would try this first, then look into a manual.......Good luck...Rob
Posted on May 09, 2008
skywavebe
  • 1258 Answers
SOURCE: Technics RS-TR272 dual cassette deck
Ahh, Another Dual cassette deck. These are typically not worth a repair charge. I went looking for a service manual but Hi Fi Engine did not have one but they had a Owners Manual. Any unit that has a specification as to wow and flutter starting new at .18% was never made to be a long lasting deck of any quality. I don't like to be negative about people equipment but you might be better off getting a better deck from the start. If you think it is worth the repair, then send it to someone but I don't think you will want to sink $100 into a unit like this.
I am not saying it is unrepairable but that with what you come out in the end you could have made a better choice for a deck to buy.
It is probably a bad solder joint or bad capacitor on the circuit board.
I am in Chicago and would look at it for you if you want.
Posted on Oct 17, 2012
Tip
How to install a subwoofer and amplifier
When installing any electrical components always remember to unhook the battery. First thing you want to do is run your ground cable from a volt meter to a body or frame nut or bolt near by in the trunk or hatch area a shorter thicker ground is best then connect the other end of your volt meter to your battery cable that will need to be run through the firewall and connect to the positive battery terminal. Also VERY important make sure you have installed a fuse on the wire in between the amp and the battery. after you have connected the battery cable and ground to your meter it will light up or give you the correct reading for your ground, if not run the ground somewhere else until you have found the right spot. pull out your stereo, for stereos that are made to be compatible with an amp there will be multiple rca jacks in the back of the stereo. For a sub woofer you want to hook the rca cable to the rear or sub labeled rca jacks. Then run your amplifier remote wire to the remote wire protruding from the back of your car stereo. After that you can run the ground and battery cable to the correct slots. Now connect your sub via rca and your done. making it fit correctly is up to you. If you do not have an amp with a subwoofer out then you can take the wires from your sub and bridge the connection to your amp and get enough power, take the positive wire to your sub and hook it up to the positive terminal of channel one on the amp then take the negative wire from your sub and hook it into the negative terminal on channel two and your done.
keywords: subwoofer, fuse, wiring, car audio, car , car audio install, speakers, dvd player, in dash, acura integra gsr del sol honda civic itr ls b16 hatch coupe jdmkey words: honda acura integra gsr itr jdm del sol coupe hatch ls si boosthonda, acura, civic, crx, si, hx, two door, integra, DA, EF, EG, EK, DC, DC2, DC4, hatchback, four door, GSR, LS, GS, RS, EX, DX, VX, engine, transmission, VTEC, V-TEC, non-VTEC, B18, B18A, B18B, B18A1, B18B1, B16, B16A, B16A2, B18C, B18C1, B18C5, D16, D15,key words:VTEC, V-TEC, non-VTEC, B18, B18A, B18B, B18A1, B18B1, B16, B16A, B16A2, B18C, B18C1, B18C5, D16, D15, integra civic, b18, turbo spoon,JDM,EK9,da6,eg,civic,HB,honda,acura,turbo, acura Honda Civic Integra EG6 EK9 EK4 DB8 DC4 ITR CTR civic honda jdm integra ls gsr b16 b18 civic si crx k20 swap hatch coupe lx eg ek ef b20 accord prelude sedan trade sir type-r lsd b18c5 b18c1 turbo supercharger b-series integra da dc eg ek ex gs rs ls gsr lsr rs si sir sirg wanted prelude accord transmission eg ef ek em ep civic integra del sol s2000 s2k rsx accord gsr type r itr ctr vtec v tec honda acura blades ls mesh rota volk 4 lug 5 lug b16 b18 h22 h23 b20 k20 d16 d15 b series h series d series turbo all motor eg ek da ef crx dc2 dc5 dc em ej ap1 f20 prelude jdm edm ukdm doch b18a b18 b18c1 b18c5 rota rsx integra DA ef eg ek hx rims si rims gsr blades ls distributer distributor rota rotor aem injen akimoto parts works obx hatchback honda acura integra ls rs gs gsr type r civic dx cx ex hx lx si crx hf del sol oem jdm da da9 da6 db dc dc2 ef ef8 ef9 eg eg6 motor integra da dc eg ission, VTEC, V-TEC, non-VTEC, B18, B18A, B18B, B18A1, B18B1, B16, B16A, B16A2, B18C, B18C1, B18C5, D16, D15, suspension, break, brake, greddy, tanabe, cusco, zex, nos, turbo, drag, hks, aem,subwoofer powered subwoofer subwoofers svs subwoofer
home subwoofer car subwoofers best subwoofer subwoofer cable
subwoofer reviews car subwoofer klipsch subwoofer subwoofer wiring
home theater subwoofer yamaha subwoofer subwoofer amplifier
jbl subwoofer subwoofers for sale jackhammer subwoofer subwoofer boxes
hsu subwoofer sunfire subwoofer kicker subwoofers pioneer subwoofers
subwoofer car audio car audio subwoofers powered subwoofers
cheap subwoofers home subwoofers 15 subwoofer
subwoofer placement computer subwoofer active subwoofer
velodyne subwoofer mtx subwoofer kicker subwoofer subwoofer box
infinity subwoofer home audio subwoofers
car speakers and subwoofers
cheap subwoofer
home theater subwoofers
rel subwoofer
wireless subwoofer
jbl subwoofers
10 subwoofer
subwoofer speakers
8 subwoofer
bazooka subwoofer
subwoofer enclosures
custom subwoofer boxes
on Jan 28, 2011 | Honda Civic Cars & Trucks
My Sanyo DP23845 23 In. LCD Television does not have any options under set up beside color-how do I add channels?
