Question about Denon AVR991 Receiver
No network connection
Airplay works ... Pandora has no internet connection ... Ethernet connections are good ... other components behind same hub are working with no problems
2 Suggested Answers
bigbird498
SOURCE: Unable to play pandora on Denon 1912
Check the Denon website. There is a notice for Pandora users. Pandora changed something and Denon products are blocked as of 11/30. They state that they are working on a fix and to check back after 12/6 for the update.
Posted on Dec 02, 2012
Won't log into pandora
http://us.marantz.com/DocumentMaster/us/PressReleases/PandoraProblem-M.pdf
Dec 01, 2012 | Marantz SR5006 AV Receiver with Networking...
Yamaha receiver will not connect to Airplay
I have the same problem, it seems the airplay connection is easily lost, it never plays for longer than an hour without itunes losing the receiver, then i have to reset the receiver so that it appears in itunes again, very annoying. I spoke to Yamaha and they are not aware of any issues but clearly there is one. A quick workaround is to bring the receiver up in a browser by typing in its IP address, go to IP Address tab and simply apply without changing anything, this causes the receiver to initialize its network function as you will see the amp resetting and it will then appear in iTunes. This doesn't work through the units setup without changing settings and then changing them back again. Hopefully this is just a glitch that will Yamaha will fix in the next firmware update, I am running 1.14 update.
Sep 28, 2012 | Yamaha RX-V473 5.1 Channel Network AV...
Got a hub genius GH4080SE and trying to connect computers, pls advise what is the steps?
Hardware Setup
1 Find the WAN or uplink port of the Ethernet hub. Typically, it is located on the rear of the unit, and it is often separate from the LAN ports.
2 Connect an Ethernet cable from the WAN port of the hub to either the Ethernet port of the internet modem or, if expanding a network, to an empty LAN port on the existing network’s router, switch or hub.
3 Plug an Ethernet cable into one of the LAN ports on the Ethernet hub and connect the other end of cable to the computer or device that will be added to the network. Repeat for any other devices that will need to be on the network.
4 Power up the Ethernet hub and the computers or other devices attached to it. On the front of the hub will be a series of LEDs that correspond to each LAN and WAN port on the hub. Every port that has a cable plugged into it should have one or more of the LEDs lit that represent that port. If not, check the connections and swap out the Ethernet cable if necessary.
Software Setup
1 Configure the network settings on each connected computer. If you are expanding a network and the network uses DCHP, or dynamic IP addressing, no configuration will be necessary. On networks using static IP addressing or on a new network setup using the Ethernet hub, each computer or device must be assigned a unique IP address. Local IP addresses must use the allowed “private” address pools that will not interfere with internet addresses. Acceptable addresses include 192.168.x.x, 172.16.x.x to 172.31.x.x, or 10.x.x.x. The “x” represents a number that is chosen by the user, from 0 to 254. All computers on the network should share the first three numbers in the address, with the final number representing the individual computer. In a network with three computers, for example, the first could be 192.168.1.1, the second could be 192.168.1.2 and the third could be 192.168.1.3, though the final number does not need to be sequential.
2 Click the “Start” button in Windows, select “Control Panel" and double-click the icon labeled “Network Connections.”
3 Right-click the icon for the Ethernet adapter and select “Properties.” Click on the check box marked “Internet Protocol (TCP/IP)” and press the “Properties” button.
4 Select the radio button labeled “Use the following IP address.” Enter a unique IP address for the computer and the applicable subnet mask. If a router is used on the network, enter the router’s IP address as the default gateway. Press the “OK” button and reboot if necessary.
5 Enable file and printer sharing from the “Properties” dialog for the Ethernet card if files will be transferred between the networked computers.
6 Click the “Start” button, select “Control Panel” and double-click on the “System” icon. Select the “Computer Name” tab and click on the button labeled “Change” to set the computer’s network name. In the “Computer Name” box, enter a unique name for the computer. In the “Member of” section, choose the radio button marked “Workgroup” and enter the workgroup of the network. If setting up a new network, this name can be change but all computers on the network must share the same workgroup name.
7 Verify that all computers can access the network and the Internet if connected.
Read more: How to Set up an Ethernet Hub | eHow.com http://www.ehow.com/how_4530475_set-up-ethernet-hub.html#ixzz0xnIzsGqa
see also Networking Diagram
Aug 27, 2010 | Genius GH 4080 SE 8-Port Ethernet Hub...
I need to ask about my problem. I just bought a D-Link DES-1008D and a D-Link DIR-300 Wireless-G Router my problem is after I attach 7 computers on my switch hub. I only have limited local network...
Make sure you're using a crossover ethernet cable to connect the router to the switch. Also make sure that the router has it's DHCP server up and running.
Nov 03, 2009 | D-Link DES-1008D 8-Port Ethernet Switch...
Cannot get the ethernet to work
The "cable unplugged" error points to an electromechanical problem. Something is broken.
The first thing to try would be to replace the ethernet cable (make sure it is wired straight through, since some hardware won't automatically configure for a crossover cable). If that doesn't work, test that the hub you are connecting to works by hooking it up at a friend's house. If the hub and cable are alright, it's possible that the jack on your network card is faulty.
Feb 01, 2009 | Linksys Instant Networking Hub
Laptop ethernet jack as a hub for another component
No. just buy a modem and a router in one that can do that kind of option without any hassle.
Dec 04, 2008 | Enterasys RoamAbout (CSISA-AX) Wireless...
Internet & xbox live sametime Netgear 8-port 10-base-t Ethernet Hub en108
Does the xbox work when connected directly to the internet (not through the hub)? If so, there may be some kind of conflict related to sharing your internet connection between the PC and xbox, and I'd reccommend getting a router instead of a hub.
Feb 20, 2008 | NetGear ProSafe DS104 10-Port Ethernet Hub...
Brother 2700CN Color Laserwriter--Loss of Ethernet Connection
No lights on network card mean that you will need to replace network port/card on printer if cable and connection is sound
Nov 28, 2007 | Office Equipment & Supplies
Not able to connect to the internet
Please list the model of the network hub you are using.  Also is a "hub/switch" or a routher.  Also are you using a DSL or Cable internet connection?  Please provide a little more details.
Oct 26, 2007 | NetGear (GS608UK) 8x1000 Mbps Networking...
Denon AVR991 Receiver Logo
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
