What is instructions to lite a robertshaw 7200 series furnace gas valve?
Valve replaced last december
SOURCE: goodman ac/gas furnace unit mdl. # gmp075-4
i HAD THE SAME PROBLEM, TURNS OUT IT WAS THE FLAME SENSOR, CLEANED IT, AND ALL WAS GOOD
Posted on Dec 13, 2007
  • 464 Answers
SOURCE: Gas Valve Knob - Fits Robertshaw 700
try Elliott Refrigeration in Belleville, On and speak to Diane.
Posted on Oct 13, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: Hello I have a goodman gas furnace
On a call for heat, the 24 volt thermostat2.gif sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the ignitor. The ignitor will glow and you will be able to see it if viewed thru the small inspection port. Once the ignitor gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the ignitor does not energize (bad control, bad ignitor), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not lite (dirty pilot), the burner does not lite (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Most newer furnaces will have a diagnostic center or control built into the control module. You may be able to view it as it is running thru a small viewing port. Some models will require the removal of an access panel prior to finding it. On the reverse of the access panel, there will be a diagnostic chart that will aide you in understanding any error code recorded (usually a blinking light).
Posted on Oct 18, 2009
  • 79 Answers
SOURCE: My pilot keeps going out on the furnace. We lite
Check the pilot light size. Is it small and not surrounding the top 1/3 of the thermocouple? If it isn't then the pilot orfice is restricted or the pilot tube compression nut could be loose. The pilot gas adjustment screw may also need adjusting if this gas valve has one. These problems should only be addressed by an experienced service tech.
Posted on Nov 10, 2009
  • 3309 Answers
SOURCE: ? Replacement part for an obsolete Williams gas valve P100172A
Hi try national energy they should be able to tell you the right valve for this , the thermopile should read between 500 and 300 mille volts
Posted on Feb 10, 2010
Looking for Intertherm MGH-075-ABWN-05 gas valve Model 36c67 type 177
WHITE-RODGERS Type 36C67 - Emerson
www.emersonclimate.com/Documents/White-Rodgers/instruction.../0037-5838.pdf
Type 36C67 complete gas control combines into a single compact package the functions of 3-position Gas ****, pressure regulator, 100% shut-off automatio pilot, main operator and Natural-LP Gas Selector. Termostat Circuit Current (24 V Model):. 0.23 Amps. Pilot Gas Outlet: Located at outlet end of the valve. Type of Gas:.
Need refurbished gas valve & tube - mobilehomerepair.com
https://www.mobilehomerepair.com > ... > Nordyne Service & Repair Feb 9, 2014 - The gas valve model is 36C67 Type177 part# is 6243700 ... Two are a electric oil radiator type & the other two are electric grid type. ... guys that you had to rebuild for me hoping it would solve my Intertherm model MGH-055-ABW36C67 gas furnace not heating up hot enough but did not resolve the problem.
36C67-175 - Hvac Controls - Amazon.com
https://www.amazon.com/Unknown-36C67-175/dp/B003WZWGDE Rating: 4.3 - ‎4 reviews
Product description. Robertshaw, Coleman, Evcon 24V, 1/2" x 1/2" inlet/Straight outlet, Dual Standing Pilot, Step Opening, Mobile Home, Gas Valve Replacement w/Two 1/2" Side Outlets & Reducer Bushing (1/2" x 3/8") ...Missing: intertherm
Apr 07, 2018 | Intertherm Heating & Cooling
Why won't my Robertshaw gas furnace pilot light stay lit..Do I need a therm couplen or What.
if gas line to pilot generator clean and sill wont stay lit need new pilot generator
Jan 10, 2016 | Robertshaw 720-007 universal gas valve for...
I have a LENOX furnace and the fan comes on and furnace will lite then go out
Lenox furnace are a bear to work on if all the world isn't right that day. The sensor is not proofing to the control module.
Nov 13, 2015 | Honeywell Furnace Gas Valve Sv9501h2409
Hello I have a robertshaw 7100 see. Gas valve on me furnace and would like to know if it has both Nat. And propane orficess in it and how to change it from one to the other. Thanks brad
No gas valve has both orifices built in. You need to get the proper orifice for the BURNER , replace the old one with the new and then adjust the air mixture to get a flame with just a blue tip on the flame.tip.
Aug 18, 2014 | Heating & Cooling
I'm not sure if the orifice can be changed on your valve, that is the only difference between natural gas and propane. I recommend calling your local plumbing supply store for exact specs but the gas valve shouldn't be much $$$
Robertshaw 7200 series gas valve manual
have a robertshaw 7200 ercs gas valve, 1 year old, pilot wont light... any advise anyone know pilot lighting instructions ?
Nov 01, 2010 | Heating & Cooling
Furnace wont light properly.
You have to press the red buton below the off/test selector for about 1 minute until the flame sensor detects the heat coming from the pilot before switching the gas valve to on.
Dec 04, 2009 | Heating & Cooling
Oct 13, 2009 | American Range AF-25 Deep Fryer
Heating & Cooling Logo
88 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