HDTV inherently provides a superior sound quality simply because the sound of HDTV is digitally transmitted. The difference in sound between an HDTV television and an analog television is rather noticeable. In fact, it is directly analogous to the difference between the music on CD's compared to the music on audiocassette tapes.
The difference in sound quality provided by HDTV televisions and programming does not end there. Many HDTV programs are also broadcast in Dolby Digital 5.1 surround sound, but in order to take full advantage of this technology, it is necessary to have the right equipment.
Dolby technology has been created by Dolby Laboratories, Inc. This technology is the most renowned provider of digital audio technology. Also, Dolby Laboratories is known for reliable and superior products. For these reasons, Dolby Digital Surround has become the standard for HDTV. Many television manufacturers substitute their own surround sound systems, but they cannot live up to the reputation and performance of Dolby. Therefore, it important to check the specs on an HDTV television before buying in order to ensure that it uses Dolby Digital Surround.
When using Dolby Digital Surround Sound, there are three options for set up. The first option is to buy a television with high quality center channel speakers, woofers, tweeters, and Dolby technology installed in the television. With this option, it is unnecessary to buy addition equipment to take advantage of Dolby Digital Surround Sound.
Another option for taking advantage of the Dolby Digital Surround Sound with an HDTV is to connect an external set of surround speakers to the television. With this option, the surround sound set up includes a front pair of speakers, a surround pair of speakers, a center channel, and a subwoofer. Sometimes, the front speakers are "powered towers." This means these towers include subwoofers.
The placement of these speakers is very important for the quality of the surround sound. The Center Channel Speaker should be centered either above or below the television. The Front Left and Right Speakers should be placed in an arc formation in line with the Center Channel Speaker. The Surround Left and Right Speakers, on the other hand, should be placed to the left and right sides behind the listening position. Many people choose to wall mount these speakers.
The third option for taking advantage of the Dolby Digital Surround System included in an HDTV television is to use an external set of front speakers can be connected to the HDTV television. This configuration is useful if there is not enough room to set up the external surround sound system and the HDTV does not come with Dolby Digital Surround installed. This isn't true surround sound, but it is a viable alternative to those who can't take advantage of the first two formats.
The audio and video outputs of the DVD or VCR can be connected to the AV receiver's video outputs. If a separate DVD and VCR need to be connected, one can be connected to the VCR1 connection and the other can be connected to the VCR2 connection. The AV receiver's VCR video and audio outputs should then be connected to the audio and video inputs of the DVD and/or VCR. In this way, the DVD and/or VCR will be able to record video signals that come through the AV receiver and the VHS tapes and/or DVD's will be able to be viewed on the HDTV.
To take full advantage of the Dolby Digital Surround Sound technology, one of the video outputs of the DVD player and/or VCR needs to be connected to the AV receiver. The digital coaxial audio or digital optical connection must also be connected to the AV receiver.
How do I connect my CD player?
A CD player can be connected to an AV receiver. The CD player's digital audio outputs can be used to connect the CD player to the AV receiver. A CD-Recorder can also be connected the AV receiver by using the Audio Tape Record/Playback input/output loop connections. In this way, the CD-Recorder will be able to function much like a standard audiocassette deck.
What else will I need?
Besides the basic electronic equipment needed to set up Dolby Digital Surround Sound, it is necessary to have connection cables. This includes video, audio, and loudspeaker connection cables. These cables need to be at an appropriate length in order to set the speakers in the proper position for optimal surround sound quality.
Jul 29, 2012 | Sanyo DP23845 23 in. LCD Television
How do I get the C5 Subwoofer to activate?
Hello
If subwoofer is inactive now, the sound preference settings you set now is wrong.
