Question about Onkyo TX-DS575 Receiver
Left chanel deal - Onkyo TX-DS575 Receiver
Audio out left and right
Chanel is a French perfume maker. Usually, when discussing audio, we refer to channels, a totally different beast. But, since you capitalized the first letter in Chanel (which would make it a proper noun), maybe you really are referring to the perfume. Does your HandyCam have nostrils and Smellovision? I just can't keep up with all this new-fangled stuff....
Jun 21, 2012 | Sony Handycam CCDTRV118 Camcorder
I need a user manual for a Techwood LVD2263D flatscreen tv. I cannot install & re-tune to view TV channels
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers, for spare parts and service and Installation Instructions as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Dec 23, 2010 | Televison & Video
One of my DJ turntables = only left side stereo sound
need to narrow it down, using 1 turn table ONLY with the mixer on channel 1 (the chanel that is working) to test reciever is working properly and sound working on both side of the speakers, this eliminate the first turn table. Next, disconnect the working turn table (1) and connect your second turn table to the same chanel and see if you getting the sound coming chanel 1 just as your first turn table did. If you getting sound coming out from turn table on ch1 than is not the turn table issue. It will be you mixer having problems. You cant solve the problems having everything connected. Testing one turn table at a time using working chanel on the mixer to see if both turn table working properly. If you use the same chanel testing both turn table and the second one does not work than it will be one of your turn table is faulty. Note: if you find and test both of your turn table is working properly than it will be your mixer. good luck and hope that help..
Aug 06, 2009 | Technics SL-1200MK2 Turntable
Sound problem with home theater speakers
Change both left & right TDA7275 IC
Change all the 1uf 50v capacitors related to the IC,s
Thank you very much
contact me at meganetsl@yahoo.com
thank you again
M.Fateh Almunajed
Jul 28, 2009 | Yamaha 5.1-Ch. Surround Sound Home Theater...
Ts-wx105a pioneer subwoofer connection to car stereo
1 I 2 I 3 I 4 I
---------------------- the wiev from woofer
5 I 6 I 7 I 8 I
1- Right Chanel (-)
2- Right Chanel (+)
3- Left Chanel (-)
4- Left Chanel (+)
5- NC (not connected)
6- GROUND ( - )
7- POSITIVE ( + )
8- Remote (from HU)
Apr 26, 2009 | Car Audio & Video
Harman-kardon citation 7.1
Go to diyAudio.com and try asking there....
Jan 10, 2009 | Harman Kardon Audio Players & Recorders
Top left side screen shows video 5
Get the original Sony remote. Select TV or the Video input you want to use. Then press the Display button to make the text dissapear.
Jerry G.
Nov 13, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
JVC dual channel bridgeble Amp
Most repair shops offer a warranty. If you've recently had it repaired, return it to the shop to have them check it out. If you continue playing it as it is, more damage may occur and the additional damage isn't likely to be covered by the warranty.
Jul 01, 2008 | JVC KS-AX4750 Car Audio Amplifier
1 channel only works???? plz help
Inside the amp check copper6 for loose connection
Oct 28, 2006 | Volfenhag ZX-7180 Car Audio Amplifier
Onkyo TX-DS575 Receiver Logo
343 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
