Question about Samsung DV448AEP 7.4 Cu. Ft. Electric Front Load Dryer - Platinum Stainless
Samsung dryer hums but the drum does not turn
Heard the running dryer make a thunk, and now it just makes a humming (motor?) sound.
  • 3 Answers
It sounds to me like the drive belt that goes around your dryer tub has broken.
Samsung dryer hums but the drum does not turn - images?q=tbn:and9gcqu5itfzbd0xyagva6nfwjbc486ekglruzljwmfemwgndlj-mg5tw
The back of the dryer will need to be removed to gain access to the problem.
Posted on Oct 27, 2012
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 46 Answers
It sounds like your drive belt might have busted. Remove the back panel and you will be able to inspect this. Here is a link for the belt.
http://www.repairclinic.com/Samsung-Dryer-Model-DV448AEP-ID-1067244-Belt-Parts
SOURCE: Samsung front load dryer will turn on but not
I was cleaning mine and doing the same thing last night. Washed a load of clothes tonight and went to dry them and everything works on it except it won't spin or heat. Heard the same type of popping noise last night cleaning it out. Have you found any solutions? Mine is just over a year old. I did some reading and thing that the dryer belt came off its assembly possibly. Have you found a solution?
Posted on Apr 14, 2011
  • 1267 Answers
SOURCE: Samsung dryer DV4015J turns on and motor sounds
If this is the older type, then the dryer drum is rotated by a thin loop belt that goes around the drum and then a pulley on the motor. I had to replace my 20 year old dryer belt on a Whirlpool a couple years ago. The front comes off and the belt slips over the drum. The front of the Whirlpool is held on by friction clips that have to be pried off with a flat blade. I suspect that you can do the same. look on the internet for a diagram of your dryer or you may have one in the manual that came with the machine.
Posted on Sep 19, 2010
heatman101
  • 43501 Answers
SOURCE: dryer power is on, cycle starts but dryer drum
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Nov 11, 2010
  • 291 Answers
SOURCE: have a samsung dryer model DV209AEW/XAA. I "hand
Check to make sure your child lock is off first. Hold the time and signal buttons simultaneously for three seconds. Unlikely, but do check. Some of these dryers have a safety switch that the idler pulley has to engage to allow the dryer to run. I tried to find a schematic for this model but could not get one to tell if you do have a safety switch. Look at the arm of the idler pulley and see if it is contacting the switch actuator correctly. When a belt breaks or pops off, sometimes the arm of the pulley will move to the other side of the switch actuator and will not allow the dryer to run once a belt is reistalled. I would also look to see if a wire was knocked off of the motor switch when your belt came off. Good Luck, Appliance Specialists
Posted on Dec 03, 2010
  • 8404 Answers
SOURCE: Dryer will not start, motor
I believe your start capacitor has failed. You can remove the motor and have it repaired at a motor fix place in your town or have someone come to your home and fix it ... or ... you can get the numbers from the device and replace it yourself. Be careful with the leads of the old capacitor. It may not be entirely drained of power.
Posted on May 03, 2011
I have a Samsung electric dryer dv400 that the drum doesn't turn when you press start. It just hums but doesn't turn.
Check the blower housing to be sure there are no foreign objects blocking the blower wheel from spinning, also see if you can turn the drum by hand, but don't spin it more than a foot or two as the belt may come off.
Jul 24, 2016 | Samsung Dryers
Why Frigidaire gas dryer will not start? makes humming noise
Rodney, if the humming noise sounds like your motor is running but the drum does not turn you probably have a broken belt.
Jan 20, 2015 | Frigidaire FGQ332ES Gas Dryer
My dryer only makes a humming sound
Remove the drum belt & start it if it hums and starts hard you will need a motor. If it don't hum check the drum rollers & glides on the front. Check the idler pully and belt. Drum rollers should turn easy if not either replace of try oiling them with some good oil after cleaning them real good. Hope this helps
Mar 01, 2014 | Whirlpool GEW9250 Electric Dryer
Dryer motor just hums, drum doesn't turn
check belt drum drive? check drum turns at all, it may be stuck.most drums turn with a belt. if it broke it is laying on the bottom of the dryer.didnt u see it??look again.
Apr 21, 2013 | Kenmore 98702 Stacked Washer/Dryer
Speed Queed Dryer Motor makes humming noise when starting.
motor is no longer strong enough to turn drum,soory-mike
Jan 24, 2010 | Speed Queen AES28AWF Electric Dryer
Press the start button on dryer, it hums but wont turn. With 2 people pressed the start button again, held the door switch, reached in turned the drum, it hummed stopped humming then no more nothing....
Sounds like a weak motor. You'll have to get a new motor installed. They are fairly inexpensive and easy to install yourself on that type of machine if you are handy. Motor is located in the bottom right of the machine, attached to the drum belt through a small pulley underneath the drum next to the motor.
Dec 27, 2009 | Dryers
Hums when turned on-won't turn over
belt may have broke. if you are hearing a humming sound . thats the motor .whitch is good, sounds like the belt broke or slipped off.
Sep 12, 2009 | Kenmore 73952 Gas Dryer
When we push the on button, you can hear a hum,
Sounds like the belt that turns the drum has broken. the hum sound is the motor turning. Does it still get hot in the drum? If so then you need a replacement belt ($15-$25).You can open the rear or the dryer to confirm the belt is broken. Be sure to unplug from the wall outlet to avoid electrical shock.
Aug 18, 2009 | Dryers
When you press the start button the dryer hums and doesnt turn
first thing you need to do is open the door and try to rotate drum by hand it it is not turn by hand that mean there is some thing stack in your blower fan. if you can turn the drum by hand you need two people to check this problem..one open the door there is one push button, push that button and hold now second person need to push the start button when you heard hums sound the turn the drum by hand again if your dryer stat spin that mean you have bad motor. (forgive me for my english)
Apr 18, 2009 | Dryers
Electric Whirpool Dyrer Wont Run
your dryer needs a new motor
Sep 17, 2007 | Dryers
Samsung DV448AEP 7.4 Cu. Ft. Electric Front Load Dryer - Platinum Stainless Logo
1,026 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
