Question about Empire Heating & Cooling
Empire civf-25c cast iron unvented room heater
tooltech75
  • 80 Answers
SOURCE: I have a dyna glo unvented gas fired room heater
try the maintenance procedures on page 17. (click to see)
Posted on Oct 08, 2009
  • 57 Answers
SOURCE: I have a RMI-70LP Dyna-Glo 18,000 btu unvented
These can be converted by changing the orface on the heater and also the regulator. Best to contact your gas company or Dyna Glo to obtain the correct orface for that particular heater.
SOURCE: Have Dyna-Glo Unvented Gas-Fired Room Heater,
I had the same issue. Iwent to the local harware store and bought heay duty mirror hangers. They work great for only a few bucks.
Posted on Dec 09, 2009
  • 3248 Answers
SOURCE: I have a empire corcho unvented heather that the
Hi would clean it out could be slight blockage in the pilot
Posted on Feb 19, 2010
  • 674 Answers
SOURCE: I have a 3000btu dnya glo unvented gas fied room
I'm not familiar with these heaters but I assume there is button or something you push to get the pilot to light. There will be air in the pipe between where the gas comes in and the pilot light. You have to give it enough time for the gas to push this air out of the line. Hope this helps.
Posted on Mar 16, 2010
Burner for corcho wall moont heater model number ck30t3lt
Search Results
    SunStar Corcho Vent-Free Natural Gas Infrared Heater with ...
    www.efireplacestore.com > ... > SunStar Heating Products Space Heaters
    SunStar Corcho Vent-Free Natural Gas Infrared Heater with Manual Controls ... For added convenience, you can mount this heater on a wall or have it stand on ...
    Tech Video: Wall Heater Maintenance - YouTube
    ? 3:33
    https://www.youtube.com/watch?v=8eglHvyNV3U
    Oct 19, 2010 - Uploaded by FMIPRODUCTS
    How to clean the Vent-Free Wall Heater burner's & pilot. ... Fix Mr Heater Vent Free Pilot Problems - Part ...
    EMPIRE CORCHO UNVENTED GAS HEAT
Dec 14, 2015 | Heating & Cooling
Bought a used lp gas heater stove for living room.need istructions with pictures on how to install the vent. did not come with a manuel and unable to find info needed on website. this is an Empire Cast...
You have this posted under the Z-vent heading... is that the make pipe that came with the stove, and if not, what vent pipe came with the stove... we need to know which pipe it is exactly to be able to help you best...
heatman101
Aug 29, 2011 | Flex Z-flex Vent Pipe For Gas & Lp...
Thermostat is not shutting off heater..... can't adjust....gets room too hot. I keep on pilot only this is a EMpire RH25
Your heater uses a capillary bulb type thermostat sensor. If the small copper tubing that runs from the copper bulb to the control valve ls bent or crimped, it won't work properly or at all. Try setting the temperature at the lowest level, so that the room heats up gradually. Then, see if the Thermostat shuts it off. Also check the air intake on the front of the heater to make sure it's not obstructed or clogged in any way. If all else fails, contact Empire Comfort Systems Technical Service Dept @ 800-851-9396.
Hope this helps you troubleshoot and solve the problem.
May 02, 2011 | Empire RH35 Mid-Size Heater
Just had it installed on the wall and it says unvented, does that mean that it does not need to be vented or it needs to be vented. i am still afraid of the gas heater
an unvented heater is just that. unvented. they have a pilot system that shuts off the pilot if room air is depleated. in the instruction manual it will tell you to supply fresh air to the room. these have been out for quite awhile now and are safe to use.
Feb 13, 2011 | Heating & Cooling
I have a mod. REH-18-N 005843 ventless heater (gas) can I change it to porpane? How safe is in a reck room area?
you will need a conversion kit from natural gas to LPG. For room sizing you will need to look in the manual
Dec 14, 2010 | Rinnai Unvented Gas Zone Heater. 99% fuel...
Mar 13, 2010 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Oct 22, 2009 | Dyna-Glo Heating & Cooling
I have a RMI-70LP Dyna-Glo 18,000 btu unvented room heater. Can it be converted to natural gas?
Oct 08, 2009 | Dyna-Glo Heating & Cooling
Heating & Cooling Logo
50 people viewed this question
Top Empire Heating & Cooling Experts
Paul Carew
vance jones
Dan Webster
Dan Webster
Are you an Empire Heating and Cooling Expert? Answer questions, earn points and help others
