Question about Namco Arcade Classics Plug and Play TV Games
How to open case?
Namco 5 in 1 plug & Play game. Need to open case because wires have become loose, & looes signal. just need to open so a little solder and good to go. just want to know "How To" open case without breaking it, and turning it to scrap parts.
  • Boss Of All Oct 30, 2012
    I just need to know "HOW TO" open game console, top from bottom, so I can get a look inside at workings.
  • Boss Of All Nov 02, 2012
    Can anyone help me with this "issue" of just how to open the case/console for this namco 5 in 1 game? I just want to open the plastic case, and check the connections for loose wires. PLEASE advise.
Under the decals on ether side are four screws remove these and
separate the sides under these you will find white wedges that hold the case halfs together pull out these wedges and open the case. repair unit and Reverse the prosess to reassemble the unit. If you know how to work on electronics you may need to replace the electrolitic capacitors while the case is open. Kill 2 birds with one stone.
Posted on Mar 12, 2014
3 Suggested Answers
Ninja_Rick
  • 119 Answers
SOURCE: I have a namco tv games video game system that is
the input you plug it into....1-2-3 etc.
Posted on Feb 26, 2010
bogueautoser
  • 5 Answers
SOURCE: Namco plug+play poor picture quality
if it has multible colors the yellow has to go to the green top plug and red and white go to the furthist away from the green plug.
Posted on Jul 10, 2012
I have a Namco plug and play game system with AV male jacks. Im having a problem with the system AVm jacks and my tv can't pic up the system signal. How can I fix this
I've had the same plug and play and had the same issue so I think I have a good diagnosis for you. Where the wires enter the back of the game, they tend to fray out and this causes a short in the cables causing the audio and video to no longer show up. It can be constant or intermittent. When intermittent, wiggling the cable close to were it enters the game will cause disruptions on the screen (not if on an HD tv) and for the video/audio to cut out or in. It's trash if you for trust yourself to take it apart and work on it but otherwise you can tear it open and check the wiring. Watch out for the screws that hold the shell together because some may be hidden under stickers as well. Make sure that all 4 connections for the wires inside are tight and that no fraying has occurred. If you see fraying then either snip it with scissors or tape it off with electrical tape. Good luck my friend :)
Nov 08, 2016 | Video Game Consoles & Games
Namco plug play not turning on
Same happened to mine...They just get old and die out...I guess its time to throw it away
May 17, 2013 | JAKKS Pacific Ms Pac Man Plug And Play Tv...
Jul 10, 2012 | Namco Arcade Classics Plug and Play TV...
Fire button won't work
Did u open it n c how does the button work n if u do can u put it up on youtube cuz im missin pieces n i need to buy them theres a video up takin it apart .
thanks
Jun 15, 2012 | Namco Arcade Classics Plug and Play TV...
Tail light & turn light on left side doesn't work---can it be a buser & if so where is it -in windstar xl ?
1.The fuses for those circuits have "blown." 2.Brake light switch mounting is not properly adjusted. 3.A connector plug somewhere in the circuit (s) has become "unplugged," or loose. 4.A conductor [wire] somewhere in the circuit has been cut, broken, "pinched," or pulled apart. Corrosion has occurred inside any one or more of the connector plugs, or at any connection/splice/ground, in the circuit. Corrosion can "block" the flow of electrical current just the same as if a wire were cut. 5.The brake light and turn signal switches have become defective [this is usually the "last" thing to fail, and in this case very highly unlikely].
Apr 08, 2010 | 1995 Chevrolet Monte Carlo
My tekken 5 wont load past the Namco logo and if it loads , it'll lag for a long time
Try cleaning the disc, with disc cleaner.
If still persist. you should clean the lens, open the case then clean it with cotton buds with alcohol, after finish, rub it again with soft cotton bud without alcohol.
Oct 24, 2009 | Namco Tekken 5
Namco plug and play turns on, but no visual or audio shows up on the tv
Try changing the channel on the tv. If it's a newer tv then make sure that the tv settings are correct. If it's an older tv,or one that you've played the system on before,then trying wiggling the wires and see if you notice any differences. If you see flashes of the game then it's probably in need of new hook ups (wires).
Hope this helps.
Aug 12, 2009 | Video Game Consoles & Games
Namco Arcade Classics Plug and Play TV Games Logo
384 people viewed this question
Top Namco Video Game Consoles & Games Experts
Josh Whitehead
Josh Whitehead
EnergeeUK
Level 1 Expert
Are you a Namco Video Game Console and Game Expert? Answer questions, earn points and help others
