Question about Kenwood KAC9105D Car Amp
Kenwood kac-9105D amp
The blue light stays on but not the red one. I have every wire hooked up and I'm only running a 500w rms alpine type S. I ran for about a day and today I went to start my car and ready to listen to some bass but no bass. Any help would be appreciated.
    Master:
  • 444 Answers
Tipical for that amp.Did you buy it used?
Posted on Oct 27, 2012
guly
  • 67 Answers
SOURCE: Amp not powering up correctly.
check transistor of the unit 1 or 2 tans. bad use a tester. the unit is overload protected. replace the deffecteve parts
Posted on Sep 19, 2007
blueextc3221
  • 15935 Answers
SOURCE: adjusting wattage on kenwood kac 9103 class D mono amp
That amplifier is 900W x 1 @ 2ohms.
If your subs are 4ohm SVC wired Parallel, resulting in a 2 ohm load, each sub will only see 1/2 of the rated power. (450W ea.)
Your gain (sensitivity) setting should be between 75% and 85% to max. You will be fine.
Posted on Jan 03, 2009
djmaximus_87
  • 26 Answers
SOURCE: kenwood kac-x1r flashes code e-03
HI DUDE EVERY REMOTE WIRE THEY HAVE FUSE NEAR THE BACK OF PLAYER TRY TO CHANGE IT .... R...TRY UNPLUG UR AMP .. AND ..FIX IT BACK
Posted on Jun 23, 2009
  • 136 Answers
SOURCE: connecting subwoofer to kac-7201 kenwood amp
from your sub connect one short piece of cable from + on one side to - on the other side using the same diameter cable as you are running to the sub from amp . this will leave you with + and - on opposite sides of speaker these will then run to the amp +to+ and - to- on the mono side of connetor which is one left + and one - right and the amp switched to bridged
Posted on Sep 03, 2009
  • 31 Answers
SOURCE: I have a Kenwood KAC-9103D hooked up to two 12
your amp has a output section problem,contact eric @ Capital Audio & Electronics Repair in Tallahassee,FL 850-339-1130 wee repair all brands and models
Posted on Mar 20, 2010
No sound from my subs
it should have a red light on if it is in protection mode. If it does not have the red light then buy a new amp and check all you wiring
Nov 22, 2013 | Kenwood KAC-9105D 1800W Max Class D 1 Ch...
What amp would be better to use with what speakers/sub? I have a KAC-7202 kenwood 920W maximum power (150wX2 RMS, 4ohms) (230wX2 RMS 2ohms) and then the other amp I have is a Alpine MRP-M500 mono power...
I'm using that Alpine right now for 2-12" subs and I have compared it to 6 or 7 other amps this month and most were 4 channel 150Watt/Channel Bridged to 300Watts x 2 and found the Alpine to be superior in both sound quality and loudness. The Alpine has also not turned off even with full volume for hours at a time, Very solid amp I was very surprised due to it's size!
Apr 04, 2013 | Kenwood Car Audio & Video
I have 3 Kenwood 12'inch subwoofers need to know how to wire them up to a Kenwood KAC-9105D
Follow the link and use the first diagram which illustrates wiring the subs to 2.66 ohms http://www.the12volt.com/caraudio/woofer_configurations.asp~Q~3~I~42
Remember that that amp is one ohm stable so you will not be getting the most out of that amp with that subs set up. The subs will only see 650 to 850 watts total...so each sub will only see about 215 - 275 watts a piece. Find out what the RMS wattage of your subs are each an determine if the wattage I mentioned above meets those requirements.
Sep 27, 2012 | Kenwood 12" 4-Ohm Single-Voice-Coil...
How to bridge a kenwood kac-9105d
Are you referring to something like this, using two different amps? It is a mono amp, meaning there's one amp in the box.
"KAC-9105D also has a Dual Mono Drive connection that allows you to strap two KAC-9105D amps together to power a single subwoofer."Quoted fromhttp://www.kenwoodusa.com/Car_Entertainment/Amplifiers/KAC-9105D
Here's a link to a page out of the Yamaha Sound Reinforcement book. the top shows a stereo amp (1 box, two different amps inside) hooked up to drive two different speakers, which is known as 'stereo' mode.It then shows the two amps hooked to the opposite sides of the same speaker, which is known as 'bridge' mode.http://books57.net/ampOuts.gif
Any help?
Feb 24, 2012 | Kenwood Car Audio & Video
What is the p. con on the back of the kenwood 9105d?
Power control wire - tells the amp to turn on, usually connected to the blue/white or blue wire when blue/white is not present on aftermarket radios. On factory systems you usually want to hook up this connector to an acc source on the car
Jun 13, 2010 | Kenwood KAC-9152D Car Audio Amplifier
NOT SURE WHAT OHMS SUB I NEED!
if you get the 4ohm you can wire it to run a 2ohm an the kenwood amp will push 900 watts at 2ohms.they say it can push up to 1800 watts,that would be at 1ohm.that kenwood runs 500 at 4ohms an 900 at 2ohm.if you need help wiring the sub or anything else let me know bertman285@hotmail,com Max Power Output 1800W Power Output 4 Ohm [14.4V] 500W x 1 [20-200Hz, 0.5%THD] 2 Ohm [14.4V] 900W x 1 [100Hz, 1.1%THD] Bridged[4 Ohm] -
Oct 09, 2009 | Alpine Type-R SWR-1242D Car Subwoofer
Red Light
that means you probably have a shorted speaker wire, a bad speaker or the amp itself is bad, try disconnecting the speakers one at a time and see if it turns on or not. if the red light stays on with no speakers hooked up it means the amp is bad
May 30, 2009 | Kenwood KAC-7252 Car Audio Amplifier
Adjusting wattage on kenwood kac 9103 class D mono amp
Jan 02, 2009 | Kenwood KAC-9103D Car Audio Amplifier
Kenwood KAC9105D Car Amp Logo
258 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