Before using the remote control for the following
operation
* Set the remote control mode selector to AUDIO
** There are exceptions in the operation mentioned
above. In such a case, follow each instruction
Dolby Pro Logic II*1
# Dolby Pro Logic II has a newly developed multichannel playback
format to decode all 2 channel sources - stereo source and Dolby
Surround encoded source - into a 5.1 channel.
Dolby Pro Logic II has two modes - Movie mode and Music
mode
# Pro Logic II Movie (MOVIE)
Suitable for reproduction of Dolby Surround encoded sources
# Pro Logic II Music (MUSIC)
Suitable for reproduction of any 2 channel stereo music sources
# Dolby Digital*1
Used to reproduce multichannel soundtracks of the software
encoded with Dolby Digital
# DTS Digital Surround*2
encoded with DTS Digital Surround. DTS Digital Surround (DTS) is another discrete multichannel
digital audio format available on CD and DVD software
Jun 19, 2011 | JVC TH-C5 System
Pls send me a connection diagram of how to connect my dbx 215 graphic equalizers to a powered mixer
ftp://ftp.dbxpro.com/pub/PDFs/Manuals/English/dbx2SeriesManualA2.pdf It's all in there. Here is a little extra guidance. if you are getting your left and right channels out through RCA you will need a RCA to 1/4 in adapter Radio Shack carries them relatively cheap. If it's already 1/4 or XLR skip this Left goes into Left in, Right goes into Right in. Then work backwards Right comes out of Right out, Left comes out of Left out. channel 1(left in) and Channel 2(right in) of your powered mixer. you should be set.
Good Luck, Cody J.
Dec 16, 2010 | DBX -215 Home Equalizer
Technics Tape Deck RS-M227X. VU needles jump to the maximum right
More than likely the pre-amp IC has failed! Trace the wires from the VU meters back they should locate the source of the problem. Remember it will be something common to both channels!
Oct 30, 2009 | Audio Players & Recorders
Unit looks to be working fine but I get no out-put on line out. Both 1 and 2 decks were ran and problem is on both decks
Often a micro switch can break that cuts off the sound, look around for them.
Otherwise it sounds like a amp problem. It is also something that common to both channels. Maybe an IC that both channels goes into, or perhaps the IC is not getting power.
Oct 17, 2009 | Technics RS-TR575 Single Dual Cassette...
Bose 901 Active EQ Loop
There's good news and bad news. The bad news is that a multichannel receiver with Bose 901's will only sound right in STEREO on stereo analog material. For one thing, the other speakers around the room are not designed to recieve its Active Equalization and for another, if you engage your Tape Monitor you will not be able to play digital sources. Tape Monitor is for analog stereo material only and on my receiver it disables any digital inputs.
The good news. I have a setup similar to what I think you're trying to do and it works great!
A separate stereo amp for the 901's was my solution. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center and Surround speakers. You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier that would have you cooking just fine (2x100W).
Run the dbx and BSR in tandem with each through the tape monitor loop on the receiver but be advised you can only use them on analog source stero material. However, you can still employ the various DSP options to spread the sound around the room.
At my PC workstation across the room I have a stack of analog processors and sources including dbx 3bx-ds, dbx 120x-ds, BSR Spatial Enhancer, BBE 462 Sonic Maximizer, SS-525x EQ, Carver C-9, dbx-224x, JVC cassette deck, Dual 1249 Turntable running through a Garrard MRM-101 Preamp, Pioneer PDR-509 CD Recorder and the Media Center PC stereo analog channels all running through a dbx 400x Program Route Selector (a godsend) which is attached to my ONE TAPE MONITOR on my Pioneer VSX-36TX Receiver. Of course, I have some of my analog processors running in tandem, too, since the 224x only has three processor and three tape loops.
For listening/recording anything 2-channel analog I engage the stack through the Tape Monitor. For everything else I turn the Tape Monitor off. The nice thing about the stack being separate is that I can doodle with recording and use headphones while the TV/DVD/Blu-Ray do something else.
Jan 10, 2009 | Onkyo TX-SR705 Receiver
Dbx compressor/limiter/gate
Haven't tried this myself, but first thoughts that come to mind are that it sounds like you must have the connections right for things to work when in bypass (which routes the signal straight from the input to the output uneffected). I'd suggest making sure your gate is 'off'. On the DBX turn the 'threshold' knob in the Expander/Gate section of your front panel all the way counter clockwise to 'off'. I would also start with your compression 'ratio' knob turned all the way counter clockwise to 1:1 which effectively turns off your compressor. If you have sound coming through like this then you can start fooling around with the controls to effect the sound the way you'd like.
I'm sure you're already aware that the compressor has separate mono channels and you'd have to hook up right and left through their own compressor channels to have stereo compression.
Dec 26, 2007 | Audio Players & Recorders
89 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
