Question about GE Monogram ZDWC240NBS Stainless Steel Wine Cooler
GE Refrigerator Model ZDWC240NABS not cooling
My wine cooler stopped cooling. It still runs but there's a 'clicking' that sounds as if something is trying to turn on like the compressor, but it doesn't stay on. Not sure what's going on.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 46 Answers
It could be the relay. take off the panel so you can access the compressor. unplug the unit for about a minute then plug back in. Is the click coming from the compressor? Remove the relay from the compressor. You will want to ohm out the compressor to make sure it is OK. Check the windings to ground to see if it is grounded. If not i would recommend a three in one relay. They are cheap and come in various sizes depending on the size of compressor.
Posted on Oct 27, 2012
    Problem Solver:
  • 15 Answers
If it is a clicking sound maybe it is a relay. try replacing that
marka19
  • 1430 Answers
SOURCE: GE bottom freezer began making a clicking noise, will not run
The clicking could be the start relay.If the start relay is bad, the compressor will not start and you will hear a clicking noise in 2-5 minute intervals. The clicking noise is the overload cutting the compressor off when it overheats from trying to start with a bad start relay. To find out if this is bad first unplug the refrigerator. Remove the lower cover from your refrigerator. Then take the cover off that is on the side of the compressor,you will see wires going to this. Now you should be able to see the start relay plugged on to the side of the compressor and unplug it. Now the best way to tell if it’s bad is to shake it. If it rattles, it’s bad and needs to be replaced. If not, most of the time it’s ok. But rather than saying the compressors bad, you might want to replace it anyways because it don’t cost much in most cases (less than $25). If you replace it and it doesn’t work then the compressor is bad and you’ll need you call a repairman. (Note that compressors are very costly and are normally not worth fixing). You can also enter your model # at www.appliancehelponline.com for diagrams and illustrations.
Posted on Apr 09, 2010
  • 108 Answers
SOURCE: Does not cool. Compressor Hot
Sounds like the compressor starting relay. This should be available from from most appliance parts retailers that carry refrigeration parts. It is probably a plug-in relay which is easy to replace. PULL THE PLUG UNTIL YOU GET IT! Constant cycling on the thermal protector will damage the unit.
Ray
Posted on Oct 19, 2008
  • 19 Answers
SOURCE: My GE Profile wine cooler temp does not respond to any temps
Call GE answer center 1-800-626-2000 ask for tech help,have Model # off data plate ready.
Posted on May 09, 2009
aasc
  • 1606 Answers
SOURCE: clicking sound from the relay from the back. Fan shakes & stops.
The correct pt # WR55X10942
Posted on Aug 04, 2010
197jacobs
  • 226 Answers
SOURCE: Have a GE Monogram Wine
it needs freon a certified sevice
Posted on Oct 15, 2010
Wine cooler cools but has a very loud, too loud to ignore, whirring sound when it is in cooling mode. Any ideas?
And when the wine is cooled ... the noise stops?
It's like a refrigerator ... it only operates when it it is reducing temperatures. Once things have cooled, the system cuts out.
If your wine cooler stops making a noise when the wine is cooled ..ok.
Jan 19, 2016 | Refrigerators
My vinotemp vt60 starts cooling then stops
I sounds to me like the compressor is overheating. There is an overload on the compressor itself. Follow the wires where they go into the compressor. There will be a black wire going from the power cord to the overload. These can be purchased at appliance parts stores. Make sure there is no dirt build up on condenser coils or a kink in the tubing.
Jul 30, 2014 | VinoTemp (VT60GNV) Wine Cooler
Beeping will not stop on wine cooler - red wine side
Beeping usually indicates that something has gone wrong. Probably not cooling properly. The water coming out would indicate that the unit has defrosted. Turn the unit back on again and see if the red side is cooling properly. Some wine fridges have independent evaporators which allows different cooling temps in different parts of the cabinet.
Jun 26, 2014 | Danby DWC2727BLS Silhouette 54-Bottle...
Danby wine cooler DWC440 stopped cooling - makes clicking noise
sounds like you need a new start kit or your compressor is lockedup. get a supco 3in1 for fractional hp compressors.wire it in correctly! you only get one chance at the last step.
Nov 27, 2012 | Danby Refrigerators
HH error code? on magic chef mcbc580dbt
I, too, have just seen (late June 2013) the "HH" code on my Magic Chef wine cooler (and it is running too cold and I can't reset the temperature). Have you found a solution since your posting of about 1 year ago?
Jun 27, 2012 | Magic Chef MCWC30MCG Compact Wine Cooler
Wine cooler compressor hums and then nothing.
If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 09, 2011 | Danby DWC283BLS Wine Cooler
It just stopt cooling (wgersdorf@yahoo.com)
Turn the temperature dial to the lowest temperature setting. Wait 24 hours for the wine cooler to reach the desired temperature. Also, turn the wine cooler off and inspect the fan. If the fan if it's running or not.
Lastly, check the compressor.
These are the areas that could make your wine cooler stop cooling; the temperatue settings (Thermostat), then Fan and the compressor.
Check these three areas and let me have a feed back.
Bye for now.
Mar 04, 2011 | Haier BC112G Wine Cooler
My 12 bottle cooler is still cooling OK but it is making a strange loud throbbing or pulsating noise. Is there something I can do to stop this noise?
Mine is too. It\'s the fans they are very cheap and I don\'t think you can find a replacement for them. It\'s the usual stuff made in China that we Americans buy.
Jan 01, 2011 | Wine Enthusiast Silent 12 Bottle Wine...
GE Monogram ZDWC240NBS Stainless Steel Wine Cooler Logo
520 people viewed this question
Top GE Furniture Experts
Dan Webster
Dan Webster
Craig Butler
Craig Butler
Day Coker
Are you a GE Furniture Expert? Answer questions, earn points and help others
